Forum Index : Microcontroller and PC projects : That was easy
![]() ![]() Geoff's watering controller ![]() WebMiteRP2350V6.00.01RC1.zip NB: WebMiteRP2350 includes the full GUI controls Edited 2024-11-26 23:23 by matherp |
Nice, Where did you get one that fast ? Volhout PicomiteVGA PETSCII ROBOTS |
Pimoroni has them: |
Not sure if BT will be supported but I asked Copilot about 5.2 because I use(prefer) classic BT |
Bluetooth isn't and won't ever be supported by me. |
Oh I'm covered with ESP32 ( Arduino IDE ) |
Oh, you poor thing. My condolences. ;) Mick Zilog Inside! nascom.info for Nascom & Gemini |
And I just ordered a bunch more ESP32s...I must be a masochist |
For those in Australia, Little Bird Electronics have plenty for $12.05 + postage https://littlebirdelectronics.com.au/collections/new/products/raspberry-pi-pico-2w Also available with the pins for an extra $2 Jim Edited 2024-11-27 05:29 by TassyJim VK7JH MMedit |
Harm, https://www.kiwi-electronics.com/nl/zoeken?search=raspberry%20pi%20pico%202%20w Jan. |
| andreas Senior Member Joined: 07/12/2020 Location: GermanyPosts: 226 |
Oh, there is a new user manual! Thank You Geoff!! Oh, there is a new firmware! Thank You Peter!! Oh there is a new chip in the post box! ;-) ![]() -andreas |
At least I wouldn't take a hammer to it like I'm tempted to do with my ESP32-C3 super mini. That's gone into storage just in case I'm feeling particularly masochistic sometime... Mick Zilog Inside! nascom.info for Nascom & Gemini |
Testing WebMiteRP2350V6.00.01RC1 - very nice! > 2 MB filesystem! > option list WebMite MMBasic RP2350A Edition V6.00.01RC1 OPTION FLASH SIZE 4194304 OPTION CPUSPEED 150000 'KHz > memory Program: 0K ( 0%) Program (0 lines) 160K (100%) Free Saved Variables: 16K (100%) Free RAM: 0K ( 0%) 0 Variables 0K ( 0%) General 208K (100%) Free > flash list Slot 1 available Slot 2 available Slot 3 available > files A:/ <DIR> . <DIR> .. 00:00 01-01-2000 4 bootcount 2 directories, 1 file, 2461696 bytes free > option list WebMite MMBasic RP2350A Edition V6.00.01RC1 OPTION AUTORUN 1 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION CPUSPEED 150000 'KHz OPTION DISPLAY 50, 100 OPTION WIFI FritzBox, *********************, PICO93370ED3E2A OPTION TELNET CONSOLE ON OPTION F1 files > flash list Slot 1 in use: "' connect to wifi and get time" Slot 2 available Slot 3 available > list ' connect to wifi and get time Do While MM.Info(IP ADDRESS) = "0.0.0.0" If Timer > 5000 Then CPU RESTART Loop WEB ntp 1,"192.168.178.1" Print "Hello, world!" > run ntp address 192.168.178.1 got ntp response: 28/11/2024 18:19:52 Hello, world! -andreas Edited 2024-11-29 03:22 by andreas |
I've forgiven the ESP32-C3 super mini. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
Yeah, we've heard that before, Peter.... At this point in time, I fully believe you, but you have a tendency to pull surprises out of your hat, historically speaking. ![]() Smoke makes things work. When the smoke gets out, it stops! |
Wireless UART link and robust because it was originally intended for industrial apps. WiFi is a PITA and sloooow in comparison. |
Oh, I have NO DOUBT how hard BT is - don't get me wrong. I was just putting the stick in, so to speak. Peter has amazed us before, AFTER saying he would NEVER support thing X.... Smoke makes things work. When the smoke gets out, it stops! |
I don't think Bluetooth is too programmer and resource friendly. IIRC it's one of those things that demands RAM buffers and a chunky protocol stack. I can't blame Peter on this one, it's definitely non-trivial. One of those things where you let someone else do the hard work and load their library! Mick Zilog Inside! nascom.info for Nascom & Gemini |
This one is a definite. I hate bluetooth in real life. One of the least reliable, clunky, and confusing ways of connecting available. As Mick says it would have high resource requirements and whether it could even be implemented alongside wifi on the Pico I don't know - I will not be trying to find out. |
Guesses on how long it will be before Peter includes BT? THANK YOU Peter so much for including GUI controls too - very useful!! |
