Local Time 07:20 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite 5.07.00 - Bug Reports
     Page 1 of 4
Posted: 07:07am 27 Oct 2021
I'm a bit concerned that we may miss bugs due to the many threads on the PicoMite, so:
Please post bug reports for this version here.
Try to include a bit of example code that illustrates the bug.
You can also post inaccuracies in the manual here.
Do not post suggestions for new features or for additions to the manual.
Posted: 07:28am 27 Oct 2021
I don't know if this has been addressed:
robscott:
doing some testing on V5.07.00b30, and wondering if there is a reason BITBANG WS2812 is limited to 64 LEDs
the 1st 64 LEDs work fine, but when I go to 256 in my array
Bitbang ws2812 B,gp0,256,l%()
Error : 256 is invalid (valid is 1 to 64)
I see in External.c
nbr=getint(argv[4],1,64);
it's max at 64, but I have a 256 grid WS2812B panel I would like to drive
I see interrupts are off, so maybe you were worried about the total delay ?
robscott
Posted: 01:25pm 28 Oct 2021
Thanks Mick for this thread;
Spotted an issues in the current 5.07 manual
Page 116
GPS(FIX) is a copy of GPS(DOP)
GPS(DOP) Returns DOP (dilution of precision) value (if sentence GGA is enabled).
GPS(FIX) Returns DOP (dilution of precision) value (if sentence GGA is enabled).
looks like GPS(FIX) is 0 or 1 , depending on whether the GPS has lock the position
Update:
Looks like the doc should read
Fix Denotes the Quality Indicator:
1 = Uncorrected coordinate
2 = Differentially correct coordinate (e.g., WAAS, DGPS)
4 = RTK Fix coordinate (centimeter precision)
5 = RTK Float (decimeter precision.
Rob
Edited 2021-10-29 00:33 by robscott
Tinine
Posted: 03:50pm 28 Oct 2021
Posted: 11:26pm 28 Oct 2021
Thanks guys.  I will update the manual.
robscott
Posted: 04:12pm 29 Oct 2021
N5110 Graphic display issue
Last BOX Graphic command does not finish clearing the buffer and closing the box
missing data will be written with next graphic command
for example
Box 20,20,40,40
draws an open box, lower right of box not closed
(Graphic not completed)
PIXEL 0,0
closes the box
also
Circle 10,10,5
closes the box
(any graphic command)
Update:
PIXEL Command is also effected (or maybe its the base command with issues)
from command line;
CLS
pixel 10,10 - Nothing drawn ( no pixels on )
pixel 20,20 - 10,10 pixel drawn ( 1 pixel on )
pixel 30,30 - 20,20 pixel drawn ( 2 pixels on )
pixel 0,0 - 30,30 pixel drawn ( 3 pixels on )
pixel 0,0 - 0,0 pixel drawn ( 4 pixels on)
so draw doesn't happen until the following graphic command
(issue must be , data in buffer, which is release when the command starts)
Rob
Edited 2021-10-30 02:58 by robscott
Posted: 09:20am 30 Oct 2021
  Quote  so draw doesn't happen until the following graphic command
Just tested with V5.07.00 binary and can't replicate, everything works perfectly. Please reflash and try again.
OPTION SDCARD GP15
OPTION LCDPANEL N5110, LANDSCAPE,GP7,GP8,GP9, 177
One thought - have you got CE on a pin or hardwired?
Edited 2021-10-30 19:32 by matherp
robscott
Posted: 01:47pm 30 Oct 2021
My CE was Hardwired to GND
100% confirmed that was my issue (CE to GND)
( tested both ways, as did you I'm sure )
without CE on proper pin, display works, but not correctly
NO CODE ISSUE, Works correctly, NO BUG
Thank You
Rob
karlelch
Posted: 07:41am 31 Oct 2021
Command stacking
I like this feature a lot, but there seems to be some problem when the cursor is moved and the command is edited. If one goes back with the cursor and deletes/inserts characters, they appear at the wrong position and what one sees in the line is not what is given to the interpreter when pressing Enter. Looks like a simple indexing offset.
Posted: 08:16am 31 Oct 2021
  Quote   like this feature a lot, but there seems to be some problem when the cursor is moved and the command is edited. If one goes back with the cursor and deletes/inserts characters, they appear at the wrong position and what one sees in the line is not what is given to the interpreter when pressing Enter. Looks like a simple indexing offset.
This happens if the window of the terminal emulator is less than 80 characters wide. Please ensure this is the case and try again
karlelch
Posted: 10:36am 31 Oct 2021
Hmm not sure. I use TeraTerm, it is set to 64 lines w/ 80 characters.
In MMBasic, I used `option display 64, 80`.
Here is an example of what mean:
> print 1,2,3
1       2       3
Now I retrieve the previous line with the up key and press backspace; this is how it looks then:
>print 1,2, 3
1       2
Next, I again get the previous line back and type 444, and here is the result:
> print 1,2444
1       2       444
Still, it is possible then I have some TeraTerm setting wrong.
Posted: 10:49am 31 Oct 2021
I can't replicate so I can only suspect something else in the teraterm setup.
You could try the attached to see if it makes any difference
PicoMite.zip
karlelch
Posted: 11:02am 31 Oct 2021
Yes, now it works as expected! Thanks.
Previously, I had tried the latest release and the latest beta from  Geoff's website.
Posted: 08:17am 01 Nov 2021
The PicoMite manual is missing the following command in the command listing
BACKLIGHT n, n=0 to 100
This is however fully covered on page 43
Pages 41 and 42 should also be updated to show the optional parameter on the relevant displays ILI9163, ILI9341, ST7735, ST7735S, SSD1331, ST7789, ILI9481, ILI9488, ILI9488W, ST7789_135 and ST7789_320
Calli
Posted: 08:26am 01 Nov 2021
Ohhh! Wondered about it myself. Checked and my Term was 80x40. Did not work. Now using 81x40 and it works :)
Best,
Carsten
electricat
Posted: 11:28am 01 Nov 2021
PicoMiteV5.07.00 (downloaded from Geoffg.net site)
In editor i write some lines, pres F1, says saved xx bytes.
Power off, and there is no saved program in flash  1
If after exiting F1>> editor >>F1 i manually  FLASH SAVE 1 , then it will be stored ok but still after F4>> some edit >> F1, saved xx bytes >> Power off , still no saved editions.
If after edited something I press F1, then says saved xx bytes... if I try FLASH SAVE 1, says error already programmed If I power cycle, still no edited saves.
I believe, If I do FLASH SAVE 1 it should be owervriten according to my wish in any case ?
What I am missing? or it is some bug
My MMBasic 'sand box'
Posted: 12:44pm 01 Nov 2021
It's a case of terminology, I think, not a bug.
When you press F1 while in the Editor and it says "Saved xx bytes" it means that the Editor has passed those bytes back to the runtime system. The Editor then closes. It doesn't mean that those bytes have been saved anywhere else.
The user can then use FLASH SAVE n to save the program currently in the runtime area to flash memory slot n.
If there is a SDcard connected then you can use SAVE "filename" at this point.
If you want to replace the program in a flash memory slot you use FLASH OVERWRITE n, when the current contents of that slot will be replaced by the program in the runtime area. You can't use FLASH SAVE n consecutively on the same slot.
Posted: 01:01pm 01 Nov 2021
F1 saves the program in a separate bit of flash memory. If you power off and then on the program will still be there. No need to use FLASH SAVE unless you want more than one program. See page 12 of the manual
electricat
Posted: 02:24pm 01 Nov 2021
yes, yes Mixtel90... bug is something in between relay contacts ;)
matherp I`ve seen manual page 12 of course.
I understand logic beyond all of this, However for me something is going wrong.
I tried it after fresh firmware upload.
I tried use so called nuke firmware to erase pico flash completely as this board was flashed python before. No external hardware connected.
As I said for example while in freshly flashed pico board I edit program, then save it by pressing F1 and it must be stored in FLASH area 1 right ? It says saved bytes xx. and if FLASH LIST I see it`s occupied 1 by program.
Then I power off pico board (removing from USB), power on (put into USB) connect via tera term... and... no. There is no program I wrote before. Only if I use FLASH SAVE 1 it will be there on next boot and will start by option autorun 1.
I will try wirgin pico board, but ideas whats going on are wlcome
Posted: 02:40pm 01 Nov 2021
  Quote  and it must be stored in FLASH area 1 right ?
No. It is actually stored in flash area 11 and this is automatically restored to RAM on power up.
If you have autorun set 1 this will then overwrite the program and load whatever is in 1 which won't be what you just edited
To automatically run the program in 11 just use OPTION AUTORUN ON
Suggest you set OPTION AUTORUN OFF to start with so you can see what is actually happening. Make sure you are not also setting autorun in a program
     Page 1 of 4
