Local Time 07:18 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 2040 2350 and diy
     Page 1 of 3
stanleyella
Posted: 07:45pm 10 Jun 2025
lot of discussion lately.
I was going to post an easy vero board but it's soldering and not fun if you want compact... like olimex, which was sold for 2040 but is hdmi board?
works ok ish with 2350 mmbasic hdmi. so 2040 can do hdmi?
is there anything else like olimex no soldering needed?
Posted: 09:49pm 10 Jun 2025
The only way I can think of to get something like that is modules plugged into a breadboard with wire links. It's not easy to have a completely no solder system as even most of the modules need the header pins soldering before you can use them.
stanleyella
Posted: 11:00pm 10 Jun 2025
I'll use the pins supplied as solder wiring avi messed it. ordered 2 more pihut then found I had a spare. can't find coloured wire.
Posted: 06:49am 11 Jun 2025
For cheap coloured 30AWG wire get a mixed roll of 8 colours of wire-wrap wire. AliExpress £4.29 for 250m. Alternatively, Bitsbox do 5m lengths of Kynar in blue, red, green, yellow and black for £1.20 per length. 5m doesn't sound a lot but it goes quite a long way on a PCB. :)
stanleyella
Posted: 02:06pm 11 Jun 2025
I got some "somewhere". I tried some old pc ribbon for connecting old drives all grey but holes on dvi board bit small and messed up.
tried molex coloured cable used for bread boarding and cut off the male/female connector to find how poor the wire was. it's poor without the r.
as I look through boxes searching for something I found lots of electronics I'd forgotten I had :) stan
Posted: 04:19pm 11 Jun 2025
Just stick an order in to Bitsbox for some Kynar or one of their wire packs. They are pretty quick, their stuff is good and postage is fixed price and reasonable (£2.50 per order). Don't mess with rubbish. :)
Edited 2025-06-12 02:20 by Mixtel90
cosmic frog
Posted: 04:29pm 11 Jun 2025
  stanleyella said  I'll use the pins supplied as solder wiring avi messed it. ordered 2 more pihut then found I had a spare. can't find coloured wire.
You can get a massive 50m drum of alarm wire from screwfix - link
Strip it and use it for hook up wire.
Dave.
stanleyella
Posted: 06:13pm 11 Jun 2025
ok the first try which I tested with molex type male to female, The idea was wires under the board but just testing and isn't it amazing you can use molex like this to test and it works.  bubble universe running
it's not a bad dvi board Mick. I just want more people to use mmbhasic but not get cocky or it get rocky
stanleyella
Posted: 07:44pm 12 Jun 2025
it looks tidier than before but not fun wiring/ add usb to ttl and sd card reader next.
no joining links between strip board tracks yet.
stanleyella
Posted: 08:26pm 12 Jun 2025
a point is hdmi isn't as fussy as some say. this is first try at using flying leads and the leads from dvi to gp pins I haven't have not cut all the extra unused tracks and the capacitance between them yet.
using ribbon cable is capacitance between leads but is common. maybe it's accounted for
Posted: 09:19pm 12 Jun 2025
To know if it's ok you have to run the HDMI at the highest speeds, not necessarily the ones that that monitor can handle. In other words, you need a known good design to see what the maximum speed is that your monitor will work with then test it using the knitted wires system. Even then, unless you reached the top speed you can't really say that the rats nest works properly.
stanleyella
Posted: 10:47pm 12 Jun 2025
is there a test program other than change resolution and draw filled circles in different modes? other peoples code gives heap error often
stanleyella
Posted: 12:41am 13 Jun 2025
I flashed the hdmi usb and temp wired a usb c to ttl and used the 5V to power pico pin 40 vbus. I got a usb keyboard connected that's uk but always start with mum lock on and  always types daft chars.
got to do the micro sd card next to get "the complete kit :("
got a few sd card readers, latest 3V so use pico 3.3V out or usb to ttl 3v out?
just the layout as want it all rats nest wiring and no links between tracks as never tried before
Posted: 01:20am 13 Jun 2025
OPTION KEYBOARD UK
Posted: 07:22am 13 Jun 2025
SD card sockets can't have the built in level shifters. They convert the signals to 5V, which is no use for the Pico. They are usually sold as being for the Arduino. SD cards are all 3V3 and the Pico needs a direct connection. Avoid any card modules with components on them with one exception that I know of. That one is the one I call the "inverted" module because it always used to be sold with ready soldered pins on the same side as the socket, although you can get it without the pins now. That one has decoupling capacitors and pullup resistors on it but it works very well indeed.
stanleyella
Posted: 05:17pm 13 Jun 2025
This an existing board with large sd card and adaptor.. like ili9341 uses large card and I use a micro sd card adaptor.
> option list
PicoMiteHDMI MMBasic USB RP2350A Edition V6.00.02b0
OPTION AUTORUN  ON
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION KEYBOARD UK
OPTION CPUSPEED (KHz) 315000
OPTION SDCARD GP22, GP6, GP7, GP4
OPTION AUDIO GP0,GP1', ON PWM CHANNEL 0
this is the "new" one, no sd card option yet.
option list
PicoMiteHDMI MMBasic USB RP2350A Edition V6.00.02RC24
OPTION KEYBOARD UK
OPTION RESOLUTION 640x480 @ 252000KHz
2 sd  card readers, one looks passive and meeds 3.3V, the other looks like it got a reg so probably needs 5V
never had problems with sd card readers before. used the manual suggested settings
dddns
Posted: 05:55pm 13 Jun 2025
As long as it has a AMS1117 low drop you can try any card by powering it with 3V3.
Haven't had a sdcard problem even not with 15 years old ones as most have anyway a separate 3V3 input.
The 2350 takes 5V at most pins..
Edited 2025-06-14 03:57 by dddns
stanleyella
Posted: 06:36pm 13 Jun 2025
looking  in the manual is this correct please?
card pins
gnd
miso-----GP4
clk------GP6
mosi-----GP7
cs-------GP22
3v3--- from pico or usb to ttl
then use OPTION SDCARD GP22,GP6,GP7,GP4
haven't tried cos only 6 wires I could mess up.
Posted: 06:51pm 13 Jun 2025
The top module will work. The bottom one might work, might not or might be touch and go, depending. :)  It's intended for a 5V supply. The voltage regulator won't regulate if you power it at 3V3 (not enough voltage across it) and the level shifter might be marginal because of that.
All SD cards are 3V3. They work fine when fed from the Pico. You can probably use the socket in the bottom picture by powering it from 5V rather than 3V3. Take the supply from VSYS.
For testing purposes you can use any GPIO pins for a SD card providing you specify them all in OPTION SDCARD.
Edited 2025-06-14 04:54 by Mixtel90
stanleyella
Posted: 07:16pm 13 Jun 2025
got this from passive card reader so think it's ok... now to wire it as all this was test wiring then audio out, yawn
files
A:/
  <DIR>  .
  <DIR>  ..
00:00 01-01-2024          4  bootcount
2 directories, 1 file, 2527232 bytes free
> b:
> files
B:/
19:05 28-07-2020    8802830  adele,tupac,eminem.mp3
21:07 29-09-2024   67081508  adele,tupac,eminem.wav
17:38 28-07-2020    8444268  Biggie,Adele,Tupac.mp3
21:08 29-09-2024   65642084  Biggie,Adele,Tupac.wav
22:16 28-07-2020    5338459  biggie.johnny cash.mp3
21:08 29-09-2024   39577644  biggie.johnny cash.wav
22:54 23-09-2024     138982  fatlib.bmp
16:48 30-08-2024      44556  sfx-bg.mod
20:35 20-03-2020   49501189  THENOT~1.MP3
21:11 29-09-2024  363818330  THENOT~1.WAV
18:49 28-07-2020    7598885  tupac,eminem.mp3
21:11 29-09-2024   54718580  tupac,eminem.wav
0 directories, 12 files
this was with "the top one" Mick but I gonna try the 5 V? card cos I used them dim problemo... just to test. it was initially an easy diy plan but take it back it's not easy.
soldering is worse than smoking
Edited 2025-06-14 05:40 by stanleyella
     Page 1 of 3
