Local Time 08:15 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Memory map?
     Page 1 of 3
alynna
Posted: 06:57pm 06 Oct 2021
Can I get a memory map, including IO registers, of the CMM2?  Also I sent a request in to be able to look at the source for MMBasic (I would like to add some additional functions), but I have not received it yet.
Posted: 07:30pm 06 Oct 2021
Hi @alynna,
I think you're asking a question that might have had a simple answer for a real 8-bit computer, but the CMM2 is actually a 32-bit microcontroller and you are likely to be directed to the datasheet (there is a misnomer given it is a big document) and firmware code, which I'm sure Geoff will email you about when he has done time.
Posted: 07:43pm 06 Oct 2021
  alynna said  Can I get a memory map, including IO registers, of the CMM2?  Also I sent a request in to be able to look at the source for MMBasic (I would like to add some additional functions), but I have not received it yet.
The ld input from here is basically a memory map.
The datasheet for the CPU (STM32H743 / STM32H753) is on ST's site.... and it's big.
There are related documents it references, too.
Posted: 08:09pm 06 Oct 2021
As with most microcontrollers, messing with the memory map isn't something you play with - it breaks things very quickly. :)  That doesn't mean it's impossible, but it's not recommended.
If you are thinking of peeking & pokeing variable space then the tools are there in MMBasic. You can also effectively peek and poke a string of bits that can be a nibble, byte or word.
alynna
Posted: 08:12pm 06 Oct 2021
  thwill said  Hi @alynna,
Ok found the memory map, by that I mean the hardware description and register map ... 3319 pages.. DAYAM.  Kind of puts the C64 programmers reference in perspective.
And I've been sent the source too now.
I noticed the STM32 (including the ones on our boards) have an Ethernet MAC on it.  Are the pins conveniently accessible?
Posted: 08:15pm 06 Oct 2021
  alynna said  Also I sent a request in to be able to look at the source for MMBasic(I would like to add some additional functions)
MMBasic is so fast you can probably just write them in it.
Edited 2021-10-07 06:15 by JohnS
alynna
Posted: 08:27pm 06 Oct 2021
  Mixtel90 said  As with most microcontrollers, messing with the memory map isn't something you play with - it breaks things very quickly. :)  That doesn't mean it's impossible, but it's not recommended.
I am definitely thinking of peeking and poking into the hardware register space (Apparently between 0x40000000 and 0x5fffffff).
I am also considering writing an assembler in MMBasic that will spit out CSub modules that can be called after assembled and do things... faster.
I absolutely love the idea of having a machine that is 32 bit, fast, and yet I can hit low level hardware stuff.  And write machine code for.
Edited 2021-10-07 06:29 by alynna
alynna
Posted: 08:34pm 06 Oct 2021
https://microcontrollershop.com/product_info.php?cPath=98_322&products_id=3625&osCsid=v34t2o38t62ne7j8729aj0ttp1
Also I want to implement the above.  I see no reason why, using that, I could not create a TCP/IP stack in MMBasic.
twofingers
Posted: 08:41pm 06 Oct 2021
Hi,
  Quote  Can I get a memory map ...
maybe Rubens thread helps a little.
Michael
alynna
Posted: 09:07pm 06 Oct 2021
So I have MMBasic in the STM32CubeIDE.  I have more questions.
Are functions and commands in the form of
cmd_xxx
and
fun_xxx
parsed by a preprocessor to become BASIC tokens, or is there a table to add new commands to somewhere.
Does the CMM2 have a Discord or a Slack where these kinds of questions can be answered without cluttering up this board?
Yes, I do know C.  And some ARM assembler.  Enough of the latter to get dangerous.
Posted: 09:46pm 06 Oct 2021
You need to talk to matherp and Geoffg regarding the workings of MMBasic. You also need to be aware that it's released under licence and that you aren't allowed to release modified versions of the code without permission.
MMBasic for the CMM2 stores the BASIC program as an ASCII file on the SDcard. It is tokenized into RAM when a RUN command is given. At this point it overwrites the RAM used by the editor. When the editor restarts it overwrites the RAM used by the tokenized program and variables.
Because of the way in which MMBasic works there may be limits on how many commands and functions can be built into the software. I don't know the limits for the CMM2 version.
AFAIK all MMBasic discussion takes part on this forum.
alynna
Posted: 09:59pm 06 Oct 2021
  Mixtel90 said  You need to talk to matherp and Geoffg regarding the workings of MMBasic. You also need to be aware that it's released under licence and that you aren't allowed to release modified versions of the code without permission.
I was planning on sending him back my changes so that he could release them as new versions. :)
Posted: 10:00pm 06 Oct 2021
Maybe just read the source :)
Posted: 10:04pm 06 Oct 2021
There is a table that new functions and commands are added to, grep is your friend.
You might also find it helpful to start by looking at the much simpler Windows/DOS MMBasic source code where it is easier to see the wood for the trees and then build up to looking at the CMM2 source.
Edited 2021-10-07 08:05 by thwill
alynna
Posted: 10:58pm 06 Oct 2021
  thwill said  There is a table that new functions and commands are added to, grep is your friend.
Nah, I've worked on more complex things before (I also know Verilog..).  I have figured out how to make new commands and functions and started with:
inp(<type> <addr>): Retrieves data from the hardware registers
out <type>, <addr>, <value>: Modifies hardware registers.
inp and out were traditional on Z80 BASIC where the I/O ports were off the memory bus.   Addresses are offset by REGBASE (0x40000000) and limited from 0x0 to 0x1FFFFFFF.
alynna
Posted: 11:49pm 06 Oct 2021
So now this is a thing:
> list
?"Inp() and Out example."
RNGBASE% = &H08021800
?"RNGBASE Registers are at " hex$(RNGBASE%)
RNGCTRL% = RNGBASE%
RNGSTATUS% = RNGBASE% + 4
RNGDATA% = RNGBASE% + 8
'Activate true RNG
out word RNGCTRL%,4
for j=1 to 64
 'Wait for ready
 do: loop until inp(word RNGSTATUS%) mod 2)
 ?right$("00000000"+hex$(inp(word RNGDATA%)),8),
 if not(j mod 4) then ?
next
> run
RNGBASE Registers are at 8021800
A504E788        05DA23C7        6600402D        6BDEB523
8EF55AE9        A069EEC4        12D593D5        079ECAC3
4FE15A9B        EAB0BE88        8E089FCD        87D707C3
14B92B37        BFD23E4D        A3C943C6        D0B1EED6
6F4AA1CD        3211AFE4        345AF8EA        D0544CCF
0416331A        A4831831        D2196D9D        A6D65EF3
2843420F        B9B9FF09        0B43B26E        193C2FC3
930E67C3        5D47BDD2        B42D4516        C80E0083
3A5BFCF3        8F056B13        F3FEF826        3C1D5270
4C0ED776        BAD0B25C        FF150590        514B80EA
20917F8B        7F2DB797        15D9054E        38874A75
107DBD4F        DDF548EB        A6D386D8        A75C9516
4DCE1FC9        8BB205F2        FD9A0DE3        4D5D746C
0EF59B9D        1FF17315        57676517        8B4A653C
03FD6AED        08EDE010        5DC692FB        310F922E
27D50444        1B09C399        A7A056A0        AAC919ED
alynna
Posted: 05:49am 07 Oct 2021
How do I contribute back to MMBasic?
I made a new thing.
> list
'Make some variables for the heck of it
tails = 6
fox$ = "The quick brown fox jumped over a lazy dog."
g! = 4.669201609
dim a$(10)
'Memory report!
?"Program memory size:"    tab(30) mem(progsize)
?"Program lines:"          tab(30) mem(proglines)
?"Variable memory size:"   tab(30) mem(varsize)
?"Variable count:"         tab(30) mem(varcount)
?"String var size:"        tab(30) mem(stringsize)
?"Total flash memory:"     tab(30) mem(flashsize)
?"Saved variable size:"    tab(30) mem(fvarsize)
?"Saved variable count:"   tab(30) mem(fvarcount)
?"Font memory size:"       tab(30) mem(fontsize)
?"Font count:"             tab(30) mem(fontcount)
?"C Function memory size:" tab(30) mem(cfuncsize)
?"C Function count:"       tab(30) mem(cfunccount)
?"Heap size:"              tab(30) mem(heap)
?"Total memory:"           tab(30) mem(total)
?"Used memory:"            tab(30) mem(used)
?"Free memory:"            tab(30) mem(free)
> run
Program memory size:          767
Program lines:                22
Variable memory size:         3328
Variable count:               4
String var size:              3072
Total flash memory:           524288
Saved variable size:          0
Saved variable count:         0
Font memory size:             0
Font count:                   0
C Function memory size:       0
C Function count:             0
Heap size:                    2816
Total memory:                 5472000
Used memory:                  6911
Free memory:                  5465089
Edited 2021-10-07 16:16 by alynna
Posted: 06:28am 07 Oct 2021
Why couldn't mem just be a csub?
Maybe it would be better that way.
alynna
Posted: 06:50am 07 Oct 2021
  JohnS said  Why couldn't mem just be a csub?
How? Is there some issue with contributing to MMBasic I don't know about?
Posted: 07:35am 07 Oct 2021
You'll have to ask Geoffg that, not us. MMBasic is his baby. :)
matherp has done a lot of porting to other platforms and has added a lot of functionality. He puts in a hell of a lot of (very much appreciated!) work maintaining MMBasic across several platforms. It will now run happily on a PIC chip (from 28-pin up), a RP2040 or an ARM Cortex. (I must have forgotten something...)
If something will work on CMM2 but not on PicoMite or F4, for example, because of processor differences then it's possible that the idea may be rejected for compatibility reasons. At register level the platforms vary a lot but MMBasic has to remain more or less a constant. There are variations, but core commands tend to remain the same (or there is some form of easy adaptation or work-around).
Bear in mind what MMBasic is about - it emulates using a 1980's home computer, but with a more modern BASIC and a few bells and whistles. If an idea deviates from that then it needs serious thinking about. Would you expect a C64, Speccy or Amstrad user to be happy using inp() and out all that much? How would you keep the addresses constant on all platforms so that BASIC programs remain compatible?
Edited 2021-10-07 17:38 by Mixtel90
     Page 1 of 3
