Forum Index : Windmills : Building a Darrieus H rotor
Posted: 12:40pm 16 Apr 2009
I have one 3m length of the sample PVC blade left, and I'm thinking of cutting it into 3 and making a 1m high H rotor.
I plan to use 1 inch timber dowel up the middle of the extrusion instead of the steel tube cause I dont need to hold the blade from one end, I can screw it together with timber screws, and its lighter.
A Darrieus works best with a profile that is symetrical on the inside and outside of the swept path/diameter. The extruded blades have a curve, so I worked out the ideal diameter that would pass through the center of the blade profile. This path is shown in blue, and you can see how A = B along the length of the blades chord. This gave a diameter of 580mm.
If I go bigger in diameter, I gain power. I do loose RPM, but will ignore that for this exercise. I wonder how much I can increase the diameter before I upset the air flow and get a decrease in power. Below is at 800mm.
Still looks ok. At 1200, below, I think I may be pushing my luck. I'm also loosing solidity by increasing the diameter.
Any comments? I've never played with a Darrieus before so this should be a fun project. I'm aware I need to spin it up before it will start to power itself, I'll use a pull cord to test at first, and later try a smaller Savonius made from PVC pipe. I have a servo motor as the load, this is too small to drive a F&P.
vawtman
Posted: 10:21pm 16 Apr 2009
Hi Gizmo,
What is the blade chord you have?Those blades should easily selfstart with the right solidity.You may want to keep it pretty narrow with so few blades.I think .3 is a good solidity for the giro.
Thats just me though.
Have fun and nice to see
Posted: 11:17pm 16 Apr 2009
Hey vawtman
The chord is 160mm. If I use a 600mm diameter with 3 blades, to work out the solidity, total blade chord of 480mm ( 160 X 3 ), divided by the circumference ( Pi X 600 ), gives approx 0.25
Is that right?
vawtman
Posted: 11:56pm 16 Apr 2009
you mm guys kill me
Yep and should selfstart and run great at that.
Giver a go
DaViD
Posted: 02:09pm 17 Apr 2009
Hi Glenn, What kind of r.p.m. are you looking for with this motor?Edited by DaViD 2009-04-19
If your not living on the edge your taking up to much space!
DaViD
Posted: 12:38pm 18 Apr 2009
Just a quick question, at what point does suction side flow start to creat a
loss of efficiency?
vawtman
Posted: 03:21pm 18 Apr 2009
Hi David,
There comes a point where the blades go into stall.By stall they don't stop spinning just maintain that speed and no faster.I think it's a good thing.
I built a small giro early on and at 30mph winds would spin at 120rpms and at 60mph winds still only spun at 120rpms.However the tower bent
The hawts run at such low solidity(high tsr) that the blades can fly for football feilds when out of control
It's funny when i first started everything was the darrieus bein the nasty boy.Sure the skinny bladed eggbeaters would be nasty if gone amuck.
DaViD
Posted: 07:09pm 18 Apr 2009
Thanks Vawtman, I'm trying to learn a little about the vawts.
Am I correct in my thinking that there is a suction on the inner side of the
blades that could cause performance issues or am I completely wrong?
Rember just trying to learn a thing or two
vawtman
Posted: 07:45pm 18 Apr 2009
By suction do you mean drag? If so yes all airfoils have it.You can't suck the wind into a wind turbine like a centrifugal pump pumps water if that's the thought.
It's actually pretty cool on the inside all you feel is tiny pulses when the turbine's up to speed.Pretty cool and hope someone else in this world experiences it sometime Maybe OZ did with his ground level hawt.
Where there's gains there's also losses it's the law of the land.
DaViD
Posted: 08:34pm 18 Apr 2009
I'm not saying anymore so I don't sound really stupid
Posted: 08:25am 19 Apr 2009
I finished it off today.
No load yet, and no wind either
Will post another update when I see some wind.
Posted: 11:05am 19 Apr 2009
Just a thought Gizmo. How much flex is there when you push on a blade by hand? The rods appear to be thin.
Gordon.
oztules
Posted: 11:34am 19 Apr 2009
Just too too cool ..... you will start a whole new VAWT thing I'm sure.
......oztules
Posted: 11:46am 19 Apr 2009
  GWatPE said   Just a thought Gizmo. How much flex is there when you push on a blade by hand? The rods appear to be thin.
Gordon.
Hey Gordon.
I was thinking the same, buts its actually a lot stronger that I though it would be. The center shaft is 12mm and the rods are 8mm steel. Its only 1000mm high by 600mm wide, so not a lot of wind frontage. It runs on a couple of bearings.
justmick
Posted: 12:40pm 19 Apr 2009
Love the vertical design always prefered that for suburbia. A question if I may if building one to plug into the grid and not stand alone to a battery set up, do you need a certain size/type of stator or will any still do as long as you get the right inverter to match. Would it be better to buy these parts together as a set.
Posted: 01:00pm 19 Apr 2009
Hi Mick
The small backyard VAWT's ( or even small HAWT's ) dont make much power. They are good for powering garden lights or water features, thats sort of thing. Plus they are fun to make and fun to watch. If you want to feed power back into the grid or make a dent in your power bill, you need to go big. Some of the forum members here have done just that, they have big turbines on tall masts with good wind, and they feed the power back into the grid. Anything under 2 meters diameter isn't going to reduce your power bill unless you live in a VERY windy location.
justmick
Posted: 04:27am 20 Apr 2009
thanks Gizmo
Seen some impresive VAWT`s around. The Backshed.com had a link to a japanese company making comercial towers over 7 metres putting out 1kw but they look expensive. Heard you guys talking here about spending less than $100.00, thought if I could get the right parts for the right price I could as you say make a dent in my power bill, but not really keen to go that big now I`m off the farm Sounds like I`ll just stick to my little set up for the aquaponics........ for now.
vawtman
Posted: 11:13pm 20 Apr 2009
Hey Glen
Just curious and wondering
Posted: 12:09am 21 Apr 2009
Sorry vawtman, no wind. Been still for a couple of days, even the big windmill hasn't moved. Lots of sun though , someone needs to invent a solar power windmill.
murraymint
Posted: 09:22am 22 Apr 2009
Hi Guys, first post.
I just love this site and it's full of really useful stuff.
I have a question regarding the shape and profile of the blades, Is it best to use a symmetrical or an asymmetrical aerofoil or will it not make a big difference.
