Local Time 08:56 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V6.00.02 betas
     Page 1 of 23
Posted: 11:08am 16 Jan 2025
V6.00.02b0 is available on
Bugs fixed
Fixes bug in forward references in PIO assembler when the starting line number is > 1
Fixes bug in PRINT @(x,y) when outputting to a computer console
By default disables heartbeat and enables access to all pins on RP2350B
Allows selection of GP19 for PSRAM PIN
Fixes bug in TILE HEIGHT 12 command in PicoMiteVGA
Fixes bug in TILE HEIGHT command in PicoMiteHDMI[USB] setting the screen to white
Fixes bug in LINSTR changing the regular expression if a variable
General
The firmware now implements the ability to save the entire variable space to the A: drive or PSRAM (if available) and subsequently restore it.
This is completely transparent to the user although saving to the A: drive does take a second or so and there must be free space of just less than 256KB available.
This allows commands that historically have required access to the complete variable space to be run from within a program (e.g. FILES).
Specifically, this allows the implementation of a CHAIN command
When PSRAM is enabled 2MB of the available PSRAM is reserved for system use. The remaining space(typically 6MB) is available as normal MMBasic variable space
This allows 5 RAM program slots to be created and used both from within a program and at the command line.
Of course RAM program slots will not survive a power cycle but they will survive a system reset.
New functionality
Layer buffer now available in VGA mode 1 (252MHz and above) and all HDMI mode 1 resolutions
Supports ; at the end of LONGSTRING PRINT to suppress the CR/LF
I2C(2) OPEN now supports 1000 as a speed
FILE command can now be used in a program
CHAIN fname$ [,cmdline$] ' Allows the program to run another program with the variable space preserved - command is recommended to be used in top level program and not from within a subroutine (may work OK but not tested for side-effects)
EDIT FILE command used in a program will now only be memory limited the same as EDIT
SAVE CONTEXT [CLEAR]' saves the variable space and optionally clears it - command should be used in top level program and not from within a subroutine (may work OK but not tested for side-effects). If used in a subroutine a subsequent LOAD CONTEXT must DEFINITELY be in the same subroutine or a crash/corruption will DEFINITELY happen.
LOAD CONTEXT [KEEP]' restores the variable space to the previously saved state and optionally preserves the stored variables to allow a second LOAD if required.
RAM command (RP2350 with PSRAM only) functions like the FLASH command with 5 program slots available in PSRAM. All commands except RAM LOAD (copies a RAM slot to the main flash program space) can be used in a program.
RAM FILE LOAD n,fname$ [,O[VERWRITE]] can be used to load a RAM slot from a standard disk .BAS file
SHIFT-F3 to F10 now work for computer console. NB: Shift-F1, F2, F11, and F12 don't appear to send codes so can't work
PLAY MODFILE will preferentially use space in PSRAM if enabled for the file buffer (RP2350 only). In this case a modbuffer does not need to be enabled with the OPTION command
Edited 2025-01-16 21:41 by matherp
Posted: 11:42am 16 Jan 2025
I'm *SO* glad I didn't reprint my manual....  :)
(It always goes in a ring binder now anyway - just in case!)
Many thanks!
javavi
Posted: 09:30pm 16 Jan 2025
PicoMiteHDMI MMBasic RP2350A Edition V6.00.02b0
When performing function
A$=Dir$("*",DIR)
the list of files is printed to the screen.
A$=Dir$("*",VOL)
Error : Invalid flag specification
https://www.thebackshed.com/forum/ViewTopic.php?TID=17283&P=7#232617
Edited 2025-01-17 07:40 by javavi
Posted: 11:00pm 16 Jan 2025
The error message with VOL is correct. Valid are DIR FILE and ALL
The list is me leaving a diagnostic in.
javavi
Posted: 05:21am 17 Jan 2025
  matherp said  The error message with VOL is correct. Valid are DIR FILE and ALL
in PicoMite User Manual MMBasic BASIC Interpreter Ver 6.00.01 Revision 3 (29 December 2024)
DIR$( fspec, type )
'type' is the type of entry to return and can be one of:
VOL  Search for the volume label only
DIR  Search for directories only
FILE  Search for files only (the default if 'type' is not specified)
  matherp said  The list is me leaving a diagnostic in.
This diagnostic conclusion is making my FM go crazy.
FM_V120
Edited 2025-01-17 16:23 by javavi
ville56
Posted: 06:46am 17 Jan 2025
Small bug in OPTION LIST on RP2350B (and also RP2040)
after
OPTION HEARTBEAT ENABLE GP0 and
OPTION HEARTBEAT DISABLE (or OFF)
OPTION LIST still says "OPTION HEARTBEAT PIN GP0". Despite this, GP0 can be used as normal I/O pin, so it seems to affect only the option list command.
73 de OE1HGA, Gerald
Posted: 07:46am 17 Jan 2025
@Peter,
The PIO assembler fix works. Thanks.
Pitty this could not get into 6.00.01. But I understand your position.
Edited 2025-01-17 17:49 by Volhout
Posted: 08:23am 17 Jan 2025
  Quote  in PicoMite User Manual MMBasic BASIC Interpreter Ver 6.00.01 Revision 3 (29 December 2024)
The manual needs updating - I'll ask Geoff. AFAIK that has never been available - certainly not in the PicoMite
  Quote  This diagnostic conclusion is making my FM go crazy.
I'll post an update later today
after
Please could you do OPTION RESET and see if it still happens.
Posted: 09:05am 17 Jan 2025
Download now updated to remove diagnostic in DIR$ command - no version change
ville56
Posted: 07:38pm 17 Jan 2025
after
did OPTION RESET, still happens.
ville56
Posted: 08:16pm 17 Jan 2025
Another strange behaviour found:
PicoMite MMBasic RP2040 Edition V6.00.01, Pico-restouch-lcd-3.5
After resetting options and re-establishing options for the panel AND setting
OPTION GUI CONTROLS 71 the old problem with GUI CALIBRATE occurs ...
Error : Touch not calibrated
in a loop after the first calibration point is touched.
If GUI CONTROLS is set to 0, calibration works ...
Edited 2025-01-18 06:16 by ville56
javavi
Posted: 08:27pm 17 Jan 2025
Is it possible to implement in V6.00.02 sound on I2S DAC?
PCM5102 TDA1387
Posted: 08:25am 18 Jan 2025
  Quote  Is it possible to implement in V6.00.02 sound on I2S DAC?
PCM5102 TDA1387
I have looked at this but to work properly it relies on the processor running at specific speeds to allow the 44100*64*8 master clock rate for the PIO. These speeds are incompatible with VGA and HDMI.
Given that VS1053 is fully supported I don't intend to pursue this further
  Quote  Another strange behaviour found:
Can't replicate
Edited 2025-01-18 18:28 by matherp
javavi
Posted: 12:20pm 18 Jan 2025
PCM5102 TDA1387
And at what sampling frequency is the data updated for sound on PWM or for SPI DAC?
For the I2S bus, it is not at all necessary to adhere to the exact flow frequency; it is possible to transmit data packets at a higher clock frequency with the required sampling period.
Edited 2025-01-18 22:38 by javavi
Posted: 12:42pm 18 Jan 2025
Sorry, but I've had a look at it and made a decision. If you want to pursue it further the PicoMite source is on github. The MMX port of MMbasic fully supports I2S output as that chip has a proper I2S module. The Rp2404/2350 can only do it using PIO
ville56
Posted: 01:01pm 18 Jan 2025
Can't replicate
ok, can't either anymore after a clear_flash. Must have been some garbage left over in the options area, sorry to bother you ....
javavi
Posted: 05:47pm 18 Jan 2025
  matherp said  Download now updated to remove diagnostic in DIR$ command - no version change
It looks like diagnostics in the DIR$ command is disabled only for disk B: but for disk A: it is still enabled.
Posted: 06:14pm 18 Jan 2025
Sorry - will fix
I was trying to update  LFS and FatFS to the latest versions but hit problems hence the diagnostics. Eventually I backed the changes out but not after they rendered two SD cards dead and on the A: drive neither FILES nor DIR$ gave any output even though you could load and save files and the free space changed - bizarre
NB: PIO DMA TX and PIO DMA RX don't work for RP2350 PIO2 - bug in sdk
Edited 2025-01-19 04:18 by matherp
Posted: 12:26am 19 Jan 2025
WeAct RP2350A_V20 Completely replace the original PICO2 Raspberry Pi RP2350 RISC-V Hazard3 520KByte SRAM 4 or 16MByte QSPI Flash
Color: RP2350A-V20-16MB AU$7.21 Tax excluded, add at checkout if applicable. Shipping: AU$6.86
https://www.aliexpress.com/item/1005008117237405.html
Edited 2025-01-19 10:34 by phil99
javavi
Posted: 01:04am 19 Jan 2025
  phil99 said  WeAct RP2350A_V20 Completely replace the original PICO2 Raspberry Pi RP2350 RISC-V Hazard3 520KByte SRAM 4 or 16MByte QSPI Flash
Here is a QSPI flash installed in a large case, onto which a PSRAM microcircuit can be soldered on top.
     Page 1 of 23
