Local Time 07:43 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PI5 - Trying to install Opera browser...
Posted: 06:34am 24 May 2025
Hello all.
I'm just playing around tonight, so I could be doing something wrong.
PROBABLY am doing something wrong.
Used the PI5 to go to the Opera browser website, and download the deb for Linux.
Right-click on the file, set the EXECUTE permissions to "Only Owner", click OK.
Now double-click the deb file, get asked if I want to install it, I say yes/OK, then get the following error message:
The PI5 is trying to tell me to look in the "Detailed report", which is fine, but as I am something still of a Linux novice, can someone point me to where I can FIND that report, and then maybe find out what the issue was.
Cheers!
Posted: 07:05am 24 May 2025
When you get this sort of thing there is a method that can help. Open up a terminal window (yes, it's command line time!), navigate to the location of the file you are trying to install and run the installer from the command line (you may need to use sudo to get permission to install it). You will usually get a whole load of stuff scrolling up, but it will stop where the error is - or not long after as it tidies up. Whether you understand the error message is something else, but at least it's a start. :)
Posted: 07:35am 24 May 2025
Awesome, thanks, I will try that.
Quite impressed with Raspbian.
I've tried LOTS of Linux distro's, but this seems really painless to get going, compared to other PC-based distro's.
I guess that, similar to MAC, the hardware is a KNOWN, and so they can write for known hardware, other then generic.
Posted: 08:36am 24 May 2025
Raspian was pretty good last time I was messing with a Pi. Very solid. I didn't find the urge to try anything else. Mind you, it was a 3B so there weren't many other good options. I've not had a better Pi since then.
dddns
Posted: 11:26am 24 May 2025
Arm is not amd64!! Not sure of RP5 processor type but the package needs to fit to the architecture
stanleyella
Posted: 12:59pm 24 May 2025
I use win Opera but it's not available for pi.
dddns
Posted: 01:59pm 24 May 2025
  stanleyella said  I use win Opera but it's not available for pi.
There is a windows version  for the PI.
And there is a opera version  for windows on arm.
dddns
Posted: 02:07pm 24 May 2025
@Grogster
Many thanks for your questions which made me research on Pi5.
Reading all this makes me never buy a RPI
stanleyella
Posted: 05:30pm 24 May 2025
I wish I never bought a rpi 400...or a rpi 3,2,1
get a mini ex office pc
stanleyella
Posted: 06:23pm 24 May 2025
rant rpi is useless for video. same price i5 8gb win smooth
Posted: 11:57pm 24 May 2025
  dddns said  Arm is not amd64!! Not sure of RP5 processor type but the package needs to fit to the architecture
Good point.
That was a bit of a schoolboy mistake by me there....
I don't NEED to have Opera, I was just playing around with trying to install it, but I will drop that idea now.
Posted: 01:36am 25 May 2025
Perhaps Brave is another option.
Posted: 09:11am 25 May 2025
Either use what's supplied by default or install something from the repo. Life can be so much easier. :)  I still have a soft spot for Firefox.
dddns
Posted: 09:16am 25 May 2025
Chromium would be my suggestion @Grogster
Posted: 09:35am 25 May 2025
I like Chromium (not Google Chrome) too.
dddns
Posted: 10:25am 25 May 2025
I'm using firefox but some modern browser-based applications are best compatible with chromium which is based on chrome
Posted: 10:41am 25 May 2025
I currently have Brave on here, with an option for Vivaldi. I rarely need to use anything else. My MX Linux machine is currently set up with Firefox because it happened to be there. :)
Generally, if a site or application is browser-fussy I just go somewhere else and may never look again. If they can't be bothered to standardise I'm not interested, it's their loss. I'm certainly not going to deliberately install a spyware and advertising-riddled browser for anyone. :)
dddns
Posted: 11:02am 25 May 2025
these tendencies are visible since early 2000's so I banned win for private use in 04
and quit my job in 10
stanleyella
Posted: 01:17pm 25 May 2025
raspian used to use duck duck go. I think chromium uses it to search
Posted: 01:48pm 25 May 2025
I like Startpage search engine.
