Local Time 00:02 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Just ordered one of these :
hitsware2
Posted: 12:10am 10 Mar 2023
All the way from the U.K.
Hope to make it work with coming version of mmPico/VGA
my site
Hans
Posted: 04:22am 10 Mar 2023
  hitsware2 said  All the way from the U.K.
Just do a search for "Pimoroni Pico VGA Demo Base" (ALL).
There are a number of posts that have discussed this board in the past. I found several.
Hans ...
Posted: 06:51am 10 Mar 2023
That board Will not work with picomite VGA
The connecties between the VGA connector and the rp2040 are different.
The audio is different.
Edited 2023-03-10 16:54 by Volhout
Posted: 11:58am 10 Mar 2023
I think it runs DOOM, though, so don't just scrap it if you like such things.
hitsware2
Posted: 07:46pm 10 Mar 2023
Hopefully soon uPython will work .
First I'll try this ....
Edited 2023-03-11 05:49 by hitsware2
my site
Posted: 07:57pm 10 Mar 2023
  Quote  Hopefully soon uPython will work .
Very unlikely with this board - there are a number of dedicated demo's in C that run on it but that is all
hitsware2
Posted: 08:59pm 10 Mar 2023
Yea ..... I see that .... but hope springs eternal
Then there is the BBCBasic .... From what I know , I don't know
if it will be able to read ADC ? COUNT ? et. al.
Why don't you make the new version compatible with this board ?
It evidently is based on the RPi reference ( for what that's worth ) ?
Edited 2023-03-11 07:03 by hitsware2
my site
Posted: 09:23pm 10 Mar 2023
Do you want it compatible with that board or do you want it usable? ;)
You don't create a language to run on one particular PCB nowadays.
First, I2S audio needs quite a bit of processing. It's not I2C, which can be handled in hardware on the chip. It would probably need the second PIO.
Second, the VGA system on that board uses 17 GP pins rather than 6.
Hawk
Posted: 09:50pm 10 Mar 2023
I couldn’t see any indication that a keyboard can be connected to the Pimoroni.  They’re must be something that I’m missing, as the RPi Pico port of BBC BASIC supposedly runs on it.
Posted: 10:38pm 10 Mar 2023
Unless they have found some way to use a USB keyboard through the USB port it will have to be tethered to a computer. In which case you may as well run your programs on the computer and leave it in the junk box.
Perhaps you are meant to use the few remaining I/O to implement your own PS/2 port.
  Quote  Why don't you make the new version compatible with this board ?
Because it is a catastrophically stupid design
Posted: 10:51pm 10 Mar 2023
It's odd, too, in that I can't (*) figure _why_ they chose it. Someone was clever enough to create the PIOs etc and so much else on the Pico (OK, the ADC is an exception) ... yet the "reference design" has such shortcomings.  Like it was made by someone with little interest in h/w (GPIOs etc) - other than quite good VGA (using up so many pins).
Oh well. It wasn't expensive.
(*) it's well beyond my abilities re h/w
Perhaps they'll make a version 2 ref design... any of the MMBasic ones would be good!
Posted: 10:58pm 10 Mar 2023
I suspect the reference design is optimised for running impressive demos to show off the Pico. It has nothing to do with making it usable.
Posted: 11:07pm 10 Mar 2023
  Mixtel90 said  I suspect the reference design is optimised for running impressive demos to show off the Pico. It has nothing to do with making it usable.
Bingo!
Sounds right.
They definitely need a #2.
hitsware2
Posted: 01:19am 11 Mar 2023
  Hawk said  I couldn’t see any indication that a keyboard can be connected to the Pimoroni.  They’re must be something that I’m missing, as the RPi Pico port of BBC BASIC supposedly runs on it.
That doesn't mean it's a ' boot to basic ' standalone ...
my site
hitsware2
Posted: 01:21am 11 Mar 2023
  phil99 said  Unless they have found some way to use a USB keyboard through the USB port it will have to be tethered to a computer. In which case you may as well run your programs on the computer and leave it in the junk box.
Except you may be able to use the vga monitor the same way as now doable with small lcd displays
my site
Posted: 07:36am 11 Mar 2023
That board is a clever but pointless design IMHO. It's actually what it says - a demo board. It's not intended to do anything useful, there simply isn't enough IO left. Also, by the time you are running the VGA display most of the RAM has gone. There quite simply isn't enough of it. You *may* get impressive things to run (written in C) but it's not a general purpose board by any means.
Posted: 12:49pm 11 Mar 2023
Reading more, and looking at the examples, looks like they debugged the Pico using the ref design.
Maybe take off various resistors etc and use it for MMBasic after that.
Posted: 12:53pm 11 Mar 2023
Cheaper and more convenient to get a PicoMite VGA mini....  ;)
Ok, you don't get the (unsupported) high number of colours or the (unsupported) I2S audio. :)
Posted: 02:35pm 11 Mar 2023
  Mixtel90 said  Cheaper and more convenient to get a PicoMite VGA mini....  ;)
Well, they're supported - but not by MMBasic (for good reasons).
I plan to send for Mini PCBs once someone else who's competent at soldering etc has got them & found any problems plus fixed them :)
(BTW I am convinced the PM & PMVGA are far better designs for actual use than the demo board.)
TBF, the demo board is cheaper if you already own it (the OP & me, at least). It may even be cheaper than buying the Mini PCBs and parts (I don't care, I'll buy 'em anyway).
Also, it doesn't need any soldering (probably a -ve for many on here LOL) or the effort of buying of various components (not meant as a complaint).
I had a very quick glance at the demo board just now and don't really fancy trying to remove parts. CBA as some say.
