Local Time 13:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New 4 inch LCD
     Page 1 of 12
Bleep
Posted: 04:55pm 14 Mar 2024
I'm hoping that this display will be usable with the ILI9488 driver on Picimite?
4" 480x320 LCD using ILI9488 chip
It claims to use the same chip & is same resolution so in theory it will work, not sure about the touch though?
palcal
Posted: 08:59pm 14 Mar 2024
I'll find out one day I just bought one.
stanleyella
Posted: 09:52pm 14 Mar 2024
the link said £3.xx now says  £23.xx
other ad shows it £7.xx
Posted: 10:21pm 14 Mar 2024
The link says £45.37 for the touch version here.
Remember that on AE the price is shown without taxes and shipping though. Sometimes you have to spend £8 to get stuff in less than a month too!.
stanleyella
Posted: 10:49pm 14 Mar 2024
other ad from original link
https://www.aliexpress.com/item/1005006262797500.html?
Posted: 12:09am 15 Mar 2024
For me, the link in the first post shows $12.76USD without touch, and $13.89 with--both including shipping. Why would the UK price be so high?
Posted: 12:32am 15 Mar 2024
I suspect the price you are seeing is the "First Time Discount" from that seller.
When I clicked that link the price was $AU 12.xx for the touch version but jumped to $AU 21.27 + 10% tax when I logged in. Presumably I have bought from them before.
Posted: 01:17am 15 Mar 2024
Hi Bleep,
AndrewG and I have been using these as our preferred LCD for well over 6 months now. They are exceptionally good.
BTW the price shown for me is $19.54AU
Mick.
palcal
Posted: 02:53am 15 Mar 2024
Mine cost A$23.  Free postage
Edited 2024-03-15 14:23 by palcal
Pluto
Posted: 08:11am 15 Mar 2024
Ordered one yesterday. From the hint by Bleep on top of this thread. €16:50 incl VAT and postage.
Good to hear that Mick has been satisfied.
Posted: 09:17am 15 Mar 2024
LOL!
I was bog-eyed and thick-fingeredlast night....
The Price was (and still is) £4.37 for the touch version here.
Bleep
Posted: 10:19am 15 Mar 2024
Hi, Aliexpress must almost make up the price on the fly!
Every time I go there my price, without touch is £9.56, or £10.43 with touch, free delivery, but 20%VAT is added at checkout, so £12.48 for a touch version delivered, supposedly 7 day delivry!  Yes I've ordered one to try. :-)
Regards Kevin
Edited 2024-03-15 20:22 by Bleep
Bleep
Posted: 10:29am 15 Mar 2024
Mick, the big one,
Does this screen still need the resistor diode mod to get it working properly, can someone point me to a definitive version of how to connect up this mod, a simple circuit diagram showing resistor & diode & what pins to connect to will be fine.
Regards Kevin.
Posted: 10:36am 15 Mar 2024
Thing to remember about the ili9488.
1. They are slow
2. You need an extra resistor and diode to get reliable reading
3. They are slow
4. They are too big for both a framebuffer and a layer buffer to fit in memory
5. They are slow
Reasons:
The ILI9488 controller has a bug where it doesn't tri-state MISO properly hence 2
The ILI9488 does not support 16-bit RGB565 over SPI so all writes and all reads are 3 bytes per pixel
The ILI9488 needs a much slower clock for reading pixels than any other display
They only support H/W scrolling in portrait mode so use for a console is terrible. It takes about 1 second to scroll a line of text up the screen
They have 2x the pixels of an ILI9341 and need 3 bytes per pixel vs 2 so things like CLS take 3x longer than on an ILI9341
Wiring mod
Edited 2024-03-15 20:45 by matherp
Bleep
Posted: 12:21pm 15 Mar 2024
Hi Peter,
I realise they are slow, :-( I want to use one as a console on a Picomite USB I like the 340x480 space, but it appears this is the only display of that resolution that can be used as a console, now that the 9481 is disabled, it looks like scrolling is very slow, but page up/down not too bsd, so I'll have to train myself to mainly use that.
Thank you for the photo of the mod, that looks very simple.
Regards Kevin.
Posted: 01:58pm 15 Mar 2024
  matherp said  They are slow ... You need an extra resistor and diode to get reliable reading ... They are slow ... They are too big for both a framebuffer and a layer buffer to fit in memory ... They are slow
Is there any more suitable 480x320 SPI LCD which is supported (or could be)?
I'm with bleep--if there's nothing better (of the SPI type), the ILI9488 is satisfactory.
stanleyella
Posted: 02:08pm 15 Mar 2024
Kevin, don't want to digress but these 7 inch displays I paid £12.50 for. Sold as car reversing monitor. got hdmi, vga and composite video... not avi as advertised- no audio- no speakers. says 5V to 24V supply but need 2A 5V. 12V 1A ok
vga 640x480 and pico is readable and scrolls as vga does. uses little space.
use with a small usb keyboard makes a small system.. no touch screen or sd card slot though. just a suggestion. stan
Posted: 03:12pm 15 Mar 2024
If you want a console and can spare the pins then the 4.3" SSD1963 is the way to go
e.g.
Quick video to upset those trying to use the ILI9488 as a console here
NB: this is in 8-bit parallel 24-bit colour mode rather than 16-bit RG565 which paints the screen 3x faster
Edited 2024-03-16 01:45 by matherp
Bleep
Posted: 08:07pm 15 Mar 2024
Ok thanks Peter, it looks like I'll have to try to build one of your 1963 parallel USB boards, or find a nice small bare VGA display to use with a VGA USB board.
Regards Kevin.
stanleyella
Posted: 08:43pm 15 Mar 2024
  Bleep said  Ok thanks Peter, it looks like I'll have to try to build one of your 1963 parallel USB boards, or find a nice small bare VGA display to use with a VGA USB board.
Regards Kevin.
these vga displays are take to bits able but why. the base is standard tripod mount.
small case border
     Page 1 of 12
