Forum Index : Microcontroller and PC projects : MMbasic RP2350 V6.01.00EXP with user-defined structures
| Page 1 of 7 |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12175 |
Attached the manual and firmware for the next experimental version of the RP2350 firmware with user-defined structures MMBasic_Structures_Manual.pdf PicoMiteRP2350V6.01.00EXP2.zip Changes from 6.01.00EXP: You can now use simple assignment of one structure to another, including records within an array rather than having to use STRUCT COPY (see tests 69 to 78). STRUCT LOAD and SAVE now work on either a single record in an array or the whole array (see tests 64 to 67) New subfunction STRUCT(SIZEOF returns the size of a type in bytes (see tests 60-63) Manual updated. Note specifically the section on alignment of data within a type. ' Comprehensive Structure Test for PicoMite ' Tests all implemented struct features Option Explicit Option Default None Print "=== Structure Tests ===" ' ============================================ ' TEST 1: Basic TYPE definition and simple struct ' ============================================ Print "TEST 1: Basic struct definition and access" Type Point x As INTEGER y As INTEGER End Type Dim p1 As Point p1.x = 100 p1.y = 200 If p1.x = 100 And p1.y = 200 Then Print " PASS: Simple struct assignment and read" Else Print " FAIL: Expected 100,200 got"; p1.x; ","; p1.y EndIf ' ============================================ ' TEST 2: Struct with different member types ' ============================================ Print "TEST 2: Struct with mixed types" Type Person age As INTEGER height As FLOAT name As STRING End Type Dim person1 As Person person1.age = 42 person1.height = 1.85 person1.name = "John" If person1.age = 42 And person1.height = 1.85 And person1.name = "John" Then Print " PASS: Mixed type struct" Else Print " FAIL: Mixed type struct failed" EndIf ' ============================================ ' TEST 3: Array of structures ' ============================================ Print "TEST 3: Array of structures" Dim points(5) As Point points(0).x = 10 : points(0).y = 11 points(1).x = 20 : points(1).y = 21 points(2).x = 30 : points(2).y = 31 points(3).x = 40 : points(3).y = 41 points(4).x = 50 : points(4).y = 51 points(5).x = 60 : points(5).y = 61 Dim ok% = 1 Dim i% For i% = 0 To 5 If points(i%).x <> (i% + 1) * 10 Or points(i%).y <> (i% + 1) * 10 + 1 Then ok% = 0 EndIf Next i% If ok% Then Print " PASS: Array of structs" Else Print " FAIL: Array of structs" EndIf ' ============================================ ' TEST 4: Pass struct to SUB by reference ' ============================================ Print "TEST 4: Pass struct to SUB by reference" Sub DoublePoint(pt As Point) pt.x = pt.x * 2 pt.y = pt.y * 2 End Sub Dim p2 As Point p2.x = 5 p2.y = 7 DoublePoint p2 If p2.x = 10 And p2.y = 14 Then Print " PASS: Struct passed by reference modified caller" Else Print " FAIL: Expected 10,14 got"; p2.x; ","; p2.y EndIf ' ============================================ ' TEST 5: Pass array element to SUB ' ============================================ Print "TEST 5: Pass array element to SUB" Dim arr(3) As Point arr(1).x = 100 arr(1).y = 200 DoublePoint arr(1) If arr(1).x = 200 And arr(1).y = 400 Then Print " PASS: Array element passed by reference" Else Print " FAIL: Expected 200,400 got"; arr(1).x; ","; arr(1).y EndIf ' ============================================ ' TEST 6: Pass struct array to SUB ' ============================================ Print "TEST 6: Pass struct array to SUB" Sub SumPoints(pts() As Point, count%) Local sum_x% = 0, sum_y% = 0 Local j% For j% = 0 To count% - 1 sum_x% = sum_x% + pts(j%).x sum_y% = sum_y% + pts(j%).y Next j% Print " Sum X ="; sum_x%; ", Sum Y ="; sum_y% End Sub Dim testArr(2) As Point testArr(0).x = 1 : testArr(0).y = 2 testArr(1).x = 3 : testArr(1).y = 4 testArr(2).x = 5 : testArr(2).y = 6 Print " Calling SumPoints (expect Sum X=9, Sum Y=12):" SumPoints testArr(), 3 Print " PASS: Array of structs passed to SUB (verify output above)" ' ============================================ ' TEST 7: Modify struct array in SUB ' ============================================ Print "TEST 7: Modify struct array elements in SUB" Sub ZeroPoints(pts() As Point, count%) Local k% For k% = 0 To count% - 1 pts(k%).x = 0 pts(k%).y = 0 Next k% End Sub ZeroPoints testArr(), 3 ok% = 1 For i% = 0 To 2 If testArr(i%).x <> 0 Or testArr(i%).y <> 0 Then ok% = 0 Next i% If ok% Then Print " PASS: SUB modified caller's struct array" Else Print " FAIL: Array not properly zeroed" EndIf ' ============================================ ' TEST 8: STRUCT COPY command ' ============================================ Print "TEST 8: STRUCT COPY command" Dim src As Point, dst As Point src.x = 999 src.y = 888 dst.x = 0 dst.y = 0 Struct Copy src To dst If dst.x = 999 And dst.y = 888 Then Print " PASS: STRUCT COPY works" Else Print " FAIL: Expected 999,888 got"; dst.x; ","; dst.y EndIf ' ============================================ ' TEST 9: STRUCT COPY with mixed types ' ============================================ Print "TEST 9: STRUCT COPY with mixed types" Dim src_person As Person, dst_person As Person src_person.age = 25 src_person.height = 1.75 src_person.name = "Alice" Struct Copy src_person To dst_person If dst_person.age = 25 And dst_person.height = 1.75 And dst_person.name = "Alice" Then Print " PASS: STRUCT COPY with mixed types" Else Print " FAIL: STRUCT COPY mixed types failed" EndIf ' ============================================ ' TEST 10: Function returning value from struct member ' ============================================ Print "TEST 10: Function using struct member" Function GetDistance(pt As Point) As FLOAT GetDistance = Sqr(pt.x * pt.x + pt.y * pt.y) End Function Dim p3 As Point p3.x = 3 p3.y = 4 Dim dist! = GetDistance(p3) If dist! = 5 Then Print " PASS: Function with struct parameter" Else Print " FAIL: Expected 5 got"; dist! EndIf ' ============================================ ' TEST 11: Nested struct access in expressions ' ============================================ Print "TEST 11: Struct members in expressions" Dim pA As Point, pB As Point pA.x = 10 : pA.y = 20 pB.x = 30 : pB.y = 40 Dim sum_expr% = pA.x + pB.x + pA.y + pB.y If sum_expr% = 100 Then Print " PASS: Struct members in expressions" Else Print " FAIL: Expected 100 got"; sum_expr% EndIf ' ============================================ ' TEST 12: Array index with variable ' ============================================ Print "TEST 12: Array of structs with variable index" Dim dynArr(9) As Point For i% = 0 To 9 dynArr(i%).x = i% * 2 dynArr(i%).y = i% * 3 Next i% ok% = 1 For i% = 0 To 9 If dynArr(i%).x <> i% * 2 Or dynArr(i%).y <> i% * 3 Then ok% = 0 EndIf Next i% If ok% Then Print " PASS: Variable index into struct array" Else Print " FAIL: Variable index failed" EndIf ' ============================================ ' TEST 13: Multiple struct types ' ============================================ Print "TEST 13: Multiple struct type definitions" Type Rectangle left As INTEGER top As INTEGER width As INTEGER height As INTEGER End Type Type Circle cx As INTEGER cy As INTEGER radius As FLOAT End Type Dim rect As Rectangle Dim circ As Circle rect.left = 10 : rect.top = 20 : rect.width = 100 : rect.height = 50 circ.cx = 50 : circ.cy = 50 : circ.radius = 25.5 If rect.left = 10 And rect.width = 100 And circ.radius = 25.5 Then Print " PASS: Multiple struct types" Else Print " FAIL: Multiple struct types" EndIf ' ============================================ ' TEST 14: Struct parameter not modified without assignment ' ============================================ Print "TEST 14: Read-only access in SUB" Sub ReadOnlyTest(pt As Point) Local val% = pt.x + pt.y Print " Read value:"; val% End Sub Dim p4 As Point p4.x = 111 p4.y = 222 ReadOnlyTest p4 If p4.x = 111 And p4.y = 222 Then Print " PASS: Struct unchanged after read-only access" Else Print " FAIL: Struct was unexpectedly modified" EndIf ' ============================================ ' TEST 15: Simple struct initialization ' ============================================ Print "TEST 15: Simple struct initialization" Dim initPoint As Point = (42, 99) If initPoint.x = 42 And initPoint.y = 99 Then Print " PASS: Simple struct initialization" Else Print " FAIL: Expected 42,99 got"; initPoint.x; ","; initPoint.y EndIf ' ============================================ ' TEST 16: Struct with string initialization ' ============================================ Print "TEST 16: Struct with string initialization" Dim initPerson As Person = (30, 1.80, "Bob") If initPerson.age = 30 And initPerson.height = 1.80 And initPerson.name = "Bob" Then Print " PASS: Struct with string initialization" Else Print " FAIL: Struct with string init failed" EndIf ' ============================================ ' TEST 17: Array of structs initialization ' ============================================ Print "TEST 17: Array of structs initialization" Dim initArr(1) As Point = (10, 20, 30, 40) If initArr(0).x = 10 And initArr(0).y = 20 And initArr(1).x = 30 And initArr(1).y = 40 Then Print " PASS: Array of structs initialization" Else Print " FAIL: Array init got"; initArr(0).x; ","; initArr(0).y; ","; initArr(1).x; ","; initArr(1).y EndIf ' ============================================ ' TEST 18: Mixed type struct array initialization ' ============================================ Print "TEST 18: Mixed type struct array initialization" Type TestStruct num As INTEGER txt As STRING End Type Dim mixArr(1) As TestStruct = (100, "first", 200, "second") If mixArr(0).num = 100 And mixArr(0).txt = "first" And mixArr(1).num = 200 And mixArr(1).txt = "second" Then Print " PASS: Mixed type struct array initialization" Else Print " FAIL: Mixed init failed" EndIf ' ============================================ ' TEST 19: LOCAL struct in subroutine ' ============================================ Print "TEST 19: LOCAL struct in subroutine" Sub TestLocalStruct Local localPt As Point localPt.x = 555 localPt.y = 666 Print " Local struct values:"; localPt.x; ","; localPt.y If localPt.x = 555 And localPt.y = 666 Then Print " PASS: LOCAL struct works" Else Print " FAIL: LOCAL struct failed" EndIf End Sub TestLocalStruct ' ============================================ ' TEST 20: LOCAL struct array in subroutine ' ============================================ Print "TEST 20: LOCAL struct array in subroutine" Sub TestLocalStructArray Local localArr(2) As Point localArr(0).x = 1 : localArr(0).y = 2 localArr(1).x = 3 : localArr(1).y = 4 localArr(2).x = 5 : localArr(2).y = 6 Local ok% = 1 If localArr(0).x <> 1 Or localArr(0).y <> 2 Then ok% = 0 If localArr(1).x <> 3 Or localArr(1).y <> 4 Then ok% = 0 If localArr(2).x <> 5 Or localArr(2).y <> 6 Then ok% = 0 If ok% Then Print " PASS: LOCAL struct array works" Else Print " FAIL: LOCAL struct array failed" EndIf End Sub TestLocalStructArray ' ============================================ ' TEST 21: LOCAL struct with initialization ' ============================================ Print "TEST 21: LOCAL struct with initialization" Sub TestLocalStructInit Local initPt As Point = (777, 888) If initPt.x = 777 And initPt.y = 888 Then Print " PASS: LOCAL struct initialization works" Else Print " FAIL: Expected 777,888 got"; initPt.x; ","; initPt.y EndIf End Sub TestLocalStructInit ' ============================================ ' TEST 22: Multiple LOCAL struct calls (memory test) ' ============================================ Print "TEST 22: Multiple LOCAL struct calls (memory test)" Sub MemTest Local tmp As Point tmp.x = 123 tmp.y = 456 End Sub ' Call multiple times to verify memory is properly freed MemTest MemTest MemTest MemTest MemTest Print " PASS: Multiple LOCAL struct calls completed (no memory error)" ' ============================================ ' TEST 23: STRUCT SORT by integer field ' ============================================ Print "TEST 23: STRUCT SORT by integer field" Dim sortArr(4) As Point sortArr(0).x = 50 : sortArr(0).y = 5 sortArr(1).x = 20 : sortArr(1).y = 2 sortArr(2).x = 40 : sortArr(2).y = 4 sortArr(3).x = 10 : sortArr(3).y = 1 sortArr(4).x = 30 : sortArr(4).y = 3 Struct Sort sortArr(), x If sortArr(0).x = 10 And sortArr(1).x = 20 And sortArr(2).x = 30 And sortArr(3).x = 40 And sortArr(4).x = 50 Then Print " PASS: STRUCT SORT by integer ascending" Else Print " FAIL: Sort order wrong" EndIf ' ============================================ ' TEST 24: STRUCT SORT reverse ' ============================================ Print "TEST 24: STRUCT SORT reverse" Struct Sort sortArr(), x, 1 If sortArr(0).x = 50 And sortArr(1).x = 40 And sortArr(2).x = 30 And sortArr(3).x = 20 And sortArr(4).x = 10 Then Print " PASS: STRUCT SORT reverse" Else Print " FAIL: Reverse sort order wrong" EndIf ' ============================================ ' TEST 25: STRUCT SORT by string field ' ============================================ Print "TEST 25: STRUCT SORT by string field" Type NamedItem id As INTEGER name As STRING End Type Dim items(4) As NamedItem items(0).id = 1 : items(0).name = "Cherry" items(1).id = 2 : items(1).name = "Apple" items(2).id = 3 : items(2).name = "Elderberry" items(3).id = 4 : items(3).name = "Banana" items(4).id = 5 : items(4).name = "Date" Struct Sort items(), name If items(0).name = "Apple" And items(1).name = "Banana" And items(2).name = "Cherry" And items(3).name = "Date" And items(4).name = "Elderberry" Then Print " PASS: STRUCT SORT by string" Else Print " FAIL: String sort wrong:"; items(0).name; ","; items(1).name; ","; items(2).name EndIf ' Verify ID followed the sort If items(0).id = 2 And items(1).id = 4 And items(2).id = 1 Then Print " PASS: Other fields preserved during sort" Else Print " FAIL: ID values not preserved" EndIf ' ============================================ ' TEST 26: STRUCT SORT case insensitive ' ============================================ Print "TEST 26: STRUCT SORT case insensitive" items(0).name = "cherry" items(1).name = "APPLE" items(2).name = "Elderberry" items(3).name = "banana" items(4).name = "DATE" Struct Sort items(), name, 2 If Left$(items(0).name, 1) = "A" Or Left$(items(0).name, 1) = "a" Then Print " PASS: STRUCT SORT case insensitive (Apple/APPLE first)" Else Print " FAIL: Case insensitive sort wrong, first="; items(0).name EndIf ' ============================================ ' TEST 27: STRUCT SORT by float field ' ============================================ Print "TEST 27: STRUCT SORT by float field" Type Measurement value As FLOAT label As STRING End Type Dim measurements(3) As Measurement measurements(0).value = 3.14 : measurements(0).label = "pi" measurements(1).value = 1.41 : measurements(1).label = "sqrt2" measurements(2).value = 2.71 : measurements(2).label = "e" measurements(3).value = 0.57 : measurements(3).label = "euler" Struct Sort measurements(), value If measurements(0).value < measurements(1).value And measurements(1).value < measurements(2).value And measurements(2).value < measurements(3).value Then Print " PASS: STRUCT SORT by float" Else Print " FAIL: Float sort wrong" EndIf ' ============================================ ' TEST 28: STRUCT SORT empty strings at end ' ============================================ Print "TEST 28: STRUCT SORT empty strings at end" items(0).name = "Zebra" items(1).name = "" items(2).name = "Apple" items(3).name = "" items(4).name = "Mango" Struct Sort items(), name, 4 If items(3).name = "" And items(4).name = "" And items(0).name <> "" Then Print " PASS: STRUCT SORT empty strings at end" Else Print " FAIL: Empty strings not at end" EndIf ' ============================================ ' TEST 29: Function returning struct ' ============================================ Print "TEST 29: Function returning struct" Dim p29 As Point p29 = MakePoint(123, 456) If p29.x = 123 And p29.y = 456 Then Print " PASS: Function returning struct" Else Print " FAIL: Expected 123,456 got"; p29.x; ","; p29.y EndIf ' ============================================ ' TEST 30: Function returning struct with Person (multiple types) ' ============================================ Print "TEST 30: Function returning struct with mixed types" Dim p30 As Person p30 = MakePerson("Bob", 35, 1.75) If p30.name = "Bob" And p30.age = 35 And Abs(p30.height - 1.75) < 0.01 Then Print " PASS: Function returning struct with mixed types" Else Print " FAIL: Expected Bob,35,1.75 got"; p30.name; ","; p30.age; ","; p30.height EndIf ' ============================================ ' TEST 31: Struct packing - string followed by int/float (non-8 aligned) ' ============================================ Print "TEST 31: Struct packing with short string before int/float" Type PackTest label As STRING LENGTH 5 value As INTEGER ratio As FLOAT End Type Dim pk As PackTest pk.label = "Test" pk.value = 12345 pk.ratio = 3.14 If pk.label = "Test" And pk.value = 12345 And Abs(pk.ratio - 3.14) < 0.01 Then Print " PASS: Struct packing with short string" Else Print " FAIL: Got label="; pk.label; " value="; pk.value; " ratio="; pk.ratio EndIf ' ============================================ ' TEST 32: Function returning struct with array member ' ============================================ Print "TEST 32: Function returning struct with array member" Type WithArray id As INTEGER values(3) As INTEGER End Type Dim wa As WithArray wa = MakeWithArray(99, 10, 20, 30, 40) If wa.id = 99 And wa.values(0) = 10 And wa.values(1) = 20 And wa.values(2) = 30 And wa.values(3) = 40 Then Print " PASS: Function returning struct with array member" Else Print " FAIL: Got id="; wa.id; " values="; wa.values(0); ","; wa.values(1); ","; wa.values(2); ","; wa.values(3) EndIf ' ============================================ ' TEST 33: STRUCT CLEAR - single struct ' ============================================ Print "TEST 33: STRUCT CLEAR - single struct" Dim clearTest As Person clearTest.age = 42 clearTest.height = 1.85 clearTest.name = "TestName" Struct Clear clearTest If clearTest.age = 0 And clearTest.height = 0 And clearTest.name = "" Then Print " PASS: STRUCT CLEAR single struct" Else Print " FAIL: Got age="; clearTest.age; " height="; clearTest.height; " name="; clearTest.name EndIf ' ============================================ ' TEST 34: STRUCT CLEAR - array of structs ' ============================================ Print "TEST 34: STRUCT CLEAR - array of structs" Dim clearArr(2) As Point clearArr(0).x = 1 : clearArr(0).y = 2 clearArr(1).x = 3 : clearArr(1).y = 4 clearArr(2).x = 5 : clearArr(2).y = 6 Struct Clear clearArr() ok% = 1 For i% = 0 To 2 If clearArr(i%).x <> 0 Or clearArr(i%).y <> 0 Then ok% = 0 Next i% If ok% Then Print " PASS: STRUCT CLEAR array of structs" Else Print " FAIL: Array not properly cleared" EndIf ' ============================================ ' TEST 35: STRUCT SWAP ' ============================================ Print "TEST 35: STRUCT SWAP" Dim swapA As Point, swapB As Point swapA.x = 100 : swapA.y = 200 swapB.x = 300 : swapB.y = 400 Struct Swap swapA, swapB If swapA.x = 300 And swapA.y = 400 And swapB.x = 100 And swapB.y = 200 Then Print " PASS: STRUCT SWAP" Else Print " FAIL: Got A="; swapA.x; ","; swapA.y; " B="; swapB.x; ","; swapB.y EndIf ' ============================================ ' TEST 36: STRUCT SWAP with array elements ' ============================================ Print "TEST 36: STRUCT SWAP with array elements" Dim swapArr(1) As Person swapArr(0).name = "Alice" : swapArr(0).age = 25 : swapArr(0).height = 1.60 swapArr(1).name = "Bob" : swapArr(1).age = 30 : swapArr(1).height = 1.80 Struct Swap swapArr(0), swapArr(1) If swapArr(0).name = "Bob" And swapArr(0).age = 30 And swapArr(1).name = "Alice" And swapArr(1).age = 25 Then Print " PASS: STRUCT SWAP array elements" Else Print " FAIL: Swap array elements failed" EndIf ' ============================================ ' TEST 37: STRUCT(FIND) - find by integer member ' ============================================ Print "TEST 37: STRUCT(FIND) - find by integer" Dim findArr(4) As Person findArr(0).name = "Alice" : findArr(0).age = 25 findArr(1).name = "Bob" : findArr(1).age = 30 findArr(2).name = "Charlie" : findArr(2).age = 35 findArr(3).name = "Diana" : findArr(3).age = 40 findArr(4).name = "Eve" : findArr(4).age = 45 Dim foundIdx% = Struct(FIND, findArr(), "age", 35) If foundIdx% = 2 Then Print " PASS: STRUCT(FIND) by integer found at index 2" Else Print " FAIL: Expected index 2, got"; foundIdx% EndIf ' ============================================ ' TEST 38: STRUCT(FIND) - find by string member ' ============================================ Print "TEST 38: STRUCT(FIND) - find by string" foundIdx% = Struct(FIND, findArr(), "name", "Diana") If foundIdx% = 3 Then Print " PASS: STRUCT(FIND) by string found at index 3" Else Print " FAIL: Expected index 3, got"; foundIdx% EndIf ' ============================================ ' TEST 39: STRUCT(FIND) - not found returns -1 ' ============================================ Print "TEST 39: STRUCT(FIND) - not found" foundIdx% = Struct(FIND, findArr(), "name", "Zara") If foundIdx% = -1 Then Print " PASS: STRUCT(FIND) returns -1 when not found" Else Print " FAIL: Expected -1, got"; foundIdx% EndIf ' ============================================ ' TEST 40: STRUCT(FIND) - find by float member ' ============================================ Print "TEST 40: STRUCT(FIND) - find by float" findArr(2).height = 1.77 foundIdx% = Struct(FIND, findArr(), "height", 1.77) If foundIdx% = 2 Then Print " PASS: STRUCT(FIND) by float" Else Print " FAIL: Expected index 2, got"; foundIdx% EndIf ' ============================================ ' TEST 42: STRUCT(FIND) with start parameter - iterate through duplicates ' ============================================ Print "TEST 42: STRUCT(FIND) with start parameter" ' Add duplicate ages findArr(0).age = 30 ' Alice now 30 findArr(1).age = 30 ' Bob already 30 findArr(4).age = 30 ' Eve now 30 ' Find first person with age 30 foundIdx% = Struct(FIND, findArr(), "age", 30) If foundIdx% <> 0 Then Print " FAIL: First match should be index 0, got"; foundIdx% Else ' Find next person with age 30 starting after first match foundIdx% = Struct(FIND, findArr(), "age", 30, foundIdx% + 1) If foundIdx% <> 1 Then Print " FAIL: Second match should be index 1, got"; foundIdx% Else ' Find next person with age 30 starting after second match foundIdx% = Struct(FIND, findArr(), "age", 30, foundIdx% + 1) If foundIdx% <> 4 Then Print " FAIL: Third match should be index 4, got"; foundIdx% Else ' Try to find another - should return -1 foundIdx% = Struct(FIND, findArr(), "age", 30, foundIdx% + 1) If foundIdx% = -1 Then Print " PASS: STRUCT(FIND) with start parameter iterates correctly" Else Print " FAIL: Should return -1 after last match, got"; foundIdx% EndIf EndIf EndIf EndIf ' Restore original ages for remaining tests findArr(0).age = 25 : findArr(1).age = 30 : findArr(4).age = 45 ' ============================================ ' TEST 41: STRUCT SAVE and LOAD ' ============================================ Print "TEST 41: STRUCT SAVE and LOAD" ' Create test data Dim saveArr(2) As Person saveArr(0).name = "Alice" : saveArr(0).age = 25 : saveArr(0).height = 1.65 saveArr(1).name = "Bob" : saveArr(1).age = 30 : saveArr(1).height = 1.75 saveArr(2).name = "Charlie" : saveArr(2).age = 35 : saveArr(2).height = 1.85 ' Save to file Open "structtest.dat" For Output As #1 Struct Save #1, saveArr() Close #1 ' Clear the array Struct Clear saveArr() ' Verify cleared ok% = 1 For i% = 0 To 2 If saveArr(i%).name <> "" Or saveArr(i%).age <> 0 Then ok% = 0 Next i% If ok% = 0 Then Print " FAIL: Array not cleared before load test" Else ' Load back from file Open "structtest.dat" For Input As #1 Struct Load #1, saveArr() Close #1 ' Verify data - check each condition separately to avoid line continuation issues Dim loadOk% = 1 If saveArr(0).name <> "Alice" Or saveArr(0).age <> 25 Then loadOk% = 0 If Abs(saveArr(0).height - 1.65) >= 0.01 Then loadOk% = 0 If saveArr(1).name <> "Bob" Or saveArr(1).age <> 30 Then loadOk% = 0 If Abs(saveArr(1).height - 1.75) >= 0.01 Then loadOk% = 0 If saveArr(2).name <> "Charlie" Or saveArr(2).age <> 35 Then loadOk% = 0 If Abs(saveArr(2).height - 1.85) >= 0.01 Then loadOk% = 0 If loadOk% Then Print " PASS: STRUCT SAVE/LOAD" Else Print " FAIL: Data mismatch after load" Print " [0] "; saveArr(0).name; ","; saveArr(0).age; ","; saveArr(0).height Print " [1] "; saveArr(1).name; ","; saveArr(1).age; ","; saveArr(1).height Print " [2] "; saveArr(2).name; ","; saveArr(2).age; ","; saveArr(2).height EndIf EndIf ' Clean up test file Kill "structtest.dat" ' ============================================ ' TEST 43: STRUCT PRINT - single struct ' ============================================ Print "TEST 43: STRUCT PRINT - single struct" Print " Output should show Person structure with Alice, 25, 1.65:" Dim printTest As Person printTest.name = "Alice" printTest.age = 25 printTest.height = 1.65 Struct Print printTest Print " PASS: (verify output above manually)" ' ============================================ ' TEST 44: STRUCT PRINT - array element ' ============================================ Print "TEST 44: STRUCT PRINT - array element" Print " Output should show Point structure with x=100, y=200:" Dim printArr(2) As Point printArr(0).x = 100 : printArr(0).y = 200 printArr(1).x = 300 : printArr(1).y = 400 Struct Print printArr(0) Print " PASS: (verify output above manually)" ' ============================================ ' TEST 45: STRUCT PRINT - whole array ' ============================================ Print "TEST 45: STRUCT PRINT - whole array" Print " Output should show 2 Point elements:" Struct Print printArr() Print " PASS: (verify output above manually)" ' ============================================ ' TEST 46: STRUCT(SIZE) - basic 1D array ' ============================================ Print "TEST 46: STRUCT(SIZE) - basic 1D array" Dim boundArr1(9) As Point Dim bound1% = Struct(SIZE, boundArr1()) If bound1% = 9 Then Print " PASS: STRUCT(SIZE) returned "; bound1% Else Print " FAIL: Expected 9, got "; bound1% EndIf ' ============================================ ' TEST 47: STRUCT(SIZE) - with dimension parameter ' ============================================ Print "TEST 47: STRUCT(SIZE) - 2D array with dimension" Dim boundArr2(4, 7) As Point Dim dim1% = Struct(SIZE, boundArr2(), 1) Dim dim2% = Struct(SIZE, boundArr2(), 2) If dim1% = 4 And dim2% = 7 Then Print " PASS: Dimension 1 = "; dim1%; ", Dimension 2 = "; dim2% Else Print " FAIL: Expected (4,7), got ("; dim1%; ","; dim2%; ")" EndIf ' ============================================ ' TEST 48: STRUCT(SIZE) - default dimension ' ============================================ Print "TEST 48: STRUCT(SIZE) - default dimension (1)" Dim dim1b% = Struct(SIZE, boundArr2()) If dim1b% = 4 Then Print " PASS: Default dimension returned "; dim1b% Else Print " FAIL: Expected 4, got "; dim1b% EndIf ' ============================================ ' TEST 49: STRUCT COPY array() TO array() ' ============================================ Print "TEST 49: STRUCT COPY array() TO array()" Dim srcCopy(2) As Point srcCopy(0).x = 10 : srcCopy(0).y = 11 srcCopy(1).x = 20 : srcCopy(1).y = 21 srcCopy(2).x = 30 : srcCopy(2).y = 31 Dim dstCopy(4) As Point ' Larger destination Struct Copy srcCopy() To dstCopy() Dim copyOk% = 1 If dstCopy(0).x <> 10 Or dstCopy(0).y <> 11 Then copyOk% = 0 If dstCopy(1).x <> 20 Or dstCopy(1).y <> 21 Then copyOk% = 0 If dstCopy(2).x <> 30 Or dstCopy(2).y <> 31 Then copyOk% = 0 If copyOk% Then Print " PASS: Array copy successful" Else Print " FAIL: Array copy data mismatch" Print " [0] "; dstCopy(0).x; ","; dstCopy(0).y Print " [1] "; dstCopy(1).x; ","; dstCopy(1).y Print " [2] "; dstCopy(2).x; ","; dstCopy(2).y EndIf ' ============================================ ' TEST 50: STRUCT COPY array preserves extra elements ' ============================================ Print "TEST 50: STRUCT COPY array preserves extra dest elements" ' Set destination element 3 and 4 before copy Dim srcCopy2(1) As Point srcCopy2(0).x = 100 : srcCopy2(0).y = 101 srcCopy2(1).x = 200 : srcCopy2(1).y = 201 Dim dstCopy2(3) As Point dstCopy2(2).x = 999 : dstCopy2(2).y = 998 dstCopy2(3).x = 888 : dstCopy2(3).y = 887 Struct Copy srcCopy2() To dstCopy2() Dim copy2Ok% = 1 If dstCopy2(0).x <> 100 Or dstCopy2(0).y <> 101 Then copy2Ok% = 0 If dstCopy2(1).x <> 200 Or dstCopy2(1).y <> 201 Then copy2Ok% = 0 If dstCopy2(2).x <> 999 Or dstCopy2(2).y <> 998 Then copy2Ok% = 0 If dstCopy2(3).x <> 888 Or dstCopy2(3).y <> 887 Then copy2Ok% = 0 If copy2Ok% Then Print " PASS: Extra elements preserved" Else Print " FAIL: Extra elements overwritten" Print " [2] "; dstCopy2(2).x; ","; dstCopy2(2).y; " (expected 999,998)" Print " [3] "; dstCopy2(3).x; ","; dstCopy2(3).y; " (expected 888,887)" EndIf ' ============================================ ' TEST 51: Nested structure - basic access ' ============================================ Print "TEST 51: Nested structure - basic access" ' Define inner struct (Point already defined above) ' Define outer struct with nested Point Type Line startPt As Point endPt As Point thickness As INTEGER End Type Dim testLine As Line testLine.startPt.x = 10 testLine.startPt.y = 20 testLine.endPt.x = 100 testLine.endPt.y = 200 testLine.thickness = 3 Dim nestedOk% = 1 If testLine.startPt.x <> 10 Or testLine.startPt.y <> 20 Then nestedOk% = 0 If testLine.endPt.x <> 100 Or testLine.endPt.y <> 200 Then nestedOk% = 0 If testLine.thickness <> 3 Then nestedOk% = 0 If nestedOk% Then Print " PASS: Nested structure access works" Else Print " FAIL: Nested structure access failed" Print " startPt: "; testLine.startPt.x; ","; testLine.startPt.y Print " endPt: "; testLine.endPt.x; ","; testLine.endPt.y Print " thickness: "; testLine.thickness EndIf ' ============================================ ' TEST 52: Nested structure in array ' ============================================ Print "TEST 52: Nested structure in array of structs" Dim lines(2) As Line lines(0).startPt.x = 1 lines(0).startPt.y = 2 lines(0).endPt.x = 3 lines(0).endPt.y = 4 lines(1).startPt.x = 10 lines(1).startPt.y = 20 lines(1).endPt.x = 30 lines(1).endPt.y = 40 Dim arrNestedOk% = 1 If lines(0).startPt.x <> 1 Or lines(0).endPt.y <> 4 Then arrNestedOk% = 0 If lines(1).startPt.x <> 10 Or lines(1).endPt.y <> 40 Then arrNestedOk% = 0 If arrNestedOk% Then Print " PASS: Array of structs with nested access" Else Print " FAIL: Array nested access failed" EndIf ' ============================================ ' TEST 53: Array of nested structure members (Phase 2) ' ============================================ Print "TEST 53: Array of nested structure members" Type DataPoint values(4) As FLOAT End Type Type DataSet points(2) As DataPoint name As STRING End Type Dim mydata As DataSet mydata.name = "Test" mydata.points(0).values(0) = 1.1 mydata.points(0).values(2) = 1.3 mydata.points(1).values(1) = 2.2 mydata.points(2).values(4) = 3.5 Dim phase2Ok% = 1 If mydata.points(0).values(0) <> 1.1 Then phase2Ok% = 0 If mydata.points(0).values(2) <> 1.3 Then phase2Ok% = 0 If mydata.points(1).values(1) <> 2.2 Then phase2Ok% = 0 If mydata.points(2).values(4) <> 3.5 Then phase2Ok% = 0 If phase2Ok% Then Print " PASS: Array of nested structure members" Else Print " FAIL: Array of nested structure members failed" EndIf ' ============================================ ' TEST 54: Arrays of structs with array of nested members ' ============================================ Print "TEST 54: Full nesting: arr(i).member(j).member(k)" Dim mydatasets(1) As DataSet mydatasets(0).name = "Set0" mydatasets(0).points(1).values(3) = 42.5 mydatasets(1).name = "Set1" mydatasets(1).points(2).values(0) = 99.9 Dim fullNestOk% = 1 If mydatasets(0).points(1).values(3) <> 42.5 Then fullNestOk% = 0 If mydatasets(1).points(2).values(0) <> 99.9 Then fullNestOk% = 0 If mydatasets(0).name <> "Set0" Then fullNestOk% = 0 If mydatasets(1).name <> "Set1" Then fullNestOk% = 0 If fullNestOk% Then Print " PASS: Full nesting array(i).array(j).array(k)" Else Print " FAIL: Full nesting failed" EndIf ' ============================================ ' TEST 55: Variables with dots in names (legacy MMBasic feature) ' ============================================ Print "TEST 55: Variables with dots in names (non-struct)" Dim My.Variable% = 42 Dim Another.Dotted.Name! = 3.14159 Dim String.With.Dots$ = "Hello" Dim dotVarOk% = 1 If My.Variable% <> 42 Then dotVarOk% = 0 If Another.Dotted.Name! <> 3.14159 Then dotVarOk% = 0 If String.With.Dots$ <> "Hello" Then dotVarOk% = 0 ' Modify and check My.Variable% = 100 Another.Dotted.Name! = 2.718 String.With.Dots$ = "World" If My.Variable% <> 100 Then dotVarOk% = 0 If Another.Dotted.Name! <> 2.718 Then dotVarOk% = 0 If String.With.Dots$ <> "World" Then dotVarOk% = 0 If dotVarOk% Then Print " PASS: Dotted variable names work correctly" Else Print " FAIL: Dotted variable names broken" EndIf ' ============================================ ' TEST 56: Subroutines with dots in names ' ============================================ Print "TEST 56: Subroutines with dots in names" Dim subTestResult% = 0 My.Test.Sub 10, 20 If subTestResult% = 30 Then Print " PASS: Dotted subroutine names work" Else Print " FAIL: Dotted subroutine call failed" EndIf ' ============================================ ' TEST 57: Functions with dots in names ' ============================================ Print "TEST 57: Functions with dots in names" Dim funResult% = My.Test.Function%(5, 7) If funResult% = 35 Then Print " PASS: Dotted function names work" Else Print " FAIL: Dotted function call failed, got"; funResult% EndIf ' ============================================ ' TEST 58: Mix of dotted variables and struct members ' ============================================ Print "TEST 58: Dotted variables alongside struct members" Dim coord.offset% = 50 Dim pt As Point pt.x = 10 pt.y = 20 Dim mixOk% = 1 ' Use dotted variable and struct in same expression Dim result% = pt.x + coord.offset% If result% <> 60 Then mixOk% = 0 ' Assign from one to other pt.x = coord.offset% If pt.x <> 50 Then mixOk% = 0 coord.offset% = pt.y If coord.offset% <> 20 Then mixOk% = 0 If mixOk% Then Print " PASS: Mixed dotted vars and struct members" Else Print " FAIL: Mixed usage broken" EndIf ' ============================================ ' TEST 59: Arrays with dots in names ' ============================================ Print "TEST 59: Arrays with dots in names" Dim Data.Array%(5) Data.Array%(0) = 100 Data.Array%(3) = 300 Data.Array%(5) = 500 Dim arrDotOk% = 1 If Data.Array%(0) <> 100 Then arrDotOk% = 0 If Data.Array%(3) <> 300 Then arrDotOk% = 0 If Data.Array%(5) <> 500 Then arrDotOk% = 0 If arrDotOk% Then Print " PASS: Dotted array names work" Else Print " FAIL: Dotted array names broken" EndIf ' ============================================ ' TEST 60: STRUCT(SIZEOF) - basic types ' ============================================ Print "TEST 60: STRUCT(SIZEOF) - basic types" ' Point has 2 x INTEGER (8 bytes each) = 16 bytes Dim sizePoint% = Struct(SIZEOF, "Point") If sizePoint% = 16 Then Print " PASS: SIZEOF Point = "; sizePoint%; " bytes" Else Print " FAIL: Expected 16, got "; sizePoint% EndIf ' ============================================ ' TEST 61: STRUCT(SIZEOF) - with string ' ============================================ Print "TEST 61: STRUCT(SIZEOF) - with string" ' Person has: age(8) + height(8) + name(256) = 272 bytes Dim sizePerson% = Struct(SIZEOF, "Person") If sizePerson% = 272 Then Print " PASS: SIZEOF Person = "; sizePerson%; " bytes" Else Print " FAIL: Expected 272, got "; sizePerson% EndIf ' ============================================ ' TEST 62: STRUCT(SIZEOF) - case insensitive ' ============================================ Print "TEST 62: STRUCT(SIZEOF) - case insensitive" Dim sizeLower% = Struct(SIZEOF, "point") Dim sizeUpper% = Struct(SIZEOF, "POINT") Dim sizeMixed% = Struct(SIZEOF, "PoInT") If sizeLower% = 16 And sizeUpper% = 16 And sizeMixed% = 16 Then Print " PASS: SIZEOF case insensitive" Else Print " FAIL: Case sensitivity issue" EndIf ' ============================================ ' TEST 63: STRUCT(SIZEOF) - with variable typename ' ============================================ Print "TEST 63: STRUCT(SIZEOF) - with variable typename" Dim typename$ = "Point" Dim sizeVar% = Struct(SIZEOF, typename$) If sizeVar% = 16 Then Print " PASS: SIZEOF with variable typename" Else Print " FAIL: Expected 16, got "; sizeVar% EndIf ' ============================================ ' TEST 64: STRUCT SAVE/LOAD individual element ' ============================================ Print "TEST 64: STRUCT SAVE/LOAD individual element" Dim elemArr(4) As Point elemArr(0).x = 10 : elemArr(0).y = 11 elemArr(1).x = 20 : elemArr(1).y = 21 elemArr(2).x = 30 : elemArr(2).y = 31 elemArr(3).x = 40 : elemArr(3).y = 41 elemArr(4).x = 50 : elemArr(4).y = 51 ' Save only element 2 Open "elem_test.dat" For Output As #1 Struct Save #1, elemArr(2) Close #1 ' Load into a different element elemArr(4).x = 0 : elemArr(4).y = 0 Open "elem_test.dat" For Input As #1 Struct Load #1, elemArr(4) Close #1 If elemArr(4).x = 30 And elemArr(4).y = 31 Then Print " PASS: Save/Load individual element" Else Print " FAIL: Expected 30,31 got "; elemArr(4).x; ","; elemArr(4).y EndIf Kill "elem_test.dat" ' ============================================ ' TEST 65: STRUCT SAVE/LOAD multiple individual elements ' ============================================ Print "TEST 65: STRUCT SAVE/LOAD multiple elements sequentially" ' Save elements 0, 2, 4 to file Open "multi_elem.dat" For Output As #1 Struct Save #1, elemArr(0) Struct Save #1, elemArr(2) Struct Save #1, elemArr(4) Close #1 ' Create new array and load back Dim loadArr(2) As Point Open "multi_elem.dat" For Input As #1 Struct Load #1, loadArr(0) Struct Load #1, loadArr(1) Struct Load #1, loadArr(2) Close #1 Dim multiOk% = 1 If loadArr(0).x <> 10 Or loadArr(0).y <> 11 Then multiOk% = 0 If loadArr(1).x <> 30 Or loadArr(1).y <> 31 Then multiOk% = 0 If loadArr(2).x <> 30 Or loadArr(2).y <> 31 Then multiOk% = 0 If multiOk% Then Print " PASS: Multiple sequential element save/load" Else Print " FAIL: Data mismatch" Print " [0] "; loadArr(0).x; ","; loadArr(0).y Print " [1] "; loadArr(1).x; ","; loadArr(1).y Print " [2] "; loadArr(2).x; ","; loadArr(2).y EndIf Kill "multi_elem.dat" ' ============================================ ' TEST 66: STRUCT SAVE/LOAD single struct to array element ' ============================================ Print "TEST 66: STRUCT SAVE single struct, LOAD to array element" Dim singlePt As Point singlePt.x = 999 singlePt.y = 888 Open "single_to_arr.dat" For Output As #1 Struct Save #1, singlePt Close #1 Dim targetArr(3) As Point Open "single_to_arr.dat" For Input As #1 Struct Load #1, targetArr(2) Close #1 If targetArr(2).x = 999 And targetArr(2).y = 888 Then Print " PASS: Single struct to array element" Else Print " FAIL: Expected 999,888 got "; targetArr(2).x; ","; targetArr(2).y EndIf Kill "single_to_arr.dat" ' ============================================ ' TEST 67: STRUCT SAVE array element, LOAD to single struct ' ============================================ Print "TEST 67: STRUCT SAVE array element, LOAD to single struct" Open "arr_to_single.dat" For Output As #1 Struct Save #1, elemArr(1) Close #1 Dim loadSingle As Point Open "arr_to_single.dat" For Input As #1 Struct Load #1, loadSingle Close #1 If loadSingle.x = 20 And loadSingle.y = 21 Then Print " PASS: Array element to single struct" Else Print " FAIL: Expected 20,21 got "; loadSingle.x; ","; loadSingle.y EndIf Kill "arr_to_single.dat" ' ============================================ ' TEST 68: STRUCT(SIZEOF) for memory calculation ' ============================================ Print "TEST 68: STRUCT(SIZEOF) for memory calculation" ' Calculate expected file size for array Dim arrSize% = 5 ' 0 to 4 = 5 elements Dim expectedBytes% = (arrSize%) * Struct(SIZEOF, "Point") ' Save array and check file size Open "size_test.dat" For Output As #1 Struct Save #1, elemArr() Close #1 ' Verify we can read it back correctly (confirms size is right) Dim verifyArr(4) As Point Open "size_test.dat" For Input As #1 Struct Load #1, verifyArr() Close #1 Dim sizeOk% = 1 For i% = 0 To 4 If verifyArr(i%).x <> elemArr(i%).x Or verifyArr(i%).y <> elemArr(i%).y Then sizeOk% = 0 EndIf Next i% If sizeOk% Then Print " PASS: Array of "; arrSize%; " elements = "; expectedBytes%; " bytes" Else Print " FAIL: Array save/load size mismatch" EndIf Kill "size_test.dat" ' ============================================ ' TEST 69: Direct struct assignment (single variables) ' ============================================ Print "TEST 69: Direct struct assignment (single variables)" Dim assignSrc As Point Dim assignDst As Point assignSrc.x = 111 assignSrc.y = 222 assignDst = assignSrc If assignDst.x = 111 And assignDst.y = 222 Then Print " PASS: Direct struct assignment" Else Print " FAIL: Expected 111,222 got "; assignDst.x; ","; assignDst.y EndIf ' ============================================ ' TEST 70: Direct struct assignment (array elements) ' ============================================ Print "TEST 70: Direct struct assignment (array elements)" Dim assignArr(5) As Point assignArr(0).x = 10 : assignArr(0).y = 20 assignArr(1).x = 30 : assignArr(1).y = 40 assignArr(3) = assignArr(0) assignArr(4) = assignArr(1) Dim arrAssignOk% = 1 If assignArr(3).x <> 10 Or assignArr(3).y <> 20 Then arrAssignOk% = 0 If assignArr(4).x <> 30 Or assignArr(4).y <> 40 Then arrAssignOk% = 0 If arrAssignOk% Then Print " PASS: Direct array element assignment" Else Print " FAIL: Array element assignment failed" EndIf ' ============================================ ' TEST 71: Direct assignment between different arrays ' ============================================ Print "TEST 71: Direct assignment between different arrays" Dim srcArr2(3) As Point Dim dstArr2(3) As Point srcArr2(1).x = 500 : srcArr2(1).y = 600 dstArr2(2) = srcArr2(1) If dstArr2(2).x = 500 And dstArr2(2).y = 600 Then Print " PASS: Cross-array element assignment" Else Print " FAIL: Expected 500,600 got "; dstArr2(2).x; ","; dstArr2(2).y EndIf ' ============================================ ' TEST 72: Direct assignment with mixed types struct ' ============================================ Print "TEST 72: Direct assignment with mixed types struct" Dim persSrc As Person Dim persDst As Person persSrc.name = "TestPerson" persSrc.age = 42 persSrc.height = 1.85 persDst = persSrc Dim persOk% = 1 If persDst.name <> "TestPerson" Then persOk% = 0 If persDst.age <> 42 Then persOk% = 0 If Abs(persDst.height - 1.85) >= 0.01 Then persOk% = 0 If persOk% Then Print " PASS: Mixed type struct assignment" Else Print " FAIL: Mixed type struct assignment failed" EndIf ' ============================================ ' TEST 73: Direct assignment from function return ' ============================================ Print "TEST 73: Direct assignment from function return" Dim funcResult As Point funcResult = MakePoint(777, 888) If funcResult.x = 777 And funcResult.y = 888 Then Print " PASS: Assignment from function return" Else Print " FAIL: Expected 777,888 got "; funcResult.x; ","; funcResult.y EndIf ' ============================================ ' TEST 74: Chained assignment (a = b, then c = a) ' ============================================ Print "TEST 74: Chained assignment" Dim chainA As Point, chainB As Point, chainC As Point chainA.x = 1000 : chainA.y = 2000 chainB = chainA chainC = chainB If chainC.x = 1000 And chainC.y = 2000 Then Print " PASS: Chained struct assignment" Else Print " FAIL: Expected 1000,2000 got "; chainC.x; ","; chainC.y EndIf ' ============================================ ' Summary ' ============================================ Print "=== All Tests Complete ===" Print "Review output above for any FAIL messages" End ' ============================================ ' Function definitions (must be after END) ' ============================================ Function MakePoint(xval%, yval%) As Point MakePoint.x = xval% MakePoint.y = yval% End Function Function MakePerson(n$, a%, h!) As Person MakePerson.age = a% MakePerson.height = h! MakePerson.name = n$ End Function Function MakeWithArray(id%, v0%, v1%, v2%, v3%) As WithArray MakeWithArray.id = id% MakeWithArray.values(0) = v0% MakeWithArray.values(1) = v1% MakeWithArray.values(2) = v2% MakeWithArray.values(3) = v3% End Function ' Subroutine with dots in name (Test 56) Sub My.Test.Sub(a%, b%) subTestResult% = a% + b% End Sub ' Function with dots in name (Test 57) Function My.Test.Function%(x%, y%) My.Test.Function% = x% * y% End Function Edited 2025-12-28 23:24 by matherp |
I've spent some time minimising the memory footprint of the structure code so it now works on the RP2040 as well as the RP2350. All versions attached. The standard PicoMiteRP2040 has been tested and passes all tests as above PicoMiteV6.01.00EXP2.zip |
over my head sir but thankyou. |
Thank you very much for the explanations in the manual regarding the memory requirements of the structs and about padding and alignment! And a huge thank you for taking my suggestion and implementing the "SIZEOF" subfunction! I think it will be very useful! Of course, you can also "calculate it manually" using the explanations about memory allocation, but that's always very error-prone. You might change something in one struct (add a member or change the order or size of string members) and, of course, forget to adjust it, for example, for the factor in 'SEEK #fn, rec%*rec_size'. I've also tested 'PEEK(VARADDR typeArray())' and 'PEEK(VARADDR typeArray(n%))': Wonderful! It works for the entire array as well as for a single array element! Wow! Many RP2040 users will be happy to have the very useful new UDT (Type .. End Type) feature!Thank You, Peter !!! |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10104 |
Mine too. I have ZERO understanding as to what this actually is, or how it would be useful. That's not to say it isn't - Peter would not have spent all that time doing this for nothing - simply that I don't understand what this is all about. If anyone has the time to elaborate as to what this feature does and why it is useful over and above what MMBASIC already does, please do comment here, or link me to another site where I can read about this concept. My ignorance is showing here, I have to say, but I make no apologies for that! ![]() I WOULD like to understand what this is all about though. ![]() Smoke makes things work. When the smoke gets out, it stops! |
Ditto Stanleyella & Grogster ChopperP |
Structures are very useful when you have a number of 'objects' that have the same attributes. If the attributes are all integers or all strings, you can just add another dimension to your array. If you have a mix of strings and numbers, structures are your friend. In MMEdit, each tab has a structured variable holding all sorts of info. Delete a tab and just delete the structured variable instead of a dozen deletes. Add a new tab and just create a new variable with the same structure. In MMCC, The terminal consists a single dimension array of lines. (actually a list but we don't have lists yet?) The structure of a line is a couple of integers and an array of 256 characters. Each character is a structure containing the character, foreground colour, background colour and attributes. So I have a structure inside a structure inside a list (or array). I can delete or move a single character or a whole line or whole screen with one command. VK7JH MMedit |
Structures are a simplified way of organizing data, you don't need to use them but, if you do, it is more convenient and intuitive than the old ways. And generally, these features mean less bugs. For example, assume that you need to track a number of alarms. Each alarm has a number of properties; the time of the alarm, its level (1, 2. 3, etc) and the action taken. To do this using old way you would define three arrays: DIM AlarmTime(nbr) AS FLOAT, AlarmLevel(nbr) AS INTEGER, AlarmAction(nbr) AS STRING Then you would access each array individually, for example: IF AlarmTine(i) < sometime) AND AlarmLevel(i) < somelevel THEN CallSomeSub This is fine and if you are happy with this then there is no need to change. But, using structures enables you to treat the data as a single "thing" rather than a bunch of loosely related arrays. For example: TYPE StructAlarm time AS FLOAT level AS INTEGER action AS STRING END TYPE Then you would define your array of alarms as follows: DIM alarm(nbr) AS StructAlarm And then you could access the properties of each alarm, for example: IF alarm(i).timer < sometime) AND alarm(i).level < somelevel THEN CallSomeSub At this point you are probably thinking that this is more complicated than the old way. BUT consider if you need to pass the alarm to a subroutine. Using the old way you might use: MySub AlarmTime(i), AlarmLevel(i), AlarmAction(i) Using a structure you would do: MySub alarm(i) And what if you need to copy alarms? For example, when swapping elements while sorting an array of alarms: DIM alarm(nbr) AS StructAlarm DIM tmp AS StructAlarm … tmp = alarm(i + 1) alarm((i + 1) = alarm(i) alarm(i) = tmp There are a lot of features in MMBasic that are "new" and "convenient" but you can still use the old ways if you want to. For example, you might want to stick to using line numbers, or GOSUB…RETURN, or not bother with OPTION EXPLICIT, and so on, and that is fine. But the new features will make your code easier to read, easier to follow and as a result, less buggy. Not that I would ever say that your code is buggy Geoff Geoff Graham - http://geoffg.net |
I'm having a hard time running the test program. Mine fails like so: TEST 68: STRUCT(SIZEOF) for memory calculation [1407] STRUCT Load #1, verifyArr() Error : Cannot find VERIFYARR size_test.dat is created, though. I copy/pasted the program into TeraTerm. It dropped the line Dim verrArr(4) as point when I manually added that line back in, everything worked again. Edited 2025-12-29 16:02 by toml_12953 |
Thanks Geoff. :) I was pretty much in the same boat, never having used a Structure in my life. I can see the advantages now. I remember using something similar for Disk BASIC random files on my Tandy Model 1, but it wasn't referred to as Structures at that time and there was less flexibility. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
| karlelch Guru Joined: 30/10/2014 Location: GermanyPosts: 368 |
Hi, there may be something brocken with XMODEM again: (1) In the latest experimental version (PicoMiteRP2350V6.01.00EXP2.uf2), xmodem `receive "miiha.bas"' causes the PicoMite to hang (no response, reset required) (2) In the previous experimental version (PicoMiteRP2350V6.01.00EXP.uf2), the same command seems to finish but ends up with an empty file. In the latest official release (PicoMiteRP2350V6.01.00.uf2), it works. PicoMite MMBasic RP2350B V6.01.00 OPTION FLASH SIZE 16777216 OPTION COLOURCODE ON OPTION PICO OFF OPTION CPUSPEED (KHz) 200000 Best Thomas Footnote added 2025-12-29 18:30 by karlelch P.S.: "xmodem r" works Footnote added 2025-12-29 19:13 by karlelch P.S.: I checked again and found that with PicoMiteRP2350V6.01.00.uf2, the same problem occurs as with PicoMiteRP2350V6.01.00EXP.uf2 - empty file. The respective receive versions (xmodem receive "miiha.bas") work as expected Footnote added 2025-12-29 19:24 by karlelch P.S.: IGNORE - see my message below |
Weren't FIELD statements fun? |
Are the single quotes there for a reason? without the single quotes XMODEM RECEIVE works as expected on the webmiteV6.1.0EXP2 Jim VK7JH MMedit |
The single quotes were just to indicate what's the command I entered ... Hmm, now I am utterly confused. Will explore more. Thanks Jim. Best Thomas |
Hi, I tested XMODEM again - now everything works as expected also with PicoMiteRP2350V6.01.00EXP2.uf2 ... I am not sure what happened before, but in between my first tests and now I did a few nukes and uploaded a few different firmware versions. Self-healing? Sorry for the confusion. Best Thomas |
I need to decide whether to include the struct functionality in the final RP2040 builds.Please could those who still use the rp2040 test out the builds above and check for any oddities or signifiocant performance impact - thanks |
tested PicoMiteRP2040V6.01.00EXP2.uf2 (complex app with heavy GUI usage) WebMiteRP2040V6.01.00EXP2.uf2 (simple app with 18B20 temp sensors) so far no issues found. I would strongly suggest to leave the struct functionality in the RP2040 code as it makes many things easier to code. As far as I could test it, it seems that a TYPEed variable is counted only as one variable no matter how many members the structure has. This has some advantages when using lots of variables and constants ... as I like to do . One has just to apply a litte "object thinking".73 de OE1HGA, Gerald |
G'day, Some simple testing with: PicoMite RP2040 V6.01.00EXP2 PicoMite RP2040 V6.01.00 V6.01.00 Test 1 116.273ms 1000 x bit shifting 4 bytes (written before byte command existed) Test 2 153.439ms 1000 x peeking 4 bytes instead Test 3 892.041ms 200 x drawing moving triangles across the LCD V6.01.00EXP2 Test 1 124.041ms Test 2 161.4ms Test 3 896.288ms Shows a slight reduction in speed (approx 5%) with EXP2 with general accessing registers etc and no real difference with LCD usage (ILI9488) More testing to follow but I can see the advantages outweighing the slight speed penalty. As a side note, being able to play around with structures in MMBasic has finally allowed me to get a grip on the whole idea, now CircuitPython is starting to make sense at last, they use structures all over and its been the cause of a monumental amount of swearing whilst trying to get my head around them Thanks to Peter for the xmas present and Geoff for the explanation. Thankyou both for MMbasic and the Mites. Regards, Lyle. |
I looked up srtuctured coding/basic and the bbc basic I installed on rpi 400 has opengl and structures. Don't personally see the point but that's cos I don't know enough to say out. |
I can get my head around "structured" basic ie simple flow with subs, no goto, but not structures. functions never used. I can't see any of this is would make any code I wrote better if I used structures. I use option explicit and declare var types as. I'm willing to learn though. |
| Page 1 of 7 |
