Local Time 12:24 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Overclock to 504MHz?
Posted: 10:20am 26 Jan 2021
Please try V5.07.00b8
In the spirit of hackers everywhere this version has the ability to overclock the CPU to 504MHz for both 400 and 480 MHz models. It may not work for you but it works reliably on the 4 CMM2 I've tested (2 Waveshare and 2 Singleboard)
To enable the overclocked mode put a link between pins 37 and 39 and then power on or reset the processor. You can then remove the link.
Use MM.INFO(CPUSPEED) to confirm the new speed
If it doesn't work simply remove the link and reboot. Use at your own risk!!!!
It is interesting that the 400MHz part has much more headroom for overclocking and this is something ArmmiteH7 users have had available and been doing for some time
504MHz is the highest speed, compatible with creating the USB clock, that I see as reliable on all the processors I've tried so far.
Edited 2021-01-26 20:24 by matherp
MauroXavier
Posted: 11:28am 26 Jan 2021
Did you notice any temperature increase in the 400 Mhz CPU?
I'm thinking it's a very good idea, but I want to take some precautions, such as placing a heat sink if necessary.
Did you get some random crashes or something like that in some version of the CPU?
I'm sorry to bother you with these questions but is that if the overclock proves to be stable, I can really enjoy the speed gain positively.
jirsoft
Posted: 11:44am 26 Jan 2021
I first thought to overclock my slower CMM2 to 480 MHz to have both with the same speed, but until everybody has the faster (overclocked?) version, is good for me to be able to test my apps also with slower version.
Anyway, it will be nice to have possibility to just overclock to 480 MHz...
Jiri
Plasmamac
Posted: 11:48am 26 Jan 2021
Iam seaching for a  Stresstest program
Plasma
Posted: 12:47pm 26 Jan 2021
  Quote  Iam seaching for a  Stresstest program
The CMM2 sits in a tight loop at full speed at all times so there is little you can do to stress it more. Possibly the only thing is to run something with lots of FP
here is what I use to stress everything. You need a suitable picture and some mp3 files on the disk to run it (mp3 decoding use FP)
Mode 1,12 has a memory bandwidth of 115,200,000 bytes per second continuous
Print "MMBASIC benchmark (C) KnivD 2016"
mode 1,12
play mp3 ""
load jpg "tiger-3"
page write 1
List commands
List functions
Dim integer t, i=0
Dim float x(1000), f=0.0
Dim string s=""
Print "Calculating... ";
s=""
f=0.0
i=0
Timer =0
Do While Timer<30000
 i=i+2 : f=f+2.0002
 If (i MOD 2)=0 Then
   i=i*2 : i=i\2
   f=f*2.0002 : f=f/2.0002
 EndIf
 i=i-1
 For t=1 To 100
   f=f-1.0001
   If (f-Int(f))>=0.5 Then
     f=Sin(f*Log(i))
     s=Str$(f,6,6)
   EndIf
   f=(f-Tan(i))*(Rnd(0)/i)
   If Instr(s,Left$(Str$(i),2))>0 Then s=s+"0"
 Next
 x(1+(i MOD 1000))=f
Print Chr$(13)+"Performance: "+Str$((i*1024)\286,8,0)+" grains"
End
Pilot352
Posted: 03:42pm 26 Jan 2021
If we do this, is there any recommendation on adding additional heat sinks?
mclout999
Posted: 05:15pm 26 Jan 2021
Do you have to leave the jumper on or short it every time?  Is there a way to default to that speed?  My mouse cable has is a full 40 pin and I can not have the jumper installed with the mouse plugged in.  I guess I could take it apart and put a momentary switch on those two pins.  Maybe it could eventually be set up with an option command and use the shorted pins to go back to default chip speed. My CMM2 works fine at that speed but MauroXavier's DEMOX crashes and hangs up the machine just after the SD card insert screen.  I know his demo is very reliant on CPU timing so that was my first test. Thanks for a wonderful new feature.
Edited 2021-01-27 03:16 by mclout999
twofingers
Posted: 05:37pm 26 Jan 2021
  Pilot352 said  If we do this, is there any recommendation on adding additional heat sinks?
I doubt if a heat sink is necessary. During the execution (>30x) of Peter's stress test, the CPU of my CMM2/400MHz/MMBasic 5.06.00 only reached ~40 degrees Celsius.
Edited 2021-01-27 03:40 by twofingers
Pilot352
Posted: 08:15pm 26 Jan 2021
-40? Are you sure you don't mean 40? -40 is colder than the arctic. LOL
twofingers
Posted: 08:35pm 26 Jan 2021
  Pilot352 said  -40? Are you sure you don't mean 40? -40 is colder than the arctic. LOL
Please read it again! "~" (= ASCII 126) is not "-" (= ASCII 45)!
~40 means approximately 40 degrees Celsius.
Which symbol do you use for this in your country?
Michael
  Quote  Usage
Common use
This symbol (in US English) informally[7] means "approximately", "about", or "around", such as "~30 minutes before", meaning "approximately 30 minutes before".[8][9] It can mean "similar to",[10] including "of the same order of magnitude as",[7]  ...
https://en.wikipedia.org/wiki/Tilde
I hope this helps!
Edited 2021-01-27 06:48 by twofingers
Posted: 08:50pm 26 Jan 2021
  twofingers said  Which symbol do you use for this in your country?
Same.
twofingers
Posted: 09:02pm 26 Jan 2021
  lizby said  Same.
Thanks! I wasn't sure.
Michael
Pilot352
Posted: 09:17pm 26 Jan 2021
Must be my browser... I don't see a Tilda. I see a minus sign. Odd. Good to know. I wouldn't want my MM2 to freeze. LOL
Pilot352
Posted: 09:18pm 26 Jan 2021
Correction.... I need glasses. LMAO
Plasmamac
Posted: 09:32pm 26 Jan 2021
runs fine here  on 504 000000   thx matherp
Edited 2021-01-27 07:34 by Plasmamac
Plasma
MauroXavier
Posted: 10:23pm 26 Jan 2021
For me unfortunately did not work as I expected.
I have a 400 Mhz CPU, in my tests, the Wolf3D show corrupted textures after a while and Into The Darkness freeze the system before even loading the stage.
matherp, any chance to change the overclock to 480 Mhz instead 504 Mhz on the 400 Mhz CPUs?
Posted: 10:48pm 26 Jan 2021
  Quote  For me unfortunately did not work as I expected.
You can try this
CMM2V1.5.zip
Have you done the oscillator mod? Probably essential to get the stability
MauroXavier
Posted: 03:54am 27 Jan 2021
  matherp said  Have you done the oscillator mod? Probably essential to get the stability
The difference in speed of 400 Mhz to overclocked 480Mhz in the Into the Darkness is very noticeable, but it freezes the system running only about 30 seconds... But as I do not have the oscillator mod, probably this is the cause of the instability.
Anyway, thanks for your support.
Edited 2021-01-27 13:55 by MauroXavier
LeoNicolas
Posted: 07:45am 27 Jan 2021
Tomorrow I will try it in my CMM2 waveshare with the oscillator mod.
I will post the results soon.
twofingers
Posted: 09:46am 27 Jan 2021
Hi Peter,
will the overclock mode disappear after a firmware update?
Michael
