Local Time 13:19 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maths precedence error in MMBasic? Any maths gurus out there?
     Page 1 of 3
Posted: 02:17pm 06 May 2024
3 + 4 * 2 / ( 1 - 5 ) ^ 2 ^ 3
is calculated by MMbasic as 3.001953125
However, if I convert that to reverse polish I get
3 4 2 * 1 5 - 2 3 ^ ^ / +
which evaluates to 3.00012207
Converting the reverse polish back to infix gives
3 + (4 * 2) / (1 - 5) ^ (2 ^ 3)
Note the 2 ^ 3 is now bracketed hence the different answer. Is the MMBasic operator precedence wrong or right?
UPDATE Wolfram Alpha also gives 3.00012207 so I suspect MMbasic is wrong
Edited 2024-05-07 00:40 by matherp
homa
Posted: 02:50pm 06 May 2024
Hello Peter,
an interesting observation.
ChatGPT 3.5:
To convert the expression "3 + 4 * 2 / ( 1 - 5 ) ^ 2 ^ 3" into Reverse Polish Notation (also known as postfix notation), you can use the shunting-yard algorithm. This algorithm processes operators and operands according to their precedence and associativity. Here's how you can convert the expression:
1. Initialize an empty stack for operators.
2. Initialize an empty list for the output (the reverse Polish notation).
3. Iterate through each token (operands and operators) in the infix expression.
4. If the token is an operand, add it to the output list.
5. If the token is a left parenthesis, push it onto the operator stack.
6. If the token is a right parenthesis, pop operators from the stack and add them to the output list until a matching left parenthesis is encountered. Pop and discard the left parenthesis.
7. If the token is an operator:
   a. While there are operators at the top of the stack with greater precedence or equal precedence and left associativity, pop them from the stack and add them to the output list.
   b. Push the current operator onto the stack.
8. After processing all tokens, pop any remaining operators from the stack and add them to the output list.
Let's apply this algorithm to the given expression:
Infix expression: "3 + 4 * 2 / ( 1 - 5 ) ^ 2 ^ 3"
Output (Reverse Polish Notation): "3 4 2 * 1 5 - 2 3 ^ ^ / +"
Here's the expression step-by-step:
1. Push "3" onto the stack.
2. Push "+" onto the stack.
3. Push "4" onto the stack.
4. Push "*" onto the stack.
5. Push "2" onto the stack.
6. Push "/" onto the stack.
7. Push "(" onto the stack.
8. Push "1" onto the stack.
9. Push "-" onto the stack.
10. Push "5" onto the stack.
11. Pop and add operators "^" (twice) to the output.
12. Pop and discard "(".
13. Pop and add "/" to the output.
14. Pop and add "*" to the output.
15. Pop and add "+" to the output.
So, the reverse Polish notation is "3 4 2 * 1 5 - 2 3 ^ ^ / +".
and
https://www.wolframalpha.com/input?i=3+%2B+4+*+2+%2F+%28+1+-+5+%29+%5E+2+%5E+3
so I think that the MMBasic operator priority is really wrong!
really really tricky.
Matthias
Quazee137
Posted: 03:12pm 06 May 2024
here is how I read it
3+((4*2)/(1-5)^(2^3)) = 3+8/-4^8 = 3+8/65536 = 3 + 0.0001220703125
in MMB4L
3 + 4 * 2 / ( 1 - 5 ) ^ 2 ^ 3 = 3.001953125
3+((4*2)/(1-5)^(2^3)) = 3.00012207
and
3 + 4 * 2 / (( 1 - 5 ) ^ 2) ^ 3 = 3.001953125
hope this helps
Quazee137
Edited 2024-05-07 01:14 by Quazee137
twofingers
Posted: 03:13pm 06 May 2024
  matherp said  3 + 4 * 2 / ( 1 - 5 ) ^ 2 ^ 3
But that's what Excel says:
strange ...
Posted: 03:14pm 06 May 2024
Maybe MMBasic mimics GW-Basic?
NPHighview
Posted: 03:17pm 06 May 2024
As an avid HP calculator (and later, SwissMicros) user, I compliment your approach.
I have a rule of thumb when programming complex calculations, in whatever language: When in doubt, use parentheses liberally to enforce evaluation order.
PEMDAS is one attempt to implement the arithmetic concept of associativity. Here's an excellent explanation of how that is (or isn't) implemented in various programming languages, Excel, Matlab, Wolfram Alpha, etc.
Edited 2024-05-07 01:19 by NPHighview
homa
Posted: 03:37pm 06 May 2024
Very interesting, thank you!
and Libre ...
Matthias
Posted: 03:57pm 06 May 2024
More and more interesting
So we have Excel and MMBasic agreeing but anything that converts to rpn disagreeing
The question is whether to read 3 + 4 * 2 / ( 1 - 5 ) ^ 2 ^ 3
as
3+((4*2)/((1-5)^(2^3))) = 3.00012207
or
3+((4*2)/((1-5)^2)^3) =  3.001953125
Quarzee137. Please can you explain why you interpret the expression to yield the former - which is what the rpn convertor does rather than the first exponentiation operator applying to the (1-5)?
vegipete
Posted: 04:07pm 06 May 2024
Simplify the problem:
2 ^ 2 ^ 3 = ?
a) = 4 ^ 3 = 64
b) = 2 ^ 8 = 256
My take on precedence is you work left to right for equal level operators, so version a would be the correct interpretation.
  matherp said  anything that converts to rpn disagreeing
Yes, if it's done using the shunting yard algorithm (or an equivalent).  (Er, maybe there's more than one variant of such anyway?)
The same issue crops up with divisions of course.
I was taught that division is done before multiplication and that more than one division next to one another are done left to right.  (Same rule for subtractions BTW.)
"Brackets" (i.e. parentheses) are done first.
I would expect exponentiation to be like division - (higher precedence than division and) done left to right if more than one next to one another.
But it's been a debate for quite some time!!
What result would people like for:
4 * 2 / ( 1 - 5 ) / 2 / 3
and for
4 * 2 / ( 1 - 5 ) - 2 - 3
Edited 2024-05-07 02:10 by JohnS
Posted: 04:26pm 06 May 2024
Reading more into this it appears that exponentiation is conventionally right associative which is what rpn is doing. It is an edge case but I think MMbasic and Excel are probably both wrong if you are going to be purist
From wikipedia
  Quote  However, when exponentiation is represented by an explicit symbol such as a caret (^) or arrow (↑), there is no common standard. For example, Microsoft Excel and computation programming language MATLAB evaluate a^b^c as (ab)c, but Google Search and Wolfram Alpha as a(bc). Thus 4^3^2 is evaluated to 4,096 in the first case and to 262,144 in the second case.
Edited 2024-05-07 02:33 by matherp
twofingers
Posted: 04:48pm 06 May 2024
  matherp said  ... From wikipedia
  Quote  However, when exponentiation is represented by an explicit symbol such as a caret (^) or arrow (↑), there is no common standard. For example, Microsoft Excel and computation programming language ...
https://en.wikipedia.org/wiki/Order_of_operations
I think that a note in the manual is sufficient. IMHO.
Kind regards
Michael
homa
Posted: 04:52pm 06 May 2024
  matherp said  Reading more into this it appears that exponentiation is conventionally right associative which is what rpn is doing. It is an edge case but I think MMbasic and Excel are probably both wrong if you are going to be purist
Especially since RPN seems to be better defined in the sequence and there are "standardised" instructions for converting to RPN (see above according to ChatGPT).
I also found this: https://www.rpn-calc.com/?q=3+4+2+*+1+5+-+2+3+%5E+%5E+%2F+%2B
Matthias
Posted: 05:00pm 06 May 2024
GW-Basic.exe running under DOSBOX
? 3 + 4 * 2 / ( 1 - 5 ) ^ 2 ^ 3
3.001953
Posted: 05:41pm 06 May 2024
Peter,
Most formula's I know that raise something to the power X, have some form of a calculation that they raise to that power. Hence there are always parenthesis around the formula. And when that is the case it is simple. You work your was from inside to  outside.
something like: (x+(a+b)^2)^3 makes life simple....
Quazee137
Posted: 06:02pm 06 May 2024
At engineering class we went from slide rules to TI-84's
that was set to use RPN on power on. So got use to
thinking that way and thats what I saw when looking at
the equation. But the left hand rule should be used now
days. I was just showing how it was being handled by
MMBasic that is the right way to process this equation.
Yes I'm old and it ok.
Quazee137
p.s. yes I still have both and a lookup book that came with slide rule.
Edited 2024-05-07 04:06 by Quazee137
Posted: 09:08pm 06 May 2024
I like the way the calculator program on my phone works.
As I entered the formula, as soon as I entered the ^ an opening bracket was added.
This gave me
3 + 4 * 2 / ( 1 - 5 ) ^ (
If I continued with the brackets used, I ended up with 3.00012207
If I backspaced to remove the opening bracket, I ended up agreeing with Microsoft and MMBasic.
I like my calculator program.
"Panecal Plus" on Android
Panecal evaluates equal precedence left to right but really wants you to think about what you really want.
LeoNicolas
Posted: 09:47pm 06 May 2024
From the android app HiPER Scientific Calculator
Posted: 10:42pm 06 May 2024
As there is no universal answer, rather than change MMBasic as previously suggested a note in the manual on the rules of precedence would be best.
When in doubt I bracket almost everything then remove pairs one at a time until the result changes, restoring those ones.
Frank N. Furter
Posted: 06:26am 07 May 2024
This is what my CASIO calculator shows:
Frank
     Page 1 of 3
