Local Time 04:23 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pico Radar
     Page 1 of 8
PhenixRising
Posted: 06:54am 14 Nov 2025
For tracking humans
Posted: 07:48am 14 Nov 2025
Nice
stanleyella
Posted: 06:24pm 14 Nov 2025
what they think of next?
PhenixRising
Posted: 09:19pm 14 Nov 2025
Data Structure and Meaning for RD-03D Radar Module
The data received from the RD-03D radar module consists of a series of bytes that represent different attributes of detected targets. Here’s a breakdown of the typical data structure to help you understand what each byte represents.
Data Frame Structure
A typical data frame from the RD-03D contains several fields that provide information about detected objects. Below is a common structure:
Header (2 bytes): Identifies the start of the data frame.
Length (1 byte): Specifies the total length of the data packet.
Target Count (1 byte): Indicates how many targets are detected.
Targets Data (n * [Data Fields]): Contains information about each detected target.
Checksum (1 byte): Used for data integrity verification.
Example Data Frame Breakdown
Here’s a conceptual example for parsing a data frame:
plaintext
Copy Code
0xFD 0xFC | Length | Target Count | Target 1 Data | Target 2 Data | ... | Checksum
Target Data Fields
Each target's data typically includes the following details:
Distance (2 bytes):
Represents the distance to the target in centimeters.
A value of 0x0001 corresponds to 1 cm.
Speed (2 bytes):
The speed of the target in centimeters per second (cm/s).
A positive value indicates approach, while a negative value indicates retreat.
Angle (2 bytes):
Angle relative to the radar in degrees multiplied by a scaling factor (e.g., 0.1).
For example, a value of 0x01F4 would represent 31.4 degrees.
Width (2 bytes):
Target's physical width in centimeters.
Height (2 bytes):
Target's physical height in centimeters.
Example of Parsed Data
Assuming you receive the following sample data frame:
plaintext
Copy Code
0xFD 0xFC | 0x06 | 0x02 | 0x00 | 0x64 | 0x00 | 0x1E | 0x00 | 0x0A | 0x00 | 0x0C | 0xB4
Interpretation:
Header: 0xFD 0xFC
Length: 0x06 bytes
Target Count: 0x02 (two targets detected)
Target 1:
Distance: 0x0064 (100 cm)
Speed: 0x0001E (30 cm/s)
Angle: 0x000A (1.0 degrees)
Width: 0x000C (12 cm)
Height: 0x00B4 (180 cm)
Checksum: Validates data integrity.
Only £7 on Amazon
PhenixRising
Posted: 09:28pm 14 Nov 2025
Paintball marker on rotary table. Servo for elevation. Solenoid for trigger.
Wonder if I can get access to Backshed from jail?
PhenixRising
Posted: 09:52pm 14 Nov 2025
Those guys: "We have created a library"
WTF! How are people supposed to learn when everything is pre-packaged.
This is another reason why MMBasic should be the standard for education.
Posted: 11:42am 15 Nov 2025
  PhenixRising said  Those guys: "We have created a library"
Those who want to learn will read the code.
Those who just want to use the device will likely use the library and have no wish to spend time reading its implementing code.
Overall, so much better than closed source.
David
Posted: 01:54pm 15 Nov 2025
You raise a good point about learning. I recently said to an associate that I liked mmbasic because it was easy to learn (actually a lot of 80’s recall) and that I just could not get my head around C++ and understand it’s different way of programming, hence why I parked my Arduino and R Pi and jumped at the CMM2.  “Not a problem” says he “just use ChatGPT to write your code”. So who needs to learn anything now, just ask AI and use pre made libraries.
I agree with your “WTF!”
***  VK5DLZ  ***
v.lenzer
Posted: 04:03pm 15 Nov 2025
If everybody it learning one day from AI, from whom will AI be learning? ;)
A pretty good project!
Edited 2025-11-16 02:04 by v.lenzer
Best wishes! Joachim
Wolfgang
Posted: 05:29pm 15 Nov 2025
I am very interested in that detailed MMbasic-Code, because I wish to modfify it only for monitoring of a single person.
Greets Wolfgang
Edited 2025-11-16 03:30 by Wolfgang
ville56
Posted: 08:39pm 15 Nov 2025
Wolfgang,
attached you can find some basic code I've written for a LD2450LD radar module which should be the same as the module mentioned in this thread.
The code is not optimized for runtime or stability but for readability and simplicity. I could not find any datasheet for the RD-03D module describing the serial protocol but some blog entries which did use the same record layout as I do. So I assume they are identical, at least they do look identically.
The program assumes only one target and uses the factory default settings.
LD2450LD.zip
Gerald
73 de OE1HGA, Gerald
Andrew_G
Posted: 10:32pm 15 Nov 2025
G'day all,
Au$17.25 is pretty amazing. Will it detect/differentiate cats?
(the neighbour has seven!)
  Quote  High pressure hose on rotary table. Servo for elevation. Solenoid for trigger.
Cheers,
Andrew
Edited 2025-11-16 17:49 by Andrew_G
Wolfgang
Posted: 10:07am 16 Nov 2025
@ville56
Thank you very much for this Pico programme. It is very impressive for me and thank you for your efforts in creating it. I can take a lot from it. The comments will help me to put the LD2450 into operation.
I have this version:
ville56
Posted: 12:02pm 16 Nov 2025
Wolfgang,
the radar on the photo is not a RD-03D or an requivalent  like my device as mentioned in the thread. So this uses a different protocol. Have to look it up, but the principle should be the same. Have you more Information about the type of your radar so I can make modification to the code accordingly?
Wolfgang
Posted: 02:37pm 16 Nov 2025
@ville56
I found the Serial Protocol pdf again as a *.pdf file here. I didn't want to post my pdf here because of its length. I hope the link is still valid.
https://naylampmechatronics.com/img/cms/001080/Protocolo_comunicacion_serial_LD2410C.pdf
Thank you in advance for your effort and support. I really appreciate it.
Greets Wolfgang
ville56
Posted: 03:54pm 16 Nov 2025
Wolfgang,
the link works. The LD2410C is a different class of device, the protocol is a bit more complex and the documentation is as bad as it can be ... partially unclear and inconsistent. So I had to order one to dissect the protocol on a live part. Should arrive here end of next week.
For the beginning, the serial interface should run on 256000 Bd, a default frame should be 23 bytes long if I'm not wrong, and the header should be F4 F3 F2 F1. The rest of the data sent is, for me, more or less understandably described in the manual. But I didn't read every detail ...
The biggest difference to the LD2540 seems to be that there is is no coordinate information available from the LD2410 but distance only. Anyway, will have some experiments as soon as the part is here ... and I will tell you what I found out
Frank N. Furter
Posted: 07:23pm 16 Nov 2025
I think it's an HLK-LD2420 that I have here. Does it use the same protocol? Actually, I only need one switch output—but that's exactly what this module isn't supposed to do...
Frank
Posted: 07:52pm 16 Nov 2025
I think that the manual for the LD2450 is the closest match to the RD-03D
LD2450_Serial_Communication_Protocol_V1.02_EN.pdf
This may also be of some use
rd-03d_multi-target_trajectory_tracking_user_manual.pdf
A Google search for both will find them.
It will be 2 weeks before I can test one.
v.lenzer
Posted: 06:43pm 17 Nov 2025
I just ordered both the LD2410C and the LD2450 from AliExpress. I'd like to contribute to the project with my RP2040. Perhaps it would be possible to display the object graphically on an ILI9341 display.
ville56
Posted: 06:14pm 18 Nov 2025
Its running here with LD2450 on an ILI9488 display for one target. Should do on any LCD-display, even HDMI or VGA. The update rate is limited by the rate the sensor delivers data and this is 10/second and seems to be fixed. Could easily be extendend to track up to 3 objects. I have implemented the basic routines to deal with the sensor (sending commands and receiving ack and data messages) and the full control should be easy to implement, depending on what you want to do.
Gerald
     Page 1 of 8
