Forum Index : Microcontroller and PC projects : New PicoMite firmware release V5.07.06
| Page 1 of 6 |
Peter has released V5.07.06 of the PicoMite and PicoMiteVGA firmware (V5.07.05 was skipped). This release is an update to both versions and fixes all currently known bugs. However the outstanding new feature is the Flash Filesystem. In case you have missed Peter's beta test versions this looks like a normal disk drive to MMBasic and is automatically created by the firmware using the spare flash memory in the Pico. Data and programs can be read/written using the normal BASIC file commands (SAVE, RUN, OPEN, etc) and sub directories can be created and deleted, long filenames used, etc. This is a major feature and is worth the upgrade. Peter has done a tremendous job The changes are listed in the release notes and both user manuals have been updated and now include change bars to highlight the new material. The new firmware and manuals can be downloaded from: PicoMite: https://geoffg.net/picomite.html PicoMiteVGA: https://geoffg.net/picomitevga.html Upgrading the firmware will erase the program and programs stored in the flash slots and clear any options set. So save everything first. Geoff Edited 2023-01-07 11:35 by Geoffg Geoff Graham - http://geoffg.net |
Thanks as always to Geoff for a huge amount of work on updating the manuals. The release notes for 5.07.06 are in the download but are reproduced below. Updating to this new release is highly recommended. PicoMite V5.07.06 Changes from V5.07.04 Breaking changes PicoMite PAGE command removed - replaced by GUI PAGE GUI TEXTBOX ACTIVATE removed Reduced available RAM and program size from 120KB to 116KB Removes support for the GDEH029A1 display as this controller is now obsolete Breaking changes PicoMiteVGA Reduced available RAM and program size from 108KB to 100KB General changes - both versions Various tuning and performance improvements Updates SDK to V1.4 Updates Compiler to version 11.2.1 Enables operation up to 378MHz SETPIN for PWM no longer needs to specify the channel and port e.g. "SETPIN 1,PWM" is now accepted Re-engineering of PORT command to allow simultaneous update Modifies the port function to read all pins simultaneously Revised version of CSub header to cater for compiler change Updated CSUB header file and additional functions exposed The number of flash slots in both versions is now 5 Changes the priority of the CIN.FIN,PER interrupt to improve accuracy Resets default fonts when a new program is loaded or the NEW command is executed. Max editor clipboard size now 16384 characters Max number of BLIT buffers now 32 (memory dependent) Support for file system on the Pico's flash. All SD file commands are supported. Flash drive is "A:" SDcard if configured is drive "B:" By default the system restarts with the active drive as drive "A:" even if the SDcard is configured On first installation the firmware will automatically create the flash drive. The firmware reads the size of the flash and uses this to determine the drive size. Flash chips > 2Mb are fully supported OPTION LIST now shows version number and which firmware Changes to better support modules with >2Mb Flash chips PWM duty cycles can now be negative which will invert the output (-100.0 <= duty <=100.0) New/changed Commands - both versions DRIVE drive$ - sets the active drive DRIVE "A:/FORMAT" - re-initialise the flash drive MATH RANDOMIZE [n] - seeds the Mersenne Twister algorithm. TRIANGLE SAVE [#]n, x1,y1,x2,y2,x3,y3 - saves a triangular area of the screen to buffer #n. TRIANGLE RESTORE [#]n - restores a saved triangular region of the screen and deletes the saved buffer. MEMORY PACK source%(),Destination%(), number, size - packs the contects of one array into another MEMORY UNPACK source%(), Destination%(), number, size - unpacks the content of one array from another BITBANG SERIALTX pinno, baudrate, ostring$ - transmits ostring$ on pinno BITBANG SERIALRX pinno, baudrate, istring$, timeout_in_ms, status% [,nbr] [,terminators$] - receives istring$ on pinno ON PS2 interrupt - triggers an interrupt whenever the PicoMite sees a message from the PS2 interface. OPTION HEARTBEAT ON/OFF LINE AA x1, y1, x2, y2 [, LW [, C]] - Draws a line with anti-aliasing. FRAMEBUFFER - see manuals for details OPTION SERIAL CONSOLE TXpin, RXpin [,B] - adding the "B" parameter means output will go to "B"oth the serial port and the USB PIO READ - Allows a single integer variable to be used when nbr=1 New/changed Functions - both versions MATH(RAND) - returns a random number 0.0 <= n < 1.0 using the "Mersenne Twister: A 623-dimensionally MM.INFO(drive) - get the current active drive - returns A: or B: MM.INFO(HEAP) - returns the free space on the MMBasic heap MM.INFO(STACK) - returns the C program stack pointer MM.INFO$(SOUND) - returns the status of the audio channel MM.INFO(PS2) - returns the last raw PS2 message received. MM.INFO(PINNO n) now accepts a literal, a string variable or an unquoted GPn designation MATH(CRC8 array()_or_string$, [length,] [polynome,] [startmask,] [endmask,] [reverseIn,] [reverseOut] - calculate an 8 bit CRC MATH(CRC12 array()_or_string$, [length,] [polynome,] [startmask,] [endmask,] [reverseIn,] [reverseOut] - calculate a 12 bit CRC MATH(CRC16 array()_or_string$, [length,] [polynome,] [startmask,] [endmask,] [reverseIn,] [reverseOut] - calculate a 16 bit CRC MATH(CRC32 array()_or_string$, [length,] [polynome,] [startmask,] [endmask,] [reverseIn,] [reverseOut] - calculate a 32 bit CRC PIO(EXECCTRL jmp_pin ,wrap_target, wrap [,side_pindir] [,side_en]) - JMP PIN must have GP designation, Extra optional parameters Other new functionality - PicoMite Enabled BLIT and LOAD JPG for mono displays BLIT LOAD: now also accept BLIT LOADBMP for compatibility with VGA version Adds support for the 480x320 IPS ILI9481 display (use code ILI9481IPS) Other new functionality - PicoMiteVGA Use EDIT 1 to edit in mode 1, Use EDIT 2 to edit in mode 2, Use EDIT to edit in current mode Implements DRAW3D command and function Improved LOAD JPG for MODE 1 (mono). Implementation of enhanced sprite command and function Bug Fixes and corrections - both versions Fixes crashing bug if edit is used after running a program with IR input Fixes bug in BITBANG LCD CMD and BITBANG LCD DATA Fixes bug in PIO READ Fixed bug in sound command overdriving the PWM when > 2 channels are used and the volume isn't explicitly specified Fixed bug in PWM n,OFF requiring spurious extra parameter Fixes bug in SDK that caused SPI clock to set to wrong level before first transaction Fixes bug when using "ON KEY int" command Fixes bug in passing string function to time$ Fixes bug in MM.INFO(filesize ... and MM.INFO(Modified ... Changes to PS2 keyboard handler to fix bug where interrupts are dropped Fixes bug in PLAY TONE n. m. d, interrupt which caused the interrupt not to fire Fixes bug in ERASE command when erasing arrays Improved error checking of SETPIN command to avoid crashes Fix to BITBANG WS2812 timings Improved error messaging for incorrect pin usage. Fixed MM.INFO(pinno when OPTION EXPLICIT specified. Improved error detection on some option commands to avoid lockups through pin conflicts Fixes bug in setpin fin,per,cin when fast signal is established before the setpin Bug Fixes and corrections - PicoMite Fixes bug in GUI DELETE Fixes bug in OPTION LIST for some displays SPI for touch reduced in speed to 1MHz to improve reliability Bug fix to GUI spinbox to erase triangle bounding line properly Fixed bug in LOAD IMAGE for mono displays Corrects reporting of MM.HRES and MM.VRES by OPTION LIST when a user driver is loaded Bug Fixes and corrections - PicoMiteVGA Fixes issue where connecting a USB CDC cable would cause the VGA version to Hardfault Change timing of PAGE COPY ,,B to avoid screen artefacts Fixes issue on some Pico in VGA mode 1 output at 126MHz Edited 2023-01-07 19:10 by matherp |
Just.... WOW! Many thanks, Peter, this is sterling work on your part as usual. This really has become a habit of yours. :) Many thanks also to Geoff for his excellent work on the manuals. I've been watching the development of 5.07.06 but until now I hadn't realised just how much has gone into it. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Those are BIG changes and improvements! Many thanks for creating such a wonderful piece of software and a manual which deserves it's name. But also it is the community here in the forums, which is always kind and helpful !Greetings Daniel |
| homa Guru Joined: 05/11/2021 Location: GermanyPosts: 757 |
Danke! Thank you, Geoff and Peter!And everyone else, like Volhout for the PIO course and the great forum here. Best regards Matthias |
Well done Peter and Geoff. We should probably hold a sweepstake on how long before the first bug/typo is reported .Happy New Year, Tom Edited 2023-01-07 22:25 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| cosmic frog Guru Joined: 09/02/2012 Location: United KingdomPosts: 311 |
Thankyou. This is very much appreciated. Dave. |
Thanks Peter, Now I read the list I realize how much improvements went into this release. This is Major. We are lucky to have such a dedicated sw developer.... Volhout PicomiteVGA PETSCII ROBOTS |
Great stuff! John |
| karlelch Guru Joined: 30/10/2014 Location: GermanyPosts: 368 |
Excellent! Thank you both - Peter and Geoff! Best Thomas |
Thanks Peter, thanks Geoff! Sorry I have to report a bug in the manual page 73 Actually it should be: MM.INFO(FILESIZE file$) That makes more sense too. BTW. the transfer speed (copy a: to a:) is 63.5 KB/s on my 16MB-Picomite (Clone). Best regards Michael |
Hi Peter, Thanks very much for this release, working fine, except for one problem I'm having. This is on a VGA. If you load my WS2812 PIO program below. 'PIO WS2812 driver on GP0 ' ' The PIO program ------------------------------------------------------------- 'Set GPIO to GP0, PIO no. 1 SetPin gp0,pio1 'configure the PIO sequencer clock and pin registers e0=Pio(execctrl GP0,1,4) p0=Pio(pinctrl 1,1,,,gp0,gp0,) 'GP0 side set, GP0 SET (for pindirs) f0=Pio(shiftctrl 0,0,0,1) 'Set Auto Pull at 32bits (0) fr0=5000000 '5MHz PIO frequency, lowest I could go with my pixels 'This code relies on AutoPull when all 32 bits have been read from X 'line Bin code comment '0 1110 0000 1000 0001 'set GP0 output, side(0), 'note GP0 is assigned in pinctrl '.wrap_target '1 0110 0002 0010 0001 'out x, 1bit, side(0), dly 1 or 2 or 1 'put one bit in x side set 0 '2 0001 0001 0010 0011 'jmp !x to 4, side(1), dly 1 or 1 or 1 'jump if not X (ie 0) side set 1 '3 0001 0004 0000 0000 'jmp to 1, side(1), dly 1 or 1 or 2 'jump to 1 side set 1 '4 1010 0004 0100 0010 'MOV Y to Y side(0), dly 1 or 2 or 2 'Nop delay side set 0 'wrap PIO program line 1,0,&hEF81 PIO program line 1,1,&h6121 PIO program line 1,2,&h1124 PIO program line 1,3,&h1101 PIO program line 1,4,&hA142 'PIO1.0 setup the machine. PIO init machine 1,0,fr0,p0,e0,f0,0 'LED data GRBG RBGR BGRB GRBG Dim Integer ct(3)=(&h00000100,&h00010000,&h01000001,&h00000100) 'The MMBasic program -------------------------------------------------------- Do PIO start 1,0 'start the PIO For b=0 To 86 PIO WRITE 1,0,3,ct(0),ct(1),ct(2) 'writes led colours to fifo Next PIO Write 1,0,1,&h00000000 ' Haven't worked out why I need this to flush? ct(3)=ct(0):ct(0)=ct(1):ct(1)=ct(2):ct(2)=ct(3) ' rotate the colours PIO stop 1,0 'stop the pio Pause 200 Loop While Inkey$="" End and run it, all works fine. If I Ctrl C out and run again I get various errors, like:- [9] e0=Pio(execctrl GP0,1,4) Error : Divide by zero or [9] e0=Pio(execctrl GP0,1,4) Error : 3 is invalid (valid is 0 to 1) If I edit the code and make any change, even a comment and re-run all is fine again for the first run, then errors after that. If I 'List' my program and then try to 'run' it I get:- Error: Invalid address - resetting my options are:- PicoMiteVGA MMBasic Version 5.07.06 OPTION SYSTEM I2C GP22,GP15 OPTION COLOURCODE ON OPTION KEYBOARD UK OPTION CPUSPEED (KHz) 378000 OPTION DEFAULT MODE 2 OPTION SDCARD GP5, GP2, GP3, GP4 OPTION AUDIO GP6,GP7, ON PWM CHANNEL 3 OPTION RTC AUTO ENABLE OPTION F6 Edit 1 OPTION F7 Edit 2 OPTION DEFAULT FONT 8, 1 Thanks for any help. Regards, Kevin. Edited 2023-01-08 04:17 by Bleep |
Thanks Peter and Geoff for all the time and brain power you have put into this. Also on VGA only PWM invert doesn't. > setpin 1,pwm > setpin 2,pwm > pwm 0, 67, 50, -50 same as pwm 0, 67, 50, 50 |
| jwettroth Regular Member Joined: 02/08/2011 Location: United StatesPosts: 86 |
Sincere thank you's for all your hard work- I've found these devices to be wonderful time savers for the kind of stuff that I do on a regular basis. In reading through the manual and other docs, I found a couple of minor items- 1. There are two of more references to the PIC32 in the Manual. Do a search. Not a big deal but a small confusion. 2. The explanation of how sound works in the background is somewhat confusing. Page 32- Play Tone 500,500,2000 End It makes some sense that this doesn't work. You then add the pauses- this I guess is still "non blocking" or is it? You go on to say just below that this applies to PLAY WAV as well. I would think that you'd use the interrupt in the original invocation to jump some where when that sound completed and the next should start. I'm going to play with this a bit tonight but I'm not sure its crystal clear what is going on. 3. I'm dying to play with the PIO stuff. I've played with this in the Python version and got it do some things. I'm an old assembly programmer so this really dear to me. I'll do some testing on the PIO stuff in the coming days. I'm going to try to hang a nice I2S DAC on it to play high fidelity sound. I'll post my results. This is a cool version- I like the internal file storage support as well as the very complete SD Card Support- wonderful. John Wettroth |
That will teach me to do last minute updates. Geoff has uploaded fixed versions to his site. You will know you have the new versions as the copyright is also updated to show 2023 Sound commands are non-blocking. The issue is that when a program ends with an END command or Ctrl-C it stops the audio output so unless you wait before exiting you will never hear anything. Likewise executing PLAY TONE twice in rapid succession will replace the first tone with the second such that the first may never be heard. Ending a program by "running off the end" without an explicit END statement will not stop the audio. Otherwise you would not be able to execute sound commands at the command prompt. Edited 2023-01-08 19:27 by matherp |
:-) :-) Been there, got the T shirt, all working great now thanks. :-) Kevin. Edited 2023-01-08 20:49 by Bleep |
@Peter I think I found a small bug regarding MM.Info(FILESIZE file$). I wanted to use it to determine whether a file exists. From manual: I would expect a return of -1 for a nonexistent file, but I get: Error : Could not find the file I know I could deal with "on error skip" and "mm.errno". I also know that there are two other ways to determine if a file_exists. MM.Info(MODIFIED fb$)="" and On Error Skip Open "file.txt" For Input As #1 If MM.ErrNo <> 0 Then ... Best regards Michael EDIT: I was surprised! Question regarding the copy command: Is it a desired behavior that files with the same name are not automatically overwritten/replaced, but have to be deleted first? Edited 2023-01-08 23:09 by twofingers |
@Peter I think there is a bug with the flashdisk the following code always leads to an error with a value di<>1: Open "test.dat" For random As #1 ' di=1 Seek #1, di l$=Input$(4, #1) Print l$; ' di=4 Seek #1, di l$=Input$(4, #1) Print l$; ' Close #1 [3] Seek #1, di Error : A hard error occurred in the low level disk I/O layer > [8] Seek #1,di Error : Could not find the file > |
Hi Peter, Sorry, another bug. :-( Using VGA with options:- PicoMiteVGA MMBasic Version 5.07.06 OPTION SYSTEM I2C GP22,GP15 OPTION COLOURCODE ON OPTION KEYBOARD UK OPTION DEFAULT MODE 2 OPTION DISPLAY 80, 160 OPTION SDCARD GP5, GP2, GP3, GP4 OPTION AUDIO GP6,GP7, ON PWM CHANNEL 3 OPTION RTC AUTO ENABLE OPTION F6 Edit 1 OPTION F7 Edit 2 OPTION DEFAULT FONT 8, 1 The Mode 1 screen is only 620 wide, height is good, similarly the Mode 2 screen is only 310 wide, as in, if I draw past these values they are off screen, the whole width seems to be stretched. Regards, Kevin. |
Check your monitor (auto adjust)- no issue for me the following code always leads to an error with a value di<>1: Trivial - will fix Trivial - will fix Edited 2023-01-09 04:41 by matherp |
| Page 1 of 6 |
