Local Time 06:54 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : A small program that shows all the characters in FONT 1
Peter63
Posted: 04:37am 15 Jul 2025
The manual shows a table but unfortunately does not show which hex code the character has, this program shows this.
There are many characters I did not think of but that are there, such as "light bulb" = hex 97 or "SD-card" = hex 99
Is it a house on hex A5 or are it headphones on hex A7
asc.zip
It would be interesting to know who created these fonts, does anyone know?
Maybe Geoff or Peter knows the history...
/Peter63
javavi
Posted: 06:29am 15 Jul 2025
  Peter63 said  It would be interesting to know who created these fonts, does anyone know?
I was also interested in this question at one time!
The lower part of the encoding from B0 to FF is clearly from the encoding of CP437 (IBM437), but where did the first one come from?
Posted: 06:41am 15 Jul 2025
The font was created for the CMM2
The line drawing characters are standard and many of the characters that would normally be chr$(0) to chr$(31) were shifted to the extended range.
Others were added as a "Nice to have"
Some of the characters are standard Unicode (or very similar) and a few were created.
There is no equivalent font anywhere that I know of.
The font was a joint exercise, much from Rob Severson who was active at that time.
Where the ASCII characters came from originally I don't know. The back tick character has been changed to the degree symbol in all MMBasic fonts.
javavi
Posted: 09:52am 15 Jul 2025
A I wonder if there is a way to type a line in the built-in PicoMite code EDITOR with these extended characters?
Peter63
Posted: 11:21am 15 Jul 2025
print string$(40,&Hc4)
print's a line, 40 character long
/Peter63
javavi
Posted: 11:36am 15 Jul 2025
  Peter63 said  print string$(40,&Hc4)
Yes, I can do that too!
Is this how to type and save a string of extended characters in a program in the EDITOR? Can anyone do it?
Maybe try changing the program text on the computer...
Some BASIC dialects allowed storing a comment string from any data bytes and the editor did not complain about them. And then you could read this data from the program, it turned out more compact than storing bytes in DATA
Peter63
Posted: 12:04pm 15 Jul 2025
You can also print the entire FONT1 as it appears in memory. See attached program. I use MM.INFO(FONT ADDRESS 1) to find the start of FONT1.
font1.zip
/Peter63
Amnesie
Posted: 12:07pm 15 Jul 2025
Hi javavi,
what Font did use used to print this char set? With font1 I can't get those chars: "ÄäüÜ" etc...
just wondering...
Greetings
Daniel
Posted: 12:13pm 15 Jul 2025
  Amnesie said  what Font did use used to print this char set? With font1 I can't get those chars: "ÄäüÜ" etc...
I don't think that is a 'mite font, it is a screenshot of CP437 - taken from Wikipedia I think: https://en.wikipedia.org/wiki/Code_page_437.
Peter63
Posted: 12:32pm 15 Jul 2025
This is what the program font1.bas looks like, where you can see the DEC code on the left. Each character in FONT1 is 8 x 12 (width x height).
font1.zip
/Peter63
Posted: 02:48pm 15 Jul 2025
You can poke any values you like as bytes into a string and use it for storage like an array, but you can't PRINT it as any characters that are control characters will get either replaced with blanks or will act as control values. e.g. if you poke &h0A into a string and print it the &h0A will print as a LF, just like PRINT CHR$(10).
IIRC you can't PRINT a string that contains characters with values between 128 and 255 as these values are used for tokens by MMBasic. You can still PRINT them as CHR$() values though.
AFAIK there's no way that putting binary values into comments will work in MMBasic.
Posted: 03:03pm 15 Jul 2025
  Quote  IIRC you can't PRINT a string that contains characters with values between 128 and 255 as these values are used for tokens by MMBasic.
Characters inside a string are not treated as tokens and can be printed as normal.
Fonts 1 and 4 include an extended character set: ascii 32 to 255.
Martin H.
Posted: 03:58pm 15 Jul 2025
Hi javavi,
just wondering...
Greetings
Daniel
the font shown is 8x16 pixels, at the moment I have no routine to convert it to a  Picomite Font
Edited 2025-07-16 02:00 by Martin H.
'no comment
Posted: 04:13pm 15 Jul 2025
  Martin H. said  the font shown is 8x16 pixels, at the moment I have no routine to convert it to a  Picomite Font
I do not believe there is a naive conversion, CP437 has glyphs in all 256 positions, including for the ASCII control codes.
javavi
Posted: 04:15pm 15 Jul 2025
  matherp said  Characters inside a string are not treated as tokens and can be printed as normal.
If it were possible to make a key combination for switching the keyboard input language and loading a new font (national encoding), it would be possible to provide support for national input/output languages as it was in the days of MS DOS.
Amnesie
Posted: 05:17pm 15 Jul 2025
Yes! this would be great. At this time I have to do a massive workaround for displaying german letters like ÄäÜüß etc. I have to read in the actual keypress of the PS/2 keyboard, then re-map it to a custom font with ÄäüßÖö etc...
My long-term idea was to create a simple text editor for MMBASIC with my GUIs, but with all those workaround it is a bit of a nightmare.
This workaround gives äÄöÖüÜß with a custom font via normal keyinput... but as said... just a workaround.
german_chars.zip
Greetings
Daniel
Edited 2025-07-16 03:33 by Amnesie
Martin H.
Posted: 08:14pm 15 Jul 2025
There are only 224 characters in the picture, so you can add the characters 0-31 at the end (224 - 255).
As I said, I have not yet found how to create an 8x16 font in mmbasic
'no comment
Amnesie
Posted: 08:37pm 15 Jul 2025
Hi javavi,
just wondering...
Greetings
Daniel
Martin,
thanks for the link, I totally forgot that you made some really good fonts. I just tested the Amiga (?) font. Works great!
Greetings
Daniel
Posted: 02:35am 16 Jul 2025
If you want to create a font based on any code page.
The first step would be to find a true-type font that has all the required characters in it. Not all fonts have all the characters defined.
You should also use a font that is free of copyright if you intend to share it.
FontTweak will convert any ttf into any size bitmaps for MMBasic.
The conversion is not very good for smaller sizes and you will need to do some cleaning up the characters.
This thread has some information about FontTweak
https://www.thebackshed.com/forum/ViewTopic.php?TID=16941&PID=221525#221525#221525
Some of the bugs mentioned there have been fixed.
FontTweak.zip
Posted: 08:26am 16 Jul 2025
  Martin H. said  There are only 224 characters in the picture, so you can add the characters 0-31 at the end (224 - 255).
You must be looking at a different picture. The one I'm seeing (with the accented characters) has 8 rows of 32 glyphs, which was 256 last time I checked .
Edited 2025-07-16 18:26 by thwill
