Local Time 14:49 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Internet radio working on the WebMite with VS1053
     Page 1 of 3
Posted: 05:02pm 09 Nov 2023
Just a few lines of code
Option escape
Option explicit
Option default none
' create the request for the radio site (ClassicFM)
Dim a$="ice-the.musicradio.com"
Dim q$="GET "
Inc q$,"/ClassicFMMP3"
Inc q$," HTTP/1.1\r\n"
Inc q$,"Host: "
Inc q$,a$
Inc q$,"\r\nConnection: close\r\n\r\n"
'create a circular buffer for reading the internet stream and
'read and write pointers
Dim buff%(4095),w%,r%
' Configure the VS1053 and tell it to play from the circular buffer
Play vs1053 GP9, gp8, gp7, gp6, buff%(), r%, w%
' Open the internet radio site
WEB open tcp stream a$,80
' Send the request to start the stream using the circular buffer specified
WEB TCP CLIENT STREAM q$, buff%(), r%, w%
'sit back and listen
Pause 500
Hardware requirement
1 PicoW
1 VS1053
9 Dupont connection cables
Software requirement
Peter and Geoff's magic WebMite MMBasic V5.07.08RC15
WebMiteV5.07.08RC15.zip
Edited 2023-11-10 05:38 by matherp
Plasmamac
Posted: 08:07pm 09 Nov 2023
Plasma
hitsware2
Posted: 09:19pm 09 Nov 2023
  matherp said  Just a few lines of code
Option escape
Option explicit
Option default none
Dim q$="GET "
Inc q$,"Host: "
Inc q$,a$
Pause 500
1 PicoW
1 VS1053
It would almost seem You are on the verge of a complete
internet appliance ?.......
my site
Posted: 08:12pm 11 Nov 2023
Code updated for the latest version RC15 syntax just posted
  Quote  Option escape
Option explicit
Option default none
Dim q$="GET "
Inc q$,"Host: "
Inc q$,a$
Play stream buff%(), r%, w%
Pause 500
morgs67
Posted: 07:23am 14 Nov 2023
Tried with a Arduino VS1053 shield similar to Geeetech one.
Works fine.
Tony
Posted: 08:49am 14 Nov 2023
  Quote  Tried with a Arduino VS1053 shield similar to Geeetech one.
Great.
Everyone who tries this, please post any station settings that you discover on this thread.
Unfortunately, many stations have now moved to HLS and this is outside the capability of the VS1053 but there are still lots of mp3 streams out there. The code should also cope with AAC streams but I haven't found one to test.
LucV
Posted: 03:48pm 14 Nov 2023
Hey guys,
Long time no see, but I am very busy.
I still follow this forum regularly and saw this. So here is my contribution.
A large list of MP3 streams:
https://www.webradiostreams.nl/
A Webmite with an oled screen or TFT screen, and a rotary connector to choose the radio stations would not be too difficult to build.
Add a small amplifier and a connection to your hifi installation and we have something unique that costs loads more in the shops.......
And here is another source (more internationally oriented):
https://www.rcast.net/dir/mp3/page1
Google is your friend:
https://www.internet-radio.com/search/?radio=mp3&page=/
And this one might be the best:
http://fmstream.org/index.php?c=FT
Luc
Edited 2023-11-15 02:00 by LucV
Luc's tech Blog
morgs67
Posted: 12:06pm 18 Nov 2023
Found a couple of AAC streams the VS1053 can play:
CLASSIC HITS RADIO
http://classichitsradio.streamingmedia.it:8017/usa
for this-
Dim a$="classichitsradio,streamingmedia.it"
Inc q$,"/usa"
WEB open tcp stream a$,8017      ' not 80
Classic1027 NZ
http://edge.iono.fm/xice/49_high.aac
for this-
Dim a$="edge.iono.fm"
Inc q$,"/xice/49_high.aac"
Need to add a volume control to the VS1053 via the WebMite and rotary control.
Tony
Pluto
Posted: 12:27pm 04 Jan 2024
My intention is to build the WebMite webradio (a la matherp above). Again a great development by Peter! Thanks!
Ordered the VS1053 module from AE two months ago. Not yet arrived.
The company making (designing) these chips is located just 200 km north from here, but they charge almost 20€+postage for just the chip!
While waiting, I am thinking about to use the MCP4822 DAC as a temporary sound output device. Run immediately into problems!
> option list
WebMite MMBasic Version 5.08.00RC2
OPTION WIFI HuaHuaNisse, ***********, PICOE6616408439
> option audio spi gp0,gp1,gp2,gp3
Error : Syntax
I understood that the audio should be declared as:
OPTION AUDIO SPI CSpin, LDACpin, SCKpin, SDIpin
GP2 is a vlid SPI CLK pin and GP3 is a valid SPI TX pin.
What do I do wrong?
Suppose that I will get the DAC operational, can I then use Peter's program (top page of this thread) and output the datastream with
It is very silent in thebackshed today! Free beer somewhere? Did I miss something?
Pluto
Posted: 12:59pm 04 Jan 2024
Just ground LDAC - don't include it in the OPTION AUDIO arguments. The SPI channel has to be dedicated to the DAC too. The PWM channel used for the SCLK will also be set as audio PWM IIRC.
Have fun. :)
Pluto
Posted: 01:13pm 04 Jan 2024
Thanks Mick!
I came one step forward...but
> option list
OPTION AUDIO SPI GP1,GP2,GP3', ON PWM CHANNEL 1
> RUN
[21] Play stream buff%(), r%, w%
Error : Only available with VS1053 audio
I think I have arrived at the end of this road. Which means I have to be patient and wait for a mailbag from China.
Posted: 01:49pm 04 Jan 2024
Ah... yes.... well.....   :(
At least you can play with the MCP4822 for something else while you wait. All is not lost. :)
Posted: 02:09pm 04 Jan 2024
The data received from an internet radio station is an mp3 or aac stream. Sending it to a DAC unprocessed would not achieve much other than noise. The VS1053 includes multiple codecs which is what makes it so clever
Pluto
Posted: 02:19pm 04 Jan 2024
Thanks Peter.
This means that I will have a free evening and time to heat the sauna.
Pluto
Pluto
Posted: 10:30am 05 Jan 2024
Is there a command to CLOSE the TCP STREAM?
After running WEB OPEN TCP STREAM a$,80 about 6...8 times I get this message
[138] WEB open tcp stream a$,80  '
Error : failed to create pcb
Probably because too many TCP connections are open. But how to close the connections that are not needed?
Pluto
Pluto
Posted: 10:17pm 06 Jan 2024
I think I found a solution:
Last part of Peter's code above:
Pause 500
If you do not want to sit and listen forever and want to change channel, then it is good to put
WEB CLOSE TCP CLIENT
before you switch to next channel.
At least my test program can make >100 channel changes without any problems.
Pluto
> option list
OPTION AUTORUN  ON
OPTION CPUSPEED  252000 'KHz
OPTION TCP SERVER PORT 80
homa
Posted: 03:01pm 07 Jan 2024
  Pluto said  I think I found a solution:
Hello,
does that mean you have 100 radio stations in your test programme? That would interest me! Would you like to share?
Matthias
Pluto
Posted: 03:31pm 07 Jan 2024
Matthias,
at the moment I have only 11 stations in my program. I am just scrolling through this set several times.
And a more important remark: I have not yet got the VS1053 module. The only idication of successful operation is done by commenting out the VS1053 Play command, that would give error without the module attached.
'Following line is commented out until I get VS1053:
' Play stream buff%(), r%, w%
By printing the circular buffer read r% and write w% pointers I can see if there is some activity.
Peter's demo program is now in a SUB:
SUB OpenRadioChannel Chan%
' create the request for the radio site e.g.(ClassicFM)
' https://ice-the.musicradio.com/ClassicFMMP3
?"Channel nbr:";Chan%
?name$(Chan%)
a$=host$(Chan%)
q$="GET "
Inc q$,page$(Chan%)
Inc q$,"Host: "
Inc q$,a$
?"q$=";q$
ON ERROR SKIP 1
IF mm.errno=16 then WEB open tcp stream a$,80:?"**SECOND ATTEMPT TO OPEN TCP**"
PRINT "mm.ERRNO=";mm.errno
IF MM.ERRNO=16 THEN PRINT "CPU RESTART"
IF MM.ERRNO=16 THEN CPU RESTART
' r%, w% are read and write pointers
n%=0
Pause 500
?"Read:";r%   'to check for streaming activity
?"Write:";w%
n%=n%+1
Loop until n%>2 'check for a few seconds, then return to main
'This is just for testing. Later the return from the sub will be activated
'e.g. by TOUCH or pin-interrupt.
WEB CLOSE TCP CLIENT 'Close the connection before opening a new one!
'You can only have 8 open connections at the same time.
'Even if you stop the program and restart, the connections will remain open
'until Pico is powered down. => CLOSE CONNECTION WHEN NOT NEEDED ANYMORE!
end sub
The station info is simply stored as:
name$(2)="Absolute Classic Rock"
host$(2)="edge-bauerall-01-gos2.sharp-stream.com"
page$(2)="/absoluteclassicrock.mp3"
When I finally get the VS1053 and get it tested, I can publish the whole thing including the list of stations I have confirmed working.
Pluto
Pluto
Posted: 02:20pm 18 Jan 2024
Finally got VS1053 module today. Got it to play web-radio stations.
BUT, when I change station I get this error:
[112] Play stream buff%(), r%, w%
Error : Sound output in use for STREAM
Obviously there is a need to STOP the
PLAY STREAM buff%(), r%, w%
before the next web-radio station is started.
Tried PLAY STOP and PLAY HALT, but it did not help.
How can I solve this problem?
option list
OPTION AUTORUN  ON
OPTION LCDPANEL ILI9341, LANDSCAPE,GP17,GP14,GP13
OPTION WIFI HuaHuaNisse, ***********, PICOE6616408433
OPTION TCP SERVER PORT 80, 10000
OPTION TOUCH GP0,GP1
GUI CALIBRATE 0, 3894, 3948, -904, -634
OPTION AUDIO VS1053 GP10,GP11,GP12,GP9,GP8,GP7,GP6', ON PWM CHANNEL 5
Pluto
Pluto
Posted: 03:51pm 18 Jan 2024
Problem solved. Tried with PLAY STOP again and now it is OK!
     Page 1 of 3
