Local Time 06:48 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite: serial I/O (from MMB4L)
Posted: 09:21pm 04 Jan 2022
Hi folks,
Finally back trying to finish alpha 3 of MMB4L.
I'm using a PicoMite to test MMB4L's serial I/O and have it working (as far as I can tell) where MMB4L talks to the PicoMite over the latter's serial console.
I'm now moving over to talking to the PicoMite via its COM ports and *think* I have found a bug on the PicoMite.
This is the transmit code running on MMB4L:
' MMB4L code to continuously transmit lines containing "Hello World".
Option Base 0
Option Default None
Option Explicit On
Open "/dev/ttyUSB0:9600" As #1
 Print #1, "Hello World"
This is the receive code running on the PicoMite:
' PicoMite code to receive data via serial I/O and echo to console.
Option Base 0
Option Default None
Option Explicit On
SetPin GP1, GP0, COM1
'Open "COM1:9600" As #1            ' (1) Prints "Hello World" continuously - OK
'Open "COM1:9600,256,foo,1" As #1  ' (2) Prints "foo" or "Hfoo" and ends   - OK
Open "COM1:9600,256,foo,2" As #1   ' (3) Prints "Hello World" continuously - BUG?
Dim ch$
 ch$ = Input$(1, #1)
 Print ch$;
Close #1
Sub foo()
 Print "foo"
 End
As you can see from the code comments I think there is a PicoMite BUG with case 3 where the interrupt trigger is 2 characters, am I correct or is there something I am missing ?
Edited 2022-01-05 07:34 by thwill
Posted: 10:31pm 04 Jan 2022
I think not a bug.
It never sees 2 buffered chars because you keep removing at least 1.
Posted: 10:53pm 04 Jan 2022
If you put a delay in your DO LOOP,
there will be sufficient time for the second character to accumulate.
Any serial is slow. 9600 if bloody slow.
Edited 2022-01-05 08:54 by TassyJim
Posted: 11:28pm 04 Jan 2022
Thanks, I now understand both how it works and what the intended use case is.
This description in the manual confused me:
  picomite-manual said  'int-trigger' is the number of characters received which will trigger an interrupt.
i.e. no explicit mention of it being the number of characters in the buffer, just the "number of characters received".
Expect more queries,
Edited 2022-01-05 10:08 by thwill
Posted: 08:16am 05 Jan 2022
Would be better if re-worded.
Posted: 09:47am 05 Jan 2022
Can anyone tell me how I configure two stop-bits or even parity without an interrupt on the PicoMite, the following both report "Syntax error":
Open "COM1:9600,1024,,256,S2" As #1
Open "COM1:9600,1024,,256,EVEN" As #1
Posted: 09:59am 05 Jan 2022
From the manual
  Quote  Opening a serial port specifying the baud rate (9600 bits per second) and receive buffer size (1KB):
OPEN "COM2:9600, 1024" AS #8
The same as above but with two stop bits enabled:
OPEN "COM2:9600, 1024, S2" AS #8
Posted: 10:06am 05 Jan 2022
  matherp said  From the manual ...
D'Oh! that's what comes from not having a printed manual to obsessively read. The problem is printed manual's for the CMM2 and PicoMite are out-of-date before they arrive.
Thank you Peter,
Posted: 10:14am 05 Jan 2022
Hi Tom,
You specified there should be an interrupt trigger after 256 characters. But when you do not specify the interrupt routine, you get a syntax error.
SetPin GP13,GP16,COM1
Open "COM1:9600,128,do_it,16,even,s2" As #1
Close #1
Sub do_it
The picomite user manual can be found at Geoff's website...
All about picomite
See appendix A of the manual
Edited 2022-01-05 20:15 by Volhout
Posted: 10:30am 05 Jan 2022
Hi Volhout,
  Volhout said  You specified there should be an interrupt trigger after 256 characters. But when you do not specify the interrupt routine, you get a syntax error ...
That's because I had mistakenly persuaded myself I needed to specify all the arguments and that an empty interrupt argument would mean no interrupt irrespective of the trigger - it will in MMB4L .
  Quote  The picomite user manual can be found at Geoff's website...
I have it, and had read Appendix A, though it appears I haven't succeeded in remembering much of it .
Posted: 02:07pm 05 Jan 2022
PicoMite bug or (another) user failure ?
> ? MM.Info(Device)
PicoMite
> ? MM.Info(Version)
5.0703
> List "bug.bas"
Option Base 0
Option Default None
Option Explicit On
Close #1
Close #1
End
> run "bug.bas"
[9] Open "COM1:9600" As #1
Error : Pins not set for COM1
Obviously this is a much reduced version of some code which had a reasonable purpose behind closing and reopening a serial port.
Posted: 02:13pm 05 Jan 2022
  Quote  or (another) user failure ?
Yep. Close releases the pins from their function. Otherwise there would be no way to re-use the pin in a program. Same for SPI, I2C, PWM
Posted: 02:24pm 05 Jan 2022
Right you are.
Thanks again,
Posted: 02:55pm 05 Jan 2022
Debate-able,
I am in line with Tom. The Setpin command attaches the pins to the UART.
Opening and closing the UART communication should not detach the pins from the UART.
Only way to detach the pins from the UART should be a new Setpin command.
Reason I respond to this "not really trivial" discussion is that I just discovered that our software partner did the same in a machine. And by freeing up the pins the serial communication channel went bazurk (crazy) by a stream of BREAK characters every time they opened and closed the UART communication.(*)
As long as the pins remain attached to the UART they will remain in idle state. Not BREAK.
RESET is a different situation...
(*) system communicating baudrate x and datatransfer baudrate y was implemented opening and closing the UART communication.
Posted: 03:06pm 05 Jan 2022
  Quote  Only way to detach the pins from the UART should be a new Setpin command.
Feel free to write it. Only a couple of hundred lines of complex C to support UART/SPI/I2C/PWM/IR and whatever I've forgotten.
Whether rightly or wrongly the PicoMite supports very flexible pin allocation and this will always have positives and negatives. Detaching the pins puts them back in tristate mode so all that is needed is a pullup resistor to avoid the issue you identify. Not everything has to be solved in software
Edited 2022-01-06 01:06 by matherp
Posted: 03:18pm 05 Jan 2022
Hi Peter,
Understood ! And yes, a pullup/down would have been required anyway, as to satisfy the initial signal levels before the UART is opened.
Posted: 03:59pm 05 Jan 2022
Can I short-circuit several days of research and code-diving on the PicoMite (or at least get a pointer as to where specifically to look) and ask:
- What is supposed to happen if you send/receive an 8-bit character, e.g. Chr$(129) when the port is configured as 7BIT ?
- If ODD or EVEN parity is set then what happens / where is the code for if the parity check fails ?
Thanks in advance,
Posted: 04:21pm 05 Jan 2022
AFAIK The Picomite SDK doesn't implement parity checking.
Incorrect chars may give a framing error and be binned but who knows?
Posted: 05:17pm 05 Jan 2022
Do any of the 'mites implement parity checking ?
Posted: 05:31pm 05 Jan 2022
Not by me. but the H/W may throw a error interrupt which is then serviced and discarded
