Forum Index : Microcontroller and PC projects : I2C Support needed
| Page 1 of 3 |
| Poppy Guru Joined: 25/07/2019 Location: GermanyPosts: 486 |
Hi all around. Could somebody please give me a simple but working "Hello World" like this but in MMBASIC https://www.hackster.io/newproject/how-to-use-lcd-i2c-30bbf0 my LCD-Adress also is "27" Being so easy for Arduinos I am really stucked right here. Andre ... such a GURU?![]() | ||||
EDIT: erased, I have misread the question, I do not have a I2C LCD. Edited 2021-09-28 21:09 by Volhout PicomiteVGA PETSCII ROBOTS |
Thanks, I will check it out! ![]() Andre ... such a GURU?![]() | ||||
But wait, this is not the I2C access to it, just the parallel way. Andre ... such a GURU?![]() | ||||
I am just running such a module on a 16X2 LCD https://andjey.info/wp-content/uploads/2021/03/arduino-i2c-module-1024x486.jpg the successfully scanned address is "27" Andre ... such a GURU?![]() | ||||
I think this should work, in theory. :) I've not tested it on the PicoMite, but I found it among some stuff that I'd saved. SETPIN gp0, gp1, I2C 'SDA is GP0, SCL is GP1 'Initialise LCDI2C_Init(&h27) Do LCDI2C 1,3,Date$ LCDI2C 2,4,Time$ Loop EDIT: Ah! Hang on... The PicoMite doesn't support I2C serial text displays in firmware. The above requires LCDI2CLib to be installed. I found it on this forum somewhere - it's pretty old. It was first posted here: https://www.thebackshed.com/forum/ViewTopic.php?TID=6715&PID=70291#70291#70291 . . . Edited 2021-09-28 22:36 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
I used a 128x64 I2C LCD instead of 16x2, but there's I2C code for it in the sensors.zip file. For that, OPTION LCDPANEL SSD1306i2c,L was needed. I don't see that 16x2 I2C is supported (but I may be missing something). Edited 2021-09-28 22:43 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
My link didn't work. :( https://www.thebackshed.com/forum/ViewTopic.php?TID=6715&PID=70291#70291#70291 Completely different beastie, lizby. Poppy has a text display, not a graphic one. Edited 2021-09-28 22:39 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
Exactly, just a text display those having a HD44780 Controller. And it is not a Picomite, just a CMM2 Gen 2 (Vers.: 5.07.01) I am just getting no access to this issue so therefore I need some basic support for finding the first step. Andre ... such a GURU?![]() | ||||
You'll need the library that I mentioned. Have a look through that thread - I think it got up to about version 7 but you may not need all the facilities. Just load the library and have a look through it - it's only MMBasic and well commented. Have a look at the CMM2 manual in Appendix B (I think) on I2C communication. That should help in opening & closing an I2C channel. You probably won't be able to use the version in the library because that was written for the micromite. I'll have a look round - I *think* I had a text I2C display running on a PicoMite at one stage. It'll be very similar to the CMM2, probably only setting up the I2C will be different. EDIT: I can't test this at present, but I think it will run "as is" if you change Sub LCDI2C_Init() to use I2C OPEN 400,100 instead of I2C1 OPEN 400,100. i2c1 1602.zip Edited 2021-09-28 23:36 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
F++++ck! Forum is bothering me out, cannot answer! Andre ... such a GURU?![]() | ||||
No chance for longer replies! Andre ... such a GURU?![]() | ||||
Try pasting from Notepad. It might work... Mick Zilog Inside! nascom.info for Nascom & Gemini |
Nope, pasting NEVER works for me at least. I already tried to do it with plain text, does not matter. After the error appeared once I cannot do anything about it and the finished text is lost. This has been for several months already, so nothing new. Since the new setup of the forum. Andre ... such a GURU?![]() | ||||
So it is still a pure matter of luck to post succesfully or not. Long postings are always risky to get invalidated. Shorts as well, but they can be typed again easily. Andre ... such a GURU?![]() | ||||
Oh! I wasn't aware that the forum setup had changed. :( Mick Zilog Inside! nascom.info for Nascom & Gemini |
Forum setup did change eliminating some possibly hostile or corrupting character combinations, but I don't know why plain text copied from notepad without any special characters should fail--it doesn't for me. Lengthy text copies from other sources I usually pass through notepad first to eliminate the problem. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
I usually type a relatively short message, and post it. (Long messages also time out). And then I edit until I have achieved the total message (do not refresh the page, becuase if someone adds a post after you, the edit function disappears). But (and this happened to me in post #2 of this thread) sometimes people already read the incomplete short message and act on it. That is most unwelcome. Pasting from notepad (windows) and leafpad (linux) works for me. Not sure why yours does not. Never tried pasting from Word, since it may throw a lot of formatting info. Edited 2021-09-29 01:02 by Volhout PicomiteVGA PETSCII ROBOTS |
Would Poppy's German keyboard (I assume) send illegal code combinations for normal ASCII characters? I wouldn't have thought so. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Good point it is a Microsoft-Keyboard PS: I just corrected my rejected posting and it went through new experience for me still some tasks to check up Edited 2021-09-29 01:47 by Poppy Andre ... such a GURU?![]() | ||||
| Page 1 of 3 |
