Local Time 05:11 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : One for the PIO gurus
Posted: 07:11pm 01 Nov 2025
Can anyone help diagnose this?
This code is supposed to create a bitclock, a HSYNC pulse and a VSYNC pulse with VGA timings. It is development in preparation for trying to drive an RGB TFT display which needs a bitclock.
The bitclock runs at 25.1MHz
The HSYNC runs at 31.5 MHz with a 3.8uS sync
The VSYNC runs at 60Hz with a 63.5uS sync
http://www.tinyvga.com/vga-timing/640x480@60Hz
All this works fine except that when you trigger on VSYNC you will see that HSYNC is drifting relative to it whereas given that they should both be triggered nearly simultaneously by the separate irqs.
The problem looks like the hysnc timing is overunning (or visa versa) but I can't see the problem, fiddling with the underrun fudge factor on the vsync numbers changes the drift but it should be locked and the fudge factor of 1000 clocks should not be critical
I've been looking at this too long to see the wood for the trees. Help appreciated.
Option explicit
Option default integer
Dim p1,f1,e1,s1,o1,p2,f2,e2,s2,o2,p3,f3,e3,s3,o3
' set pins that will be used as outputs
SetPin gp4,pio1
SetPin gp16,pio1
SetPin gp17,pio1
o1=Pio(next line 1) 'note the start of the first PIO instruction for program 1 - will be 0
Print "compiling pclk"
PIO assemble 1
.program pclk
.side set 1
.line next 'we can always use next unless we specifically want to place the code
   Pull block 'read in the loop counter which will define the timing of the second program
.wrap target
   Mov x,osr side 1 [4] 'we can use osr to keep this and re-use it
.label loop 'loop as specified by the counter
   Nop side 0 [4]
   Jmp x--,loop side 1 [4]
   IRQ 0 side 0 [3] 'set a flag for the second program
   IRQ 4 side 0  'set a flag for the third program
.wrap
.end program list
' create the setting to initialise program 1
p1=Pio(pinctrl 1,,,,gp4)
f1=252000000
e1=Pio(execctrl GP0,Pio(.wrap target),Pio(.wrap))
s1=Pio(shiftctrl 0,0,0,0,0,0)
o2=Pio(next line) 'note the start of the second pio program
Print "compiling hsync @ line: ";o2
PIO assemble 1
 .program hsync
 .side set 1
 .line next 'this will pick up o2 automatically
   Pull block side 1 'get the length of the front port
   Mov y,osr side 1 'store the length of front porch in y
   Pull block side 1 'get the length of the sync pulse into osr
 .wrap target
   Mov x,osr side 1 'get the length of the synch
   Wait 1 irq 4 side 1 'this instruction waits for irq 4 to be set and automatically clears it
   ' this happens at the start of each line
.label loop1
   Jmp x--,loop1 side 0
   Mov x,y side 1 'restore the front porch value
.label loop2
   Jmp x--,loop2 side 1
   Nop side 1
'we will trigger the data transfer here
 .wrap
.end program list
' create the setting to initialise program 2
p2=Pio(pinctrl 1,,,,gp16)
f2=252000000
e2=Pio(execctrl GP0,Pio(.wrap target),Pio(.wrap))
s2=Pio(shiftctrl 0,0,0,0,0,0)
o3=Pio(next line) 'note the start of the second pio program
Print "compiling vsync @ line: ";o3
PIO assemble 1
 .program vsync
 .side set 1
 .line next 'this will pick up o3 automatically
   Pull block side 1
   Mov y,osr side 1 'store the length of the front porch in y
   Pull block side 1
   Mov isr,osr side 1 'store the length of the rest of the line in isr
   Pull block side 1 'get the synch length
 .wrap target
   Mov x,osr side 1 'get the synch length
   Wait 1 irq 0 side 1 'this instruction waits a line end which we use to be beginning of frame
.label loop3
   Jmp x--,loop3 side 0 'synch loop
   Mov x,y side 0
.label loop4
   Jmp x--,loop4 side 1 'front porch loop
   Mov x,isr side 1
.label loop5
   Jmp x--,loop5 side 1 'rest of line loop
 .wrap
.end program list
' create the setting to initialise program 3
p3=Pio(pinctrl 1,,,,gp17)
f3=252000000
e3=Pio(execctrl GP0,Pio(.wrap target),Pio(.wrap))
s3=Pio(shiftctrl 0,0,0,0,0,0)
' initialise and start program 1 but note it will block on pull block
PIO init machine 1,0,f1,p1,e1,s1,o1,1,0,0
PIO start 1,0
' initialise and start program 2, it will block waiting for the irq
PIO init machine 1,1,f2,p2,e2,s2,o2,1,0,0
PIO start 1,1
PIO write 1,1,2,48*10-2,96*10-2
' initialise and start program 3, it will block waiting for the irq
PIO init machine 1,2,f3,p3,e3,s3,o3,1,0,0
PIO start 1,2
'rest of line value is reduced to make sure no overun but also don't miss a line
PIO write 1,2,3,8000*33-1,8000*490-1000,8000*2-1
' trigger the whole shebang by writing to program 1 fifo
PIO write 1,0,1,800
' loop, although the PIO will keep running anyway even if the program finishes
Edited 2025-11-02 05:15 by matherp
darthvader
Posted: 10:30pm 01 Nov 2025
Hi Peter ,
Last time i get problems with VGA , it was the front and back porch that was not as expected.
I'm not a PIO programmer , so , check this if it can help , who knows
Cheers.
Posted: 08:18am 02 Nov 2025
Solved. Had to clear the accumulated irq before waiting for it in the VSYNC loop. Next step to try and get data in and out
Posted: 11:17am 02 Nov 2025
If anyone is interested. Here is the fixed version. I found a couple of commands that weren't implemented in the PIO assemble IRQ NEXT and IRQ PREV. These allow a state machine on one PIO to communicate with a state machine on another PIO. I need these as I have run out of commands on PIO 1 so the data output will have to be on PIO 2. These will be in RC10. I'm using IRQ 3 to tell the data output that it can start a new line and IRQ 4 to synchronise the start of frame.
You can run the program as-is on a standard PicoMite and if you connect PIN 17 to VSYNC on a VGA monitor and pin 16 to Hsync you will find the monitor locks up happily at 640x480 @ 60Hz. The 25.2MHz pixel clock is on GP4.
Option explicit
Dim o
SetPin gp4,pio1
SetPin gp16,pio1
SetPin gp17,pio1
Const cyclesperpixel=10
Const hwholeline=800
Const hvisible=640*cyclesperpixel
Const hsync=96*cyclesperpixel
Const hfrontporch=16*cyclesperpixel
Const hbackporch=48*cyclesperpixel
Const vwholeframe=525*hwholeline*cyclesperpixel
Const vvisible=480*hwholeline*cyclesperpixel
Const vsync=2*hwholeline*cyclesperpixel
Const vfrontporch=10*hwholeline*cyclesperpixel
Const vbackporch=33*hwholeline*cyclesperpixel
Const clock=Val(MM.Info(cpuspeed))
o=Pio(next line 1) 'note the start of the first PIO instruction for program 1 - will be 0
PIO assemble 1
.program pclk
.side set 1
.wrap target
   Nop side 0 [4]
   IRQ 0 side 0  'set a flag for the second program
   IRQ 1 side 0 [3] 'set a flag for the third program
.wrap
.end program list
'PIO CONFIGURE pio, sm,clock [,startaddress][,sidesetbase] [,sidesetno][,sidesetout][,setbase] [,setno] [,setout]
'[,outbase] [,outno] [,outout][,inbase][,jmppin] [,wraptarget] [,wrap][,sideenable] [,sidepindir][,pushthreshold]
'[,pullthreshold] [,autopush][,autopull] [,inshiftdir][,outshiftdir][,joinrxfifo] [,jointxfifo][,joinrxfifoget] [,joinrxfifoput]
PIO CONFIGURE 1,0,clock,o,gp4,1,1,,,,,,,,,Pio(.wrap target),Pio(.wrap)
'PIO init machine 1,0,f1,p1,e1,s1,o1,1,0,0
o=Pio(next line) 'note the start of the second pio program
PIO assemble 1
 .program hsync
 .side set 1
   Mov y,osr side 1 'save the length of the sync pulse into y
   Pull block side 1' get the length of the visible data + front porch in osr
 .wrap target
   Mov x,osr side 1 'get the length of the active+frontporch
   Wait 1 irq 1 side 1 'this instruction waits for irq 1 to be set by the pixel clock and automatically clears it
   IRQ NEXT 3 side 1
.label loop1
   Jmp x--,loop1 side 1
   Mov x,y side 1 'restore the sync value
.label loop2
   Jmp x--,loop2 side 0
   Nop side 1
'we don't need to consider the back porch as we don't trigger again until the start of a new line
 .wrap
.end program list
PIO CONFIGURE 1,1,clock,o,gp16,1,1,,,,,,,,,Pio(.wrap target),Pio(.wrap)
PIO assemble 1
 .program vsync
 .side set 1
   Pull block side 1
   Mov y,osr side 1 'store the length of the back porch in y
   Pull block side 1
   Mov isr,osr side 1 'store the length of sync in isr
 .wrap target
   Mov x,osr side 1 'get the length of the active + front porch
   Wait 1 irq 0 side 1 [1]'this instruction waits a line end which we use to be beginning of frame
   IRQ NEXT 4 side 1
.label loop3
   Jmp x--,loop3 side 1 'main data loop
   Mov x,isr side 1 'restore the sync value
.label loop4
   Jmp x--,loop4 side 0 'sync loop
   Mov x,y side 0
.label loop5
   IRQ CLEAR 0 side 1
 .wrap
.end program list
PIO CONFIGURE 1,2,clock,o,gp17,1,1,,,,,,,,,Pio(.wrap target),Pio(.wrap)
PIO start 1,0
PIO start 1,1
PIO write 1,1,2,hsync,hvisible+hfrontporch-2
PIO start 1,2
PIO write 1,2,3,vbackporch-2,vsync,vvisible+vfrontporch-2
PIO write 1,0,1,hwholeline
PhenixRising
Posted: 04:43pm 02 Nov 2025
  Quote  These allow a state machine on one PIO to communicate with a state machine on another PIO
So, for example, The count value of a quad decoder on PIO0 can be shared with the other PIOs?
Posted: 05:04pm 02 Nov 2025
No: you just have 8 flags that can be shared
Posted: 06:20pm 02 Nov 2025
Here is the final program - VGA running from the standard PicoMite firmware. You will have to wait for RC10 to try it. With RC10 you can load the standard non-VGA firmware onto a Pico RP2350 installed on a VGA board with the usual RGB121 connections. Set the CPU speed to 252MHz then load and run the attached and you will get a very simple 640x480 demo entirely coded in MMbasic. It won't run on an RP2040 as there isn't enough memory for the framebuffer.
Option explicit
Dim o
SetPin gp4,pio0 'clock pulse
SetPin gp16,pio0 'hsync
SetPin gp17,pio0 'vsync
SetPin gp7,pio1 'DE
SetPin gp18,pio1 'Blue
SetPin gp19,pio1 'low green
SetPin gp20,pio1 'high green
SetPin gp21,pio1 'Red
const hsync=96
const hfrontporch=16
Const hvisible=640
Const hbackporch=48
const vsync=2
const vbackporch=33
const vfrontporch=10
Const vvisible=480
const pixelsperinteger=16
const pixelsperword=8
const wordstotranster=hvisible*vvisible\pixelsperword
Const vlines=vsync+vbackporch+vvisible+vfrontporch
Const hwholeline=hsync+hfrontporch+hvisible+hbackporch
Const hvisibleclock=hvisible*cyclesperpixel
Const hsyncclock=hsync*cyclesperpixel
Const hfrontporchclock=hfrontporch*cyclesperpixel
Const hbackporchclock=hbackporch*cyclesperpixel
Const vwholeframe=vlines*hwholeline*cyclesperpixel
Const vvisibleclock=vvisible*hwholeline*cyclesperpixel
Const vsyncclock=vsync*hwholeline*cyclesperpixel
Const vfrontporchclock=vfrontporch*hwholeline*cyclesperpixel
Const vbackporchclock=vbackporch*hwholeline*cyclesperpixel
Dim i,b(hvisible*vvisible\pixelsperinteger-1)
Dim badd=Peek(varaddr b())
PIO assemble 0
.program pclk
.side set 1
.wrap target
  Nop side 0 [4]
  IRQ PREV 2 side 0
  IRQ 1 side 0 [2]  'set a flag for the third program
.wrap
.end program list
PIO CONFIGURE 0,0,clock,o,gp4,1,1,,,,,,,,,Pio(.wrap target),Pio(.wrap)
Print "compiling hsyncclock @ line: ";o
PIO assemble 0
.program hsyncclock
.side set 1
.wrap target
.label loop1
.label loop2
  Nop side 1
.wrap
.end program list
PIO CONFIGURE 0,1,clock,o,gp16,1,1,,,,,,,,,Pio(.wrap target),Pio(.wrap)
Print "compiling vsyncclock @ line: ";o
PIO assemble 0
.program vsyncclock
.side set 1
  Pull block side 1
  Pull block side 1
.wrap target
  IRQ PREV 3 side 1
.label loop3
.label loop4
  Mov x,y side 0
.label loop5
  IRQ CLEAR 0 side 1
.wrap
.end program list
PIO CONFIGURE 0,2,clock,o,gp17,1,1,,,,,,,,,Pio(.wrap target),Pio(.wrap)
o=Pio(next line 0) 'note the start of the first PIO instruction for program 1 - will be 0
Print "compiling datamaster @ line: ";0
PIO assemble 1
.program datamaster
.line 0
Pull block side 0
Mov y,osr 'store the count of active lines
.wrap target 'main loop
Mov x,y 'get the active line count
Wait 1 irq next 3'wait for the start of frame
.label loop6
Wait 1 irq next 2 'wait for the next line to start
IRQ  5 'trigger the output
Jmp x--,loop6
.wrap
.end program list
PIO CONFIGURE 1,0,clock,o,,,,,,,,,,,,Pio(.wrap target),Pio(.wrap)
o= Pio(next line)
Print "compiling data @ line: ";o
PIO assemble 1
.program linedata
.line next
.side set 1
Pull block side 0
Mov y,osr side 0 'store active pixel count divided by the number of pixels per word
.wrap target
Mov x,y side 0'get the active pixel count divided by the number of pixels per word
Wait 1 irq 5 side 0 [9]'wait for next valid line to start
.label loop7
Pull side 1 'get the next data - don't block
Out pins,4 side 1 [9]
Jmp x--,loop7 side 1
Set pins, 0 side 0 [2]
.wrap
.end program list
PIO CONFIGURE 1,1,clock,o,GP7,1,1,GP18,4,1,GP18,4,1,,,Pio(.wrap target),Pio(.wrap)
PIO SYNC 'this is a new command that syncs the clocks of the PIO. It is needed for IRQ to work between PIO
PIO start 1,0
PIO write 1,0,1,vvisible-1
PIO start 1,1
PIO write 1,1,1,hvisible/pixelsperword-1
PIO start 0,0
PIO start 0,1
PIO write 0,1,2,hsyncclock-1,hvisibleclock+hfrontporchclock-1
PIO start 0,2
PIO write 0,2,3,vbackporchclock-1,vsyncclock-1,vvisibleclock+vfrontporchclock-1
PIO dma tx 1,1,wordstotranster,b(),redo
PIO write 0,0,1,hwholeline
PIO sync
mycls 1
Pause 1000
mycls 8
Pause 1000
rectangle 100,100,199,199,&H6
rectangle 0,0,hvisible-1,0,&HF
rectangle 0,vvisible-1,hvisible-1,vvisible-1,&HF
rectangle 0,0,0,vvisible-1,&HF
rectangle hvisible-1,0,hvisible-1,vvisible-1,&HF
Pause 1000
Sub redo
Sub mycls col
Local c=col
c=c+(c<<4)
c=c+(c<<8)
c=c+(c<<16)
Memory set word badd,c,wordstotranster
Sub rectangle x1,y1,x2,y2,c
Local x,y,x1p,x2p,p,q,t,bc=(c<<4) +c
  For y=y1 To y2
      x1p = x1
      x2p = x2
      p = badd + y * (hvisible >> 1) + (x1 >> 1)
      If x1 Mod 2 Then
           t=(PEEK(BYTE p) And &HF) + (c<<4)
           Poke byte p,t
           Inc p
           Inc x1p
      EndIf
      If (x2 Mod 2) = 0 Then
          q = badd + y * (hvisible >> 1) + (x2 >> 1)
          t=(PEEK(BYTE q) And &Hf0) + c
          Poke byte q,t
          Inc x2p,-1
      EndIf
      If x2p>x1p Then Memory set byte p,bc,(x2p-x1p+1)/2
    Next
Edited 2025-11-03 22:08 by matherp
Posted: 10:45pm 03 Nov 2025
Now working in RGB222 @ 640x480
Is this the next VGA variant?
Option explicit
Dim o
SetPin gp7,pio1 'DE
SetPin gp18,pio1 'low Blue
SetPin gp19,pio1 'high blue
SetPin gp20,pio1 'low green
SetPin gp21,pio1 'high green
SetPin gp22,pio1 'low red
SetPin gp23,pio1 'high red
Const hsync=96
Const hvisible=640
Const hbackporch=48
Const vsync=2
Const vbackporch=33
Const vvisible=480
Const pixelsperword=5
Const wordsperline=hvisible\pixelsperword
Const wordstotransfer=wordsperline*vvisible
Const HRes=hvisible
Const VRes=vvisible
Dim i,b(wordstotransfer\2-1)
Dim mask_table(4)=(&H3F,&HFC0,&H3F000,&HFC0000,&H3F000000)
Dim currentfont=MM.Info(font)
Dim fontadd=MM.Info(font address currentfont)
Dim fontdetail=Peek(word fontadd)
Dim fontbytes=(fontdetail And &HFF) * ((fontdetail>>8) And &HFF)/8
Dim asciioffset=((fontdetail>>16) And &HFF)
Inc fontadd,4 'pont to the actual characters
PIO assemble 0
.program pclk
.side set 1
.wrap target
  Nop side 0 [4]
  IRQ PREV 2 side 0
.wrap
.end program list
PIO assemble 0
.program hsyncclock
.side set 1
.wrap target
.label loop1
.label loop2
  Nop side 1
.wrap
.end program list
PIO assemble 0
.program vsyncclock
.side set 1
  Pull block side 1
  Pull block side 1
.wrap target
  IRQ PREV 3 side 1
.label loop3
.label loop4
  Mov x,y side 0
.label loop5
  IRQ CLEAR 0 side 1
.wrap
.end program list
PIO assemble 1
.program datamaster
.line 0
Pull block side 0
.label loop6
Jmp x--,loop6
.wrap
.end program list
o= Pio(next line)
PIO assemble 1
.program linedata
.line next
.side set 1
Pull block side 0
.wrap target
.label loop7
Out pins,6 side 1 [9]
Out pins,6 side 1 [7]
Out NULL,2
Mov pins, NULL side 0 [2]
.wrap
.end program list
PIO CONFIGURE 1,1,clock,o,GP7,1,1,,,,GP18,6,1,,,Pio(.wrap target),Pio(.wrap)
PIO start 1,0
PIO start 1,1
PIO write 1,1,1,hvisible\pixelsperword-1
PIO start 0,0
PIO start 0,1
PIO start 0,2
PIO dma tx 1,1,wordstotransfer,b(),redo
PIO sync
mycls &H3C
Pause 1000
mycls &H3
Pause 1000
rectangle 0,0,hvisible-1,0,&H3F
rectangle 0,vvisible-1,hvisible-1,vvisible-1,&H3F
rectangle 0,0,0,vvisible-1,&H3F
rectangle hvisible-1,0,hvisible-1,vvisible-1,&H3F
printstring "Hello",300,300,3,&H3F,-1
Pause 1000
Sub printchar s$,x,y,scale,fc,bc
 Local address=(Asc(s$)-asciioffset)*fontbytes+fontadd
 drawbitmap x,y,MM.FONTWIDTH,MM.FONTHEIGHT,scale,fc,bc,address
Sub printstring s$,x,y,scale,fc,bc
Local currentx=x,currenty=y
Local j
For j=1 To Len(s$)
printchar Mid$(s$,j,1),currentx,currenty,scale,fc,bc
Inc currentx,MM.FONTWIDTH*scale
Next
Sub redo
Sub mycls col
Local c=col
c=c+(col<<6)
c=c+(col<<12)
c=c+(col<<18)
c=c+(col<<24)
Memory set word badd,c,wordstotransfer
Sub rectangle x1,y1,x2,y2,col
Local x,y,p,t,wo,sw,ew,sp,ep,mask,w,i,count
Local c=col
c=c+(col<<6)
c=c+(col<<12)
c=c+(col<<18)
c=c+(col<<24)
' Pre-calculate common masks (major speedup!)
For y=y1 To y2
   wo=y*wordsperline
   sw=x1\pixelsperword
   sp=x1 Mod pixelsperword
   ew=x2\pixelsperword
   ep=x2 Mod pixelsperword
   If sw=ew Then
     ' Single word case
     mask=0
     For i=sp To ep
       mask=mask Or mask_table(i)
     Next
     p=badd+(wo+sw)*4
     t=Peek(word p)
     t=t And INV mask
     t=t Or (c And mask)
     Poke word p,t
   Else
     ' Handle first partial word
     If sp<>0 Then
       mask=0
       For i=sp To 4
       Next
       p=badd+(wo+sw)*4
       t=Peek(word p)
       t=t And INV mask
       t=t Or (c And mask)
       Poke word p,t
       sw=sw+1
     EndIf
     ' Handle full words in the middle - use MEMORY SET WORD
     count=ew-sw
     If count>0 Then
       p=badd+(wo+sw)*4
       Memory SET WORD p,c,count
     EndIf
     ' Handle last partial word
     If ep<>4 Then
       mask=0
       For i=0 To ep
       Next
       p=badd+(wo+ew)*4
       t=Peek(word p)
       t=t And INV mask
       t=t Or (c And mask)
       Poke word p,t
     Else
       ' End pixel is exactly at word boundary (pixel 4)
       p=badd+(wo+ew)*4
       Poke word p,c
     EndIf
   EndIf
 Next
Sub DrawBitmap x1,y1,width,height,scale,fc,bc,bitmap
Local f,b,i,j,k,x,y,final_width,final_height
Local draw_x_start,draw_y_start,draw_x_end,draw_y_end
Local src_y_start,src_x_start,draw_background
Local bit_index,byte_index,bit_position,pixel_on
Local x_start,x_end
Local p,wo,sw,sp,mask,t,px
Local c_word,mask_table(4)
' Pre-calculate pixel masks
mask_table(0)=&H3F
mask_table(1)=&HFC0
mask_table(2)=&H3F000
mask_table(3)=&HFC0000
mask_table(4)=&H3F000000
' Convert 6-bit colors to full word (5 pixels)
f=fc And &H3F
f=f Or (f<<6) Or (f<<12) Or (f<<18) Or (f<<24)
If bc>=0 Then
  b=bc And &H3F
  b=b Or (b<<6) Or (b<<12) Or (b<<18) Or (b<<24)
  draw_background=1
Else
  draw_background=0
EndIf
' Calculate final dimensions
final_width=width*scale
final_height=height*scale
' Early exit if completely off-screen
If x1>=HRes Or y1>=VRes Or x1+final_width<=0 Or y1+final_height<=0 Then Exit Sub
' Calculate clipping bounds
If x1<0 Then draw_x_start=0 Else draw_x_start=x1
If y1<0 Then draw_y_start=0 Else draw_y_start=y1
If x1+final_width>HRes Then draw_x_end=HRes Else draw_x_end=x1+final_width
If y1+final_height>VRes Then draw_y_end=VRes Else draw_y_end=y1+final_height
' Calculate starting bitmap position (for clipping)
If y1<0 Then src_y_start=(-y1)\scale Else src_y_start=0
If x1<0 Then src_x_start=(-x1)\scale Else src_x_start=0
' Optimize for scale=1 (common case)
If scale=1 Then
  For i=src_y_start To height-1
    y=y1+i
    If y>=VRes Then Exit For
    If y<0 Then Continue For
    wo=y*wordsperline
    For k=src_x_start To width-1
      x=x1+k
      If x>=HRes Then Exit For
      If x<0 Then Continue For
      ' Get bit from bitmap
      bit_index=i*width+k
      byte_index=bit_index>>3
      bit_position=7-(bit_index And 7)
      pixel_on=(PEEK(BYTE bitmap+byte_index)>>bit_position) And 1
      ' Calculate word and pixel position
      sw=x\5
      sp=x Mod 5
      p=badd+(wo+sw)*4
      If pixel_on Then
        ' Draw foreground pixel
        mask=mask_table(sp)
        t=Peek(word p)
        t=t And INV mask
        t=t Or (f And mask)
        Poke word p,t
      ElseIf draw_background Then
        ' Draw background pixel
        mask=mask_table(sp)
        t=Peek(word p)
        t=t And INV mask
        t=t Or (b And mask)
        Poke word p,t
      EndIf
    Next k
  Next i
Else
  ' Scaled version
    ' Process scale lines for this source row
    For j=0 To scale-1
      y=y1+i*scale+j
      wo=y*wordsperline
        bit_index=i*width+k
        ' Determine color to draw
        If pixel_on Then
          c_word=f
          c_word=b
        Else
          Continue For ' Skip transparent pixels
        EndIf
        ' Draw scale pixels horizontally
        x_start=x1+k*scale
        x_end=x_start+scale
        ' Clip horizontal span
        If x_start<0 Then x_start=0
        If x_end>HRes Then x_end=HRes
        If x_start<x_end Then
          ' Draw the horizontal run of pixels
          For px=x_start To x_end-1
            sw=px\5
            sp=px Mod 5
            p=badd+(wo+sw)*4
            mask=mask_table(sp)
            t=Peek(word p)
            t=t And INV mask
            t=t Or (c_word And mask)
            Poke word p,t
          Next px
        EndIf
      Next k
    Next j
  Next i
EndIf
Edited 2025-11-04 08:46 by matherp
Posted: 07:35am 04 Nov 2025
Hi Peter,
I could not find a "spare" pico2 in my parts stock, the pico2 I have are soldered onto a board (GameMite and HDMI board).
I am currently wiring up the GameMite to show VGA video over the keyboard pins (the GameMite does not have successive range of 6 pins on GPIO free, but as long as you do not press any keyboard key you can use GP8..GP15).
The code is running, I see HSYNC and VSYNC, now searching for a DB15 connector.
Posted: 08:30am 04 Nov 2025
For VGA use you can remove the sidesets that drive GP4 and GP7. These create the pixel clock and the DE signals needed for RGB TFT displays
Posted: 11:28am 04 Nov 2025
Here is and updated version configuring the code as a user driver. Note you will need the attached firmware because I found a bug in the firmware user driver implementation
User drivers currently don't support reading the framebuffer so things like transparent text will give an error. Might add this one day.
PicoMite.zip
Option explicit
Dim o
SetPin gp7,pio1 'DE
Const hsync=96
Const hvisible=640
Const hbackporch=48
Const vsync=2
Const vbackporch=33
Const vvisible=480
Const HRes=hvisible
Const VRes=vvisible
PIO assemble 0
.program pclk
.side set 1
.wrap target
 Nop side 0 [4]
 IRQ PREV 2 side 0
.wrap
.end program list
PIO assemble 0
.program hsyncclock
.side set 1
.wrap target
.label loop1
.label loop2
 Nop side 1
.wrap
.end program list
PIO assemble 0
.program vsyncclock
.side set 1
 Pull block side 1
 Pull block side 1
.wrap target
 IRQ PREV 3 side 1
.label loop3
.label loop4
 Mov x,y side 0
.label loop5
 IRQ CLEAR 0 side 1
.wrap
.end program list
PIO assemble 1
.program datamaster
.line 0
Pull block side 0
.label loop6
Jmp x--,loop6
.wrap
.end program list
o= Pio(next line)
PIO assemble 1
.program linedata
.line next
.side set 1
Pull block side 0
.wrap target
.label loop7
Out NULL,2
.wrap
.end program list
PIO start 1,0
PIO start 1,1
PIO start 0,0
PIO start 0,1
PIO start 0,2
PIO sync
On error skip
Option lcdpanel user,640,480
CLS RGB(0,128,0)
Line 0,0,MM.HRES-1,MM.VRES-1
Line 0,MM.VRES-1,MM.HRES-1,0
Pause 1000
CLS RGB(0,127,128)
Circle MM.HRES\2,MM.VRES\2,150,5,1.3,RGB(0,128,0),RGB(128,0,127)
Pause 1000
Text MM.HRES\2,MM.VRES\2,"Hello",CM,,4,RGB(0,128,0),RGB(128,0,127))
Pause 2000
Sub redo
Function rgb222(c)
 rgb222= (c And &HC00000) >> 18
 rgb222 = rgb222 Or (c And &HC000)>>12
 rgb222 = rgb222 Or (c And &Hc0) >>6
End Function
Sub mm.user_rectangle x1,y1,x2,y2,col
Local c,b=rgb222(col)
c=b
c=c+(b<<6)
c=c+(b<<12)
c=c+(b<<18)
c=c+(b<<24)
For y=y1 To y2
  wo=y*wordsperline
  sw=x1\pixelsperword
  ew=x2\pixelsperword
  If sw=ew Then
    ' Single word case
    mask=0
    For i=sp To ep
    Next
    p=badd+(wo+sw)*4
    t=Peek(word p)
    t=t And INV mask
    t=t Or (c And mask)
    Poke word p,t
  Else
    If sp<>0 Then
      mask=0
      For i=sp To 4
      Next
      p=badd+(wo+sw)*4
      t=Peek(word p)
      t=t And INV mask
      t=t Or (c And mask)
      Poke word p,t
      sw=sw+1
    EndIf
    count=ew-sw
    If count>0 Then
      p=badd+(wo+sw)*4
    EndIf
    If ep<>4 Then
      mask=0
      For i=0 To ep
      Next
      p=badd+(wo+ew)*4
      t=Peek(word p)
      t=t And INV mask
      t=t Or (c And mask)
      Poke word p,t
    Else
      p=badd+(wo+ew)*4
      Poke word p,c
    EndIf
  EndIf
Next
Sub mm.user_bitmap x1,y1,width,height,scale,fc,bc,bitmap
Local f,ff,b,bb,i,j,k,x,y,final_width,final_height
Local x_start,x_end
Local c_word
ff=rgb222(fc)
f=ff Or (ff<<6) Or (ff<<12) Or (ff<<18) Or (ff<<24)
If bc>=0 Then
  bb=rgb222(bc)
  b=bb Or (bb<<6) Or (bb<<12) Or (bb<<18) Or (bb<<24)
  draw_background=1
Else
  draw_background=0
EndIf
If scale=1 Then
    y=y1+i
    wo=y*wordsperline
      x=x1+k
      bit_index=i*width+k
      sw=x\5
      sp=x Mod 5
      p=badd+(wo+sw)*4
      If pixel_on Then
        mask=mask_table(sp)
        t=Peek(word p)
        t=t And INV mask
        t=t Or (f And mask)
        Poke word p,t
        mask=mask_table(sp)
        t=Peek(word p)
        t=t And INV mask
        t=t Or (b And mask)
        Poke word p,t
      EndIf
    Next k
  Next i
Else
  ' Scaled version
    For j=0 To scale-1
      y=y1+i*scale+j
      wo=y*wordsperline
        bit_index=i*width+k
        If pixel_on Then
          c_word=f
          c_word=b
        Else
        EndIf
        x_start=x1+k*scale
        x_end=x_start+scale
            sw=px\5
            sp=px Mod 5
            p=badd+(wo+sw)*4
            mask=mask_table(sp)
            t=Peek(word p)
            t=t And INV mask
            Poke word p,t
          Next px
        EndIf
      Next k
    Next j
  Next i
EndIf
Posted: 11:54am 04 Nov 2025
I am tired,
This is the XXX'th occurence of me posting something, and after pressing SAVE, nothing is saved. Not sure what it is with this forum, but it is tiring.
Anyway. Previous version (not this last one, have not tested yet).
- timing is not correct, my monitor does not autosync. Sample frequency must be 38% (scale 0-100) and offset 55%(scale 0..100). RP2040 VGA is 50%/50% which is perfect for this monitor.
Looking at the waveform:
RP2040 VGA : falling edge VSYNC and HSYNC are at same time.
This code: The HSYNC is delayed versus the falling edge of VSYNC.
Later today I can try to check your new code. I am in meetings right now.
Work is dominant at the moment....
AlbertR
Posted: 12:12pm 04 Nov 2025
Hallo Peter,
very nice. Your program inspired me to change a few things about my PIOs. Thank you for that.
I don't know anything about VGA, but since the color signals are analog, some kind of “PWM” should work to reduce the number of RGB-pins.
I changed the output part of PIO 1
Out null,2
to
Out pins,3 side 1 [2]
Out pins,3 side 1 [6]
Out pins,3 side 1 [4]
Out null,2
and add a function to arrange the colors
Function RGB222(R%,B%,G%) As integer
Local res%                                 '-1 because bit1 already shifted
  res% =        ((R% And 1)<<0)+((R% And 2)<<2)
  res% = res% Or((G% And 1)<<1)+((G% And 2)<<3)
  res% = res% Or((B% And 1)<<2)+((B% And 2)<<4)
  RGB222 = res%
End Function
The output is shown here. If both bits of an color are set it is ok, but it not I got a kind of of floating in the printposition. It looks like a diff of 5 pixel, that means one "pull". Could there be a lack of synchronization here?
output of:
mycls rgb222(0,0,0) '&H03
rectangle   1, 10,100,100,rgb222(3,0,0)
rectangle 101, 10,200,100,rgb222(2,0,0)
rectangle 201, 10,300,100,rgb222(1,0,0)
rectangle   1,110,100,200,rgb222(0,3,0)
rectangle 101,110,200,200,rgb222(0,2,0)
rectangle 201,110,300,200,rgb222(0,1,0)
rectangle   1,210,100,300,rgb222(0,0,3)
rectangle 101,210,200,300,rgb222(0,0,2)
rectangle 201,210,300,300,rgb222(0,0,1)
rectangle   1,310,100,400,rgb222(3,3,3)
rectangle 101,310,200,400,rgb222(2,2,2)
rectangle 201,310,300,400,rgb222(1,1,1)
rectangle 315, 10,414,100,rgb222(3,3,0)
rectangle 415, 10,514,100,rgb222(2,2,0)
rectangle 515, 10,614,100,rgb222(1,1,0)
rectangle 315,110,414,200,rgb222(0,3,3)
rectangle 415,110,514,200,rgb222(0,2,2)
rectangle 515,110,614,200,rgb222(0,1,1)
rectangle 315,210,414,300,rgb222(3,0,3)
rectangle 415,210,514,300,rgb222(2,0,2)
rectangle 515,210,614,300,rgb222(1,0,1)
rectangle 315,310,414,400,rgb222(3,2,1)
rectangle 415,310,514,400,rgb222(2,3,2)
rectangle 515,310,614,400,rgb222(1,1,3)
rectangle 5,614,7,634,rgb222(3,0,0)
printstring "red---+_|>@",  1,405,3,RGB222(3,0,0),-1
printstring "green-+_|>@",300,410,2,RGB222(0,3,0),-1
printstring "blue--+_|>@",500,420,1,RGB222(0,0,3),-1
printstring "blue--+_|>@",500,430,1,RGB222(0,0,2),-1
printstring "blue--+_|>@",500,440,1,RGB222(0,0,1),-1
Albert
Edited 2025-11-04 22:48 by AlbertR
Posted: 01:38pm 04 Nov 2025
@Peter,
Timing of the last one is good. For this new firmware, I had to erase flash. Without erasing it would not run correctly.
Posted: 01:43pm 04 Nov 2025
Hi Albert,
That does not work.
Each time you do an OUT pins,... The base GPIO pin is the starting position.
So a OUT pins 6,xx sends data to GPIO 18,19,20,21,22,23
If you do an OUT pins 3,xx you send to GPIO 18,19,20
The second OUT pins 3,xx you send again to GPIO 18,19,20
So you never update pins GPIO 21,22,23
AlbertR
Posted: 02:07pm 04 Nov 2025
Hi Volhout,
that was my intention. I want to reduce the needed pins.
The idea is that the PIO mudulate the output.
Out pins,3 side 1 [2]  represent bit0 of the color, delay 3 tics
Out pins,3 side 1 [6]  represent bit1 of the color, delay 7 tics
color:
&h00 ->  0 tics high, 10 tics low
&h01 ->  3 tics high, 7 tics low
&h10 ->  7 tics high, 3 tics low
&h11 -> 10 tics high, 0 tics low
for that I rearrange the color to 00RGBrgb.
Thats the idea !
Albert
Posted: 02:45pm 04 Nov 2025
@Albert,
On a CRT that might work. Although the trace written will have traveled a bit between the 2 OUT's, in essence you are creating a 1280x480 (not exactly, it is only 1280 when you have the times identical).
But for LCD this will most likely not work. That LCD has an ADC that samples the video. There are 2 options:
1/ The ADC detects 1280 since there are more transitions than 640. But it can not do 1280x480 since that is not a known format, so t will not sync.
2/ The ADC samples in the middle of the "pixel". Since the time in MSB is longer, it will sample MSB only, and it will not see MSB of the color.
AlbertR
Posted: 04:47pm 04 Nov 2025
@Volhout,
that makes sense. The ADC only samples at his samplepoint. There doesn't seem to be any filtering in the tft.
My test results:
to 1. the ADC detects only the 640x480(info in tft-menue)
to 2. the samplepoint is not exact in the middle of the pixel, it moves, see picture.
The background has the color RGB222(0,1,0)
Finally it was only an idea.
Albert
vegipete
Posted: 05:25pm 04 Nov 2025
On the Pico2 RP2350, it is possible to modulate the VGA RGB lines to generate more colour depth than just the number of pins. For an example, see this GITHub page. A capacitor is used for filtering...
Posted: 08:04am 05 Nov 2025
Hi Pete,
That is interesting. They picked T=13ns for the filter cap. Since they use the HSTX device that uses a clock of 165MHz that would definitely give some extra color per pin.
The problem is that the HSTX is used to drive VGA, using different (fixed) pins than the multitude of PicoMites around. Using this technology is not about upgrading picomite's capabilities, but building picomite2.
And the main problem that cannot be generically solved .. memory.
Let's assume you use this technology to create RGB(3:3:2) from hardware RGB(2:2:2) wiring.
If you do this on a pico2, and forget about the STRIP and SLOT (nice for 1 single application, but not generically applicable in MMBasic) each video buffer needs 76kbyte. N,F,L together are ~240kbyte. eating half of pico2's memory (which is not too bad). But all this data has to be processed (the overlaying) by the seconds M33.
In essence RGB(3:3:2) is already implemented by Peter, but I think the framebuffers are still RGB(1:2:1).
It is a good idea, and expands the capabilities of VGA RGB(2:2:2), but it feels more realistic to focus on HDMI. -or- create a picomite2.
