Forum Index : Microcontroller and PC projects : scale function
I have been testing a scale or map idea. Trying floats and integers. I am not good at sums but this is near accurate and you can mix floats and integers. This code scales 0 to 3.3 to 0 to 270.. for a dial, degrees. The final text is 3.39 270 so there is errors but rounding and what mmb does is beyond my capabilities. for next problem. I am trying to pass parameters to the sub. eg scale 0,3.3,0,270,vartoscale but do not from manual know how, arg1,arg2 It is interesting. Could it be useful? option explicit dim float sc_syscalc , sc_syscalcf , sc_fromHigh,sc_fromLow , sc_toHigh , sc_toLow , lim1 , sc_in',sc_out dim integer sc_out sc_fromLow=0 : sc_fromHigh=3.3 : sc_toLow=0 : sc_toHigh=270 'scale (0 to 3.3) to (0 to 270) cls for sc_in=0 to 3.3 step 0.01 scale text 0,0,str$(sc_in) text 48,0,str$(sc_out) ' lcd display ' pause 20 next sc_in do loop '-------------- sub scale 'the scale code sc_syscalcf = 0 lim1 = sc_toHigh - sc_toLow ' do while lim1 > 0 sc_syscalcf = sc_syscalcf + ( sc_in - sc_fromLow ) lim1 = lim1 - 1 loop ' sc_syscalc = (sc_fromHigh - sc_fromLow ) sc_out = ((sc_syscalcf / sc_syscalc) + sc_toLow) end sub |
If you can't handle the example(s) in the manual, maybe refer to the many examples which have been posted. John |
IMHO I should not need the many examples as the manual should explain it all ie real value examples not arg1.arg2 etc. which is open to misinterpretation ie does not explain sub parameters to me. Is that my problem when I try and the manual is my guide? I find other users code difficult to understand sometimes. I bet people do not understand my code either. This is just my take on a scale/map function. I looked in mmb maths and again I do not understand the arrays stuff for attempting scaling for a single value in one scale to another value in an other scale. The open source code I have tried to convert to mmb is useful for me for many applications as just a sub or even in line. If there is a better version a link would be helpful but not all example code is picomite non vga. stanno |
Using integers works. It was for no floats but try it with floats. Interesting. option explicit dim integer sc_syscalc , sc_syscalcf , scal_fromHigh,scal_fromLow , scal_toHigh , scal_toLow , lim1 , scal_in , scal_out 'scale (0 to 3300) to (0 to 270) scal_fromLow=0 : scal_fromHigh=3300 : scal_toLow=0 : scal_toHigh=270 cls for scal_in = 0 to 3300 scale text 0,0,str$(scal_in) text 48,0,str$(scal_out) ' lcd display ' pause 20 next scal_in do loop '-------------- sub scale sc_syscalcf = 0 lim1 = scal_toHigh - scal_toLow ' do while lim1 > 0 sc_syscalcf = sc_syscalcf + ( scal_in - scal_fromLow ) lim1 = lim1 - 1 loop ' sc_syscalc = (scal_fromHigh - scal_fromLow ) scal_out = ((sc_syscalcf / sc_syscalc) + scal_toLow) end sub |
You can think of the PicoMite VGA as being a LCD with a resolution of 320x240 16 colours in mode 2 or as 640x480 in mono colour when in mode 1. Just about everything else is the same. "Command <arg1>, <arg2>" only means that you have to include the arguments when you call it. It's not some strange magic. ;) The manual can't possibly include examples of everything you might want to do in MMBasic. All it can do is give you the tools - it's up to you to use them to solve your problem. If you are trying to convert to MMBasic from C or Python or some other BASIC then you first have to fully understand both the source and the capabilities of MMBasic. Some things won't convert directly and you may have to write blocks of code to replace single lines in the source - or it may work the other way. Mick Zilog Inside! nascom.info for Nascom & Gemini |
I am sorry, I have no idea what your SUB is trying to do but given the original problem, I would use a FUNCTION rather than a SUB. FUNCTIONs are best if you have one value to return. OPTION EXPLICIT OPTION DEFAULT INTEGER DIM temp AS FLOAT DIM Vin AS FLOAT FOR temp = 0 TO 100 STEP 10 PRINT scale(0,100,32,212,temp) NEXT temp FOR Vin = 0 TO 3.31 STEP 0.1 PRINT STR$(Vin,2,1), INT(scale(0,3.3,0,270,Vin)) NEXT Vin FUNCTION scale(fromLow!, fromHigh!, toLow!, toHigh!, in!) AS FLOAT scale = (toHigh!-toLow!)/(fromHigh!-fromLow!)*in!+toLow!-fromLow! END FUNCTION With a function, if a variable is declared in the parameters (argumentss) or as LOCAL in the function, the variable is treated as local and doesn't need to be DIMmed as a global. That makes code easier to manage. Jim VK7JH MMedit |
You are over thinking it. to re-scale a (0 to 3.3) variable to (0 to 270) just multiply it by 270 and divide by 3.3 Var270 = Var3.3 * 270 / 3.3 That's all there is to it. Don't use integers, they just mess up the division. The Pico does not have the limitations of an 8 bit chip, it's very capable, let it do the work. It only gets a little more complicated if the start of the ranges isn't zero. If you wanted to scale (0.3 to 3.3) to (30 to 270) Var270 = (Var3.3 - 0.3) * (270 - 30) / (3.3 - 0.3) + 30 |
but do not from manual know how, arg1,arg2 If you can't handle the example(s) in the manual, maybe refer to the many examples which have been posted. John IMHO I should not need the many examples as the manual should explain it all That is a ridiculous statement. The manual already does what almost anyone needs. No manual can ever do what you appear to want for any even moderately powerful language. If you can't handle that fact, you would be wiser to pursue another interest. Otherwise, put more effort in and in more sensible directions. E.g. write small bits of code and see how things work. But it's daft to ignore working code that others have freely posted. John Edited 2022-09-27 09:09 by JohnS |
Stan, can I please suggest that you read that section "Subroutines and Functions" again and experiment with some examples? Another good source of information is Geoff's "Getting Started with the Micromite" from https://geoffg.net/micromite.html. Yes, it's for the Micromite but is a good description of using MMBasic. Usually subroutines are used to perform tasks which are done several times in a program. Passing parameters (arguments) to them allows the subroutine to perform the same operation on different values. Try this: option default integer x = 1 y = 2 print x, y swap x, y 'swap the numbers print x, y swap x, y 'swap them back print x, y end SUB Swap a, b LOCAL t t = a a = b b = t END SUB The variables a, b and t are created for use by the subroutine and the variables x and y are passed by reference to the subroutine. If I read your program correctly, your 'subroutine' is only called from one place in the program and uses GLOBAL variables. If that is correct, it may as well be included in line in the main body of the program. (Talk about the blind leading the blind )Bill Keep safe. Live long and prosper. |
Stan, can I please suggest that you read that section "Subroutines and Functions" again and experiment with some examples? Another good source of information is Geoff's "Getting Started with the Micromite" from https://geoffg.net/micromite.html. Also the many examples Geoff has on his web site or has posted on this site, and of course Fruit of the Shed. Many languages use subroutines / functions in a very similar manner to MMBasic. It's hard to imagine someone who's used other languages hasn't already discovered that. John |
FUNCTIONs are best if you have one value to return. OPTION EXPLICIT OPTION DEFAULT INTEGER DIM temp AS FLOAT DIM Vin AS FLOAT FOR temp = 0 TO 100 STEP 10 PRINT scale(0,100,32,212,temp) NEXT temp FOR Vin = 0 TO 3.31 STEP 0.1 PRINT STR$(Vin,2,1), INT(scale(0,3.3,0,270,Vin)) NEXT Vin FUNCTION scale(fromLow!, fromHigh!, toLow!, toHigh!, in!) AS FLOAT scale = (toHigh!-toLow!)/(fromHigh!-fromLow!)*in!+toLow!-fromLow! END FUNCTION With a function, if a variable is declared in the parameters (argumentss) or as LOCAL in the function, the variable is treated as local and doesn't need to be DIMmed as a global. That makes code easier to manage. Jim Well Jim, that is almost exactly the MAP() function from Arduino. Just move the "in!" parameter as first argument and you are done..... MAP() in MMBasic FUNCTION map(in!, fromLow!, fromHigh!, toLow!, toHigh!) AS FLOAT scale = (toHigh!-toLow!)/(fromHigh!-fromLow!)*in!+toLow!-fromLow! END FUNCTION Edited 2022-09-27 17:14 by Volhout PicomiteVGA PETSCII ROBOTS |
Well Jim, that is almost exactly the MAP() function from Arduino. Just move the "in!" parameter as first argument and you are done..... MAP() in MMBasic FUNCTION map(in!, fromLow!, fromHigh!, toLow!, toHigh!) AS FLOAT map = (toHigh!-toLow!)/(fromHigh!-fromLow!)*in!+toLow!-fromLow! END FUNCTION I left it in stan's order. A slight correction. map = , not scale = Jim edit: MAP is used on the CMM2 for colour mapping so should be avoided. Edited 2022-09-27 17:50 by TassyJim VK7JH MMedit |
This is in demos Map() Function Modified on 2022/07/09 12:10 by CaptainBoing Categorized as Uncategorized » AFTER, EVERY, AT, REMAIN Flexible State Machine Timers using Semaphores. (MMBasic) » BLITDEMO.BAS (MMBasic) » Map() Function (MMBasic) Function maps a value in a given linear input range to it's counterpart in the linear output range. Often it is required to take a value in a specific range and "Map" it onto the equivalent value in some alternative range. e.g. a current measuring module might return a value in the range of 0-255 which corresponds to a current reading of 0-6Amps. The Map() function will take the measures value and the input/output ranges and return the equivalent value. The input value is constrained so that it conforms to the input range, i.e. if the lower limit is zero and a value of negative 5 is supplied, the value of zero will be used. Likewise the upper limit. Written to use Floats due to the likely nature of the application. Syntax: =Map(Value,InputRangeLowerLimit,InputRangeUpperLimit,OutputRangeLowerLimit,OutputRangeUpperLimit) Example: mAmps=Map(n,0,255,0,6000)'current in mA in the above, 0 to 255 is the measured value from the current sensor, 0 to 6000 is the equivalent current reading in mA Function Map(x As Float,rLo As Float,rHi As Float,oLo As Float,oHi As Float) As Float Map=((Min(Max(x,rLo),rHi))-rLo)*((oHi-oLo)/(rHi-rLo))+oLo End Function |
But it probably wasn't written for the CMM2, Stan. :) Be aware of the capabilities of your target machine. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Be aware of the capabilities of your target machine. It seems to works fine. OPTION EXPLICIT dim vdeg! vdeg=Map(3.3,0,3.3,0,270) cls text 0,0,str$(vdeg) do loop Function Map(x As Float,rLo As Float,rHi As Float,oLo As Float,oHi As Float) As Float Map=((Min(Max(x,rLo),rHi))-rLo)*((oHi-oLo)/(rHi-rLo))+oLo End Function |
to re-scale a (0 to 3.3) variable to (0 to 270) just multiply it by 270 and divide by 3.3 Var270 = Var3.3 * 270 / 3.3 That's all there is to it. Don't use integers, they just mess up the division. The Pico does not have the limitations of an 8 bit chip, it's very capable, let it do the work. It only gets a little more complicated if the start of the ranges isn't zero. If you wanted to scale (0.3 to 3.3) to (30 to 270) Var270 = (Var3.3 - 0.3) * (270 - 30) / (3.3 - 0.3) + 30 Late my reply but thanks. good idea. stan Would integers be ok for integers? Edited 2022-09-28 03:48 by stanleyella |
Would 3 divided by 2 times 2 yielding 2 be good enough for you? What's the fear of floats? If you're doing division, floats are your friend. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
but do not from manual know how, arg1,arg2 If you can't handle the example(s) in the manual, maybe refer to the many examples which have been posted. John IMHO I should not need the many examples as the manual should explain it all That is a ridiculous statement. The manual already does what almost anyone needs. No manual can ever do what you appear to want for any even moderately powerful language. If you can't handle that fact, you would be wiser to pursue another interest. Otherwise, put more effort in and in more sensible directions. E.g. write small bits of code and see how things work. But it's daft to ignore working code that others have freely posted. John "The manual already does what almost anyone needs No manual can ever do what you appear to want for any even moderately powerful language. If you can't handle that fact, you would be wiser to pursue another interest." Try it from a new users experience The sub explanation and using local vars and their explanation that they disappear when sub exits. The example map function in demos works and is simple to understand.. well for me. Can a sub be like a function as per passing parameters? vdeg=Map(3.3,0,3.3,0,270) Function Map(x As Float,rLo As Float,rHi As Float,oLo As Float,oHi As Float) As Float Map=((Min(Max(x,rLo),rHi))-rLo)*((oHi-oLo)/(rHi-rLo))+oLo End Function If it was map(a,b,c,d,e) as sub map how to implement. Are sub arg1.arg2 the same as a function? It is silly to try code that one does not know how it works and get meaningless error messages. If you want new users you got to have empathy. Learning a new system takes a while and some users use previous experience, not start at page 1, which is my point that the manual is organised in a way one has to jump from the info at the start to info near the end. I do not think I will pursue yet another interest. Is there a new use like me that finds the manual could be clearer? Edited 2022-09-28 05:14 by stanleyella |
| pwillard Guru Joined: 07/06/2022 Location: United StatesPosts: 347 |
Subs are like Functions but you don't get a return value. A SUB will just act on what it is given or that it can gather based on what you have it doing. Here is what I do... I printed the PICOMITE manual... and I keep a copy of it on my nightstand and then read it before I fall asleep. Edited 2022-09-28 04:57 by pwillard |
A SUB will just act on what it is given or that it can gather based on what you have it doing. Here is what I do... I printed the PICOMITE manual... and I keep a copy of it on my nightstand and then read it before I fall asleep. I watch tv and have the manual pdf on a monitor next to me and mix the both for all evening. I copy and collate parts that are of special interest and test them on a breadboard. It was nice guy on this forum that pointed out using read data that you do not use data just read. I just used the manual but misinterpreted the info was getting nowhere. |
