Local Time 14:46 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Has anyone done a rolling credits demo I can pinch?
Posted: 10:19pm 04 Oct 2020
Hi folks,
Does anyone have (or want to write) a demo of vertically rolling credits that I can repurpose for the Welcome Tape splash-screen. I specifically need to show the credits in a letterbox rather than scrolling the entire screen, i.e.
I'm suspect I will need to fade the text in and out from black as it passes through the letterbox otherwise it will probably look very odd.
vegipete
Posted: 04:37am 05 Oct 2020
Is this the sort of effect you are after?
40 random names. (Why did I pick only boy's names? Where are the female programmers?)
Fade in and out needs more thought. Maybe even a CSub.
dim a$(40)
a$( 1) = "Michael"
a$( 2) = "Daniel"
a$( 3) = "Henry"
a$( 4) = "Sebastian"
a$( 5) = "Aiden"
a$( 6) = "Matthew"
a$( 7) = "Samuel"
a$( 8) = "David"
a$( 9) = "Carter"
a$(10) = "Owen"
a$(11) = "Wyatt"
a$(12) = "John"
a$(13) = "Jayden"
a$(14) = "Dylan"
a$(15) = "Grayson"
a$(16) = "Julian"
a$(17) = "Mateo"
a$(18) = "Anthony"
a$(19) = "Jaxon"
a$(20) = "Christopher"
a$(21) = "Andrew"
a$(22) = "Theodore"
a$(23) = "Caleb"
a$(24) = "Ryan"
a$(25) = "Nathan"
a$(26) = "Thomas"
a$(27) = "Leo"
a$(28) = "Charles"
a$(29) = "Hudson"
a$(30) = "Christian"
a$(31) = "Hunter"
a$(32) = "Connor"
a$(33) = "Landon"
a$(34) = "Adrian"
a$(35) = "Robert"
a$(36) = "Carson"
a$(37) = "Brayden"
a$(38) = "Axel"
a$(39) = "Bryson"
' Scroll Window parameters
sw_x = 250
sw_y = 200
sw_thick = 2
sw_width = 300
sw_height = 100
sw_font = 2
sw_fontheight = 20
sw_text_col = RGB(YELLOW)
cls
box sw_x,sw_y,sw_width,sw_height,sw_thick  ', framecolour if desired
for j = 1 to 40
 page write 2
 text 20,100,a$(j)+"              ",LT,sw_font,1,sw_text_col
 page write 0
 for i = 1 to sw_fontheight  'MM.INFO(FONTHEIGHT)
   blit sw_x,sw_y+sw_thick+2,sw_x,sw_y+sw_thick+1,sw_width,sw_height-2*sw_thick-2,0
   blit 0,100+i,sw_x+sw_thick,sw_y+sw_height-sw_thick-2,sw_width-2*sw_thick,1,2
   pause 50
 next i
next j
for i = 1 to sw_height - sw_fontheight
 pause 50
next i
end
Turbo46
Posted: 07:34am 05 Oct 2020
Another good one Vegipete.
Maybe in lieu of fading out - random black pixels over the last lines worth of the display could make them appear to disintegrate?
Posted: 09:20am 05 Oct 2020
  vegipete said  Is this the sort of effect you are after?
Absolutely, thank you.
  vegipete said  40 random names. (Why did I pick only boy's names? Where are the female programmers?)
I don't know, I get the impression that they represented 50% or more of the early industry. We've got two great women working for us ... and I've worked with one useless one ... so that probably represents a better success rate than with my male colleagues.
Of course we don't want to spoil the suprise when Peter Mather announces he's really called Ada and has been alive since 1815.
  Quote  Fade in and out needs more thought. Maybe even a CSub.
Since you've been so generous with your time I might try my luck and consulting the Necronomicon cast Summon @Sasquatch to see if he might help us out. I guess what we need is a CSUB of a form something like:
* This subroutine changes the colour of pixels within a bounding rectangle
* that are currently coloured 'old_rgb' to colour 'new_rgb'
* @param  x        x-coordinate of top-left corner of rectangle
* @param  y        y-coordinate of top-left corner of rectangle
* @param  x2       x-coordinate of bottom-right corner of rectangle
* @param  x2       y-coordinate of bottom-left corner of rectangle
* @param  old_rgb  change pixels of this colour ...
* @param  new_rgb  ... to this colour.
void change_colour(x, y, x2, y2, old_rgb, new_rgb);
Alternatively is it possible to do something clever using a colour MAP where each line of text is drawn in a different colour and then faded in and out?
  Turbo46 said  Maybe in lieu of fading out - random black pixels over the last lines worth of the display could make them appear to disintegrate?
Thanks for the backup plan Bill.
NPHighview
Posted: 04:05pm 05 Oct 2020
Lots of information on women in computing here. Long list of names to use in the rolling credits!
As a 64-year-old white guy, it makes me a little uncomfortable that, inadvertently or not, women were pushed out of computing from the 1960's to the point that:
  Quote  ...In 1984, 37 percent of computer science majors were women, but by 2014 that number had dropped to 18 percent, according to the study. The computing industry's rate of U.S. job creation is three times the national average, but if trends continue, the study estimates that women will hold only 20 percent of computing jobs by 2025.
US News and World Report.
The article cites middle school as the critical time to encourage young women to get into the field.  As a local science fair judge, I see this a lot when judging middle school science fair projects.  Fortunately, the CMM2 is a great starting point, and very approachable, by kids at this age.
Sasquatch
Posted: 04:30pm 05 Oct 2020
You should be able to do this with the color MAP() in 8bit color mode.  i.e. Mode 1,8 etc.
I will work on the CSUB you suggested, it seems useful and may even work to roll the colors in the 16bit color MandelbrotEXP16. I'm curious to see how fast it could be.  I am also wondering if the hardware blit functions could be coaxed into doing this?  Give me a couple of days to chew on it.  All the other MMBASIC commands that specify a rectangle use H,W instead of X2,Y2 so I'll likely stick with that.
Disintegrating text also sounds cool and could be a nice effect.
Edited 2020-10-06 02:35 by Sasquatch
-Carl
vegipete
Posted: 04:35pm 05 Oct 2020
  thwill said  void change_colour(x, y, x2, y2, old_rgb, new_rgb);
That could be a good general purpose routine but I was thinking of something more palette based. A gradient set of colours is needed first, from almost but not quite black to white (or what ever.) The routine then needs to increase each screen memory byte value by one to move up the colour table - fade in - and decrease by one to fade out.
I'll test some stuff with peeks and pokes to see if the effect works. Then we can see about speed.
Posted: 05:18pm 05 Oct 2020
@Sasquatch, @vegipete
Thanks for doing this for me, it's really appreciated because it would be weeks before I could get around to it.
You might consider making the `old_rgb` and `new_rgb` into arrays of the same size (i.e. a map), you'd also need some way to indicate that size, either an additional parameter or magic terminating value in the old_rgb array.
Thanks again,
Posted: 05:34pm 05 Oct 2020
  Quote  The routine then needs to increase each screen memory byte value by one to move up the colour table - fade in - and decrease by one to fade out.
You can do this with PAGE AND_PIXEL and then some Blitting but you could possibly get a smoother effect using MAP. Do load RC1 first as I've made a sneaky improvement to the colour mapping.
This technique can also be used for colour transformations. Write in white and then change the AND mask
mode 3,16
pause 2000
page write 3
cls
print @(100,100)"some text
print @(100)"Some more test"
print @(100)"Even more text"
i=255
do
page write 2
box 100,100,100,100,,rgb(i,i,i), rgb(i,i,i)
page and_pixels 2,3,1
page write 0
BLIT 100,100,100,100,100,100,1
pause 50
i=i-1
loop until i=0
Edited 2020-10-06 03:40 by matherp
vegipete
Posted: 05:54pm 05 Oct 2020
Now this is cool! It's starting to push MMBasic's byte wrangling but it works. There may be efficiencies to be gained by using 32 bit peeks and pokes but still, the effect is pretty smooth as is. The algorithm is to set any non-zero pixels in the scroll region to the target colour for that particular section of the scroll region. In this case, the region is 32 (31?) pixels tall, and each horizontal row of pixels is a section.
A CSub version of FixColours would want (x,y,width,new_value) and would set each non-zero byte of the strip of bytes to the specified value. (Maybe x,y should instead be given as just a memory address.)
The text to be scrolled appears on the top left but that is just to see what it is doing. In a real version, a different page would be used, which would also cure the slight flickering and flashing. (If I could force MMBasic to draw using a particular colour number...)
Comment out line 11 to remove the box for even better effect.
' Fading Scrolling Text Demo
' vegipete, Oct 2020
mode 1,8
cls
sw_x = 500      ' scroll window x location
sw_y = 100      ' y location
sw_width = 50   ' width
sw_height = 200 ' height
box sw_x-2, sw_y-2, sw_width+4, sw_height+4, 2, rgb(red) ' put a box around scroll window
' build custom colours from #100 to #131
for i = 0 to 31
 map(100 + i) = rgb(8*i, 8*i, 8*i)
next i
map set
addr = MM.INFO(PAGE ADDRESS 0) + MM.HRES*sw_y + sw_x  ' memory location of top left of box
c = 33
do
 text 1,0,chr$(c)+chr$(c+1)+chr$(c+2),LT,3   ' 12x20 character, on page 0 so we can see
 for i = 1 to 24  ' character height
   blit sw_x,sw_y+1,sw_x,sw_y,sw_width,sw_height-1   ' shift scroll box image up 1
   blit 0,i,sw_x,sw_y+sw_height-1,sw_width,1   ' copy row of pixels to bottom of scroll box
   FixColours
'    pause 10  ' not needed
 next i
 c = c + 3
 if c > 127 then c = 32
loop
sub FixColours
 local i,j
 for i = 1 to 31  ' 5 bit fade region
   for j = 0 to sw_width-1   ' work across scroll box
     memloc = addr + i * MM.HRES + j  ' top of box
     if peek(byte memloc) then poke byte memloc, 100 + i ' if pixel is not black, change to fade
     memloc = addr + (sw_height - i) * MM.HRES + j   ' bottom of box
   next j
 next i
end sub
Edited 2020-10-06 04:06 by vegipete
Sasquatch
Posted: 07:35pm 05 Oct 2020
  vegipete said  Now this is cool! It's starting to push MMBasic's byte wrangling but it works. There may be efficiencies to be gained by using 32 bit peeks and pokes but still, the effect is pretty smooth as is. The algorithm is to set any non-zero pixels in the scroll region to the target colour for that particular section of the scroll region. In this case, the region is 32 (31?) pixels tall, and each horizontal row of pixels is a section.
That does look nice!  Do You want me to add a CSUB version of "FixColours" or "FixColors" to my "To-Do" list?
-Carl
Posted: 08:14pm 05 Oct 2020
Very pretty @vegipete.
  Sasquatch said  That does look nice!  Do You want me to add a CSUB version of "FixColours" or "FixColors" to my "To-Do" list?
If you could. At the moment it is unfortunately too slow to use for the credits.
Sasquatch
Posted: 04:53pm 08 Oct 2020
Here is a first pass at the requested CSUBs.  The Disintegrate CSUB version seems to have a couple of minor glitches but mostly works ok.  I'm not sure where the problem lies as the algorithm works better in MMBASIC.
Included is a demo program including the CSUBs.  The CSUBs are each completely independent, you only need the one you want to use.  See the comments for documentation.
Sorry this took so long, sometimes real life gets in the way of the hobbies.
graphsubs.zip
-Carl
vegipete
Posted: 05:23pm 08 Oct 2020
Them thar's some neat effects. The disintegrate functions look like prime candidates for NOT using true random number generators. I suppose the next request will be for a 're-integrate' function. Might be a blit equivalent, just taking longer and moving 'random' pixels each time through. Thinking more, the ideal could be a "cut-paste by disintegration" function. Pixels leave one region and appear in the second according to the desired pattern at the desired speed.
Your FixColours routine isn't as intended. You are using pixel level manipulations, which are limited by the colour map. My version in MMBasic worked at a screen memory byte value level. Any non-zero byte in the target region was changed to the requested byte. I separately forced a range of palette values to the colours I wanted. (I happened to choose 100 to 131, but that is arbitrary.)
Are there byte/word/longword alignment requirements in the ARM architecture? I'm going to go study the Mandelbrot source and see what I can learn.
Posted: 05:48pm 08 Oct 2020
Real life is proving to be a problem for me too this week.
I did have a play with scrolling credits on the splash screen last night and to be honest it felt cheap and unprofessional. That's not a comment on the code, it's an indictment of my idea of scrolling credits on the splash screen .
Hopefully we can use still make use of this code for a separate demo included on the tape.
Sasquatch
Posted: 05:53pm 08 Oct 2020
  vegipete said  Them thar's some neat effects. The disintegrate functions look like prime candidates for NOT using true random number generators. I suppose the next request will be for a 're-integrate' function. Might be a blit equivalent, just taking longer and moving 'random' pixels each time through. Thinking more, the ideal could be a "cut-paste by disintegration" function. Pixels leave one region and appear in the second according to the desired pattern at the desired speed.
The CSUB disintegrate uses a 32bit XORSHIFT PRNG for the random numbers, it's deterministic for a given size box.  The MMBASIC version uses the true random numbers.
This is actually much simpler that what I have implemented.  Keep in mind your method will only work for 8 bit color modes.  Color mapping 12 and 16 bit color modes is more complex, also some screen modes use "double pixels" I believe the horizontal doubling is done in hardware and the vertical doubling is software.  I'll add your requested function so you can try it!
-Carl
vegipete
Posted: 06:50pm 08 Oct 2020
  Sasquatch said  This is actually much simpler that what I have implemented.  Keep in mind your method will only work for 8 bit color modes.  Color mapping 12 and 16 bit color modes is more complex, also some screen modes use "double pixels" I believe the horizontal doubling is done in hardware and the vertical doubling is software.  I'll add your requested function so you can try it!
If I understand the graphics modes correctly, there are only two possibilities: 1 byte per pixel or 2 bytes per pixel. Plus some modes in which pixels 'appear twice' vertically.
With one byte per pixel, a colour look up table is used, translating one screen byte to a 16 bit colour. This applies to any of the 8 bit colour modes. Obviously, this limits you to 256 possible colours at a time (unless you do something weird like changing the look up table on the fly based on GetScanLine.)
Two bytes per pixel covers both 12 and 16 bit modes. Each screen pixel is represented by 2 bytes in memory. The interpretation of those 2 bytes depend on the particular mode.
As you say, lower resolution modes (5,6,7,13?) actually use 2 rows of memory for one line of pixels. (In fact, you can see double the vertical resolution if you use poke instead of pixel to draw on the screen.
With all that, I think my version of FixColours would still work fine in all modes, provided the CSub can determine the mode. Initially, it only needs to target 8 bit modes, single vertical byte per pixel, and would work as described.
The next level of CSub would recognize line doubled modes and change two bytes in memory, where the second is MM.HRES bytes further in memory.
The final level would recognize 2 byte pixels, and do the same: change any non-zero words to the requested word.
Is there an expanded description of the various functions listed in ARMCFunctions.h or do you refer back to the CMM2 source code for the details?
As an example, what would the CSub equivalents of PEEK and POKE look like?
Sasquatch
Posted: 06:58pm 08 Oct 2020
Ok, I added Change_Bytes() and FixBytes()!
graphsubs.zip
-Carl
Sasquatch
Posted: 10:13pm 08 Oct 2020
Currently there is no way to determine the color depth (bits/pixel) from in a CSUB.  I have asked matherp to add the function.  As you suggest, this would make life much easier. For now I have implemented separate functions for 8/16 bits.  I suppose it could be made a parameter for now.  I also don't like putting out code that requires users to upgrade to the latest beta if it can be avoided.
There is no Peek or Poke for CSUBs.  They are not needed.  You use the 'C' de-referencing operator "*"  it looks like this:
unsigned char A;  // declare A as a byte
unsigned char *peekaddress; // declare peekaddress as a pointer to a byte (the address of a byte)
peekaddress = (some address we are interested in); // set the pointer to some address
A = *peekaddress;   // A = Peek(peekaddress)
*pokeaddress = A;   // Poke(pokeaddress,A)
In the CSUB I use it like this:
if (*(page + y * HRes + x) == 0)
  *(page + y * HRes + x) = (unsigned char)new_rgb;
I want to figure out some strangeness with the CSUB version of Disintegrate() and clean up/comment my code better, then I will publish the 'C' source for these CSUBs and you can have a look.
Darn!  You have got my mind churning  about the "Re-Integrate" function.  I have an idea for a copy function to randomly copy pixels from one area/page to another.
-Carl
vegipete
Posted: 10:42pm 08 Oct 2020
You rock, Sasquatch!
(Text is snatched from Wikipedia.)
'Scrolling Fading Text Demo
'By vegipete
'Made possible with CSUB by The Sasquatch
'www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=12876
Mode 1,8
page write 2 : cls
page write 1 : cls
page write 0 : cls
dim integer sw_x = 100      ' scroll window x location
dim integer sw_y = 100      ' y location
dim integer sw_width = 550  ' width
dim integer sw_height = 200 ' height
'box sw_x-2, sw_y-2, sw_width+4, sw_height+4, 2, rgb(red) ' put a box around scroll window
for i = 0 to 31
next i
map set
do
 read txt$
 if txt$ = "END" then exit do
 page write 2
 text 20,0,txt$+space$(75),LT,1   ' 8x12 character
 page write 1
 for i = 1 to 12   ' character height
   blit 0,i,sw_x,sw_y+sw_height-1,sw_width,1,2   ' copy row of pixels to bottom of scroll box
   FixColours
   page copy 1,0,B
   pause 50
 next i
loop
page write 0
end
sub FixColours
 local integer i,j
 for i = 0 to 31  ' 5 bit fade region
   FixBytes(sw_x, sw_y+i,sw_width,2,100+i) 'Change all non zero bytes in the row to 100+i
   FixBytes(sw_x, sw_y+sw_height-i,sw_width,1,100+i) 'same change, different row
 next i
end sub
data "BASIC (Beginners' All-purpose Symbolic Instruction Code) is a"
data "family of general-purpose, high-level programming languages"
data "whose design philosophy emphasizes ease of use. The original"
data "version was designed by John G. Kemeny and Thomas E. Kurtz and"
data "released at Dartmouth College in 1964. They wanted to enable"
data "students in fields other than science and mathematics to use"
data "computers. At the time, nearly all use of computers required"
data "writing custom software, which was something only scientists"
data "and mathematicians tended to learn."
data " "
data "In addition to the language itself, Kemeny and Kurtz developed"
data "the Dartmouth Time Sharing System (DTSS), which allowed multiple"
data "users to edit and run BASIC programs at the same time. This"
data "general model became very popular on minicomputer systems like"
data "the PDP-11 and Data General Nova in the late 1960s and early"
data "1970s. Hewlett-Packard produced an entire computer line for this"
data "method of operation, introducing the HP2000 series in the late"
data "1960s and continuing sales into the 1980s. Many early video"
data "games trace their history to one of these versions of BASIC."
data " "
data "The emergence of early microcomputers in the mid-1970s led to"
data "the development of a number of BASIC dialects, including"
data "Microsoft BASIC in 1975. Due to the tiny main memory available"
data "on these machines, often 4 kB, a variety of Tiny BASIC dialects"
data "was also created. BASIC was available for almost any system of"
data "the era, and naturally became the de facto programming language"
data "for the home computer systems that emerged in the late 1970s."
data "These machines almost always had a BASIC interpreter installed"
data "by default, often in the machine's firmware or sometimes on a"
data "ROM cartridge."
data " "
data " "
data " "
data " "
data " "
data " "
data " "
data " "
data " "
data " "
data " "
data " "
data " "
data " "
data " "
data " "
data " "
data "END"
'Graphic Color Changing Subroutines
'By The Sasquatch
'As requested by thwill and vegipete
'File graphsubs.bas written 08-10-2020 12:31:44
'FixBytes(x,y,h,w,New_Byte)
'Changes any non-zero Bytes within the bounding box to New_Byte
'For a line, set h or v to 1 set w and h to 0 for full screen
'WARNING only works correctly in 8 bit color modes -
'will not work properly in "pixel doubled" modes
CSUB FixBytes
 00000000
 4FF0E92D B085681B 68006815 182F6809 EB03431D 92010201 42B8D013 4291DC0E
 DC0B4614 681B4B35 3B01681B D3054283 68124A33 3A016812 D258428A E8BDB005
 4B2E8FF0 681B4A2E 681B6812 3B016812 2B003A01 9201461F 2A00DBF0 4628DBEE
 42914611 75E5EA25 4611BF28 EA20429F BF2872E0 428D461F 92029101 4B21DADE
 681B42BA DAD9681E F8DF4253 F8DF8070 9300907C F8DF1ABB 9303B078 463D462B
 9B00461F F1039C02 F8D80A01 EB0A3000 4A150004 FB09681B FB03F000 34014307
 B1115CF1 6809990E EBBB54F1 D2010FB0 47986813 D1E842A5 37019B00 44139A03
 9B019300 D1DC42BB E8BDB005 2F008FF0 2C00DBA4 460DDBA2 E7B24621 080002EC
 080002F0 08000358 0800033C 3AFB7E91 001A36E2
End CSUB
