Local Time 15:24 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 stich
MikeAlves
Posted: 06:22pm 07 Sep 2020
Hey guys,
I finally got my switch. Just to be sure, I remove the wire that bridges the two holes and solder the pins of the switch into the PCB (see picture)?
I am ok with a soldering iron, but I just don't want to mess this up.
Thanks,
Mike
RetroJoe
Posted: 10:45pm 07 Sep 2020
Mike, I can't see the picture, but "yes" - the switch needs to replace the "always on" jumper that came pre-installed on your PCB.
I used an old push-on / push-off switch I had lying around, and it happens to illustrate the point perfectly!
Edited 2020-09-08 10:28 by jpusztai
Enjoy Every Sandwich / Joe P.
MikeAlves
Posted: 10:40pm 11 Sep 2020
Here's the pic. I forgot to upload the picture. Am I lining this up correctly?
Posted: 11:02pm 11 Sep 2020
Yes
ON will be UP or DOWN depending on your switch.
MikeAlves
Posted: 12:22am 12 Sep 2020
Thanks so much!
vegipete
Posted: 01:09am 12 Sep 2020
  TassyJim said  ON will be UP or DOWN depending on your switch.
Are there any versions of that switch where up is on?
mkopack73
Posted: 02:19am 12 Sep 2020
Not that I'm aware of. Honestly, you get used to it pretty quickly...
Posted: 02:27am 12 Sep 2020
Someone on your side of the wold found one but I didn't make a note of the part number or supplier. I am happy with down for on.
vegipete
Posted: 03:05am 12 Sep 2020
I have come to accept and appreciate down for on - for this particular application. Fitting for something invented down under.  ;-)
MikeAlves
Posted: 03:26am 12 Sep 2020
Do any of you know how to switch the vegimite port to peanut butter?
Honestly, I did think the battery was faulty because the date was always wrong. Then I realized it had to be read Day Month Year instead of Month Day Year. :)
Andrew_G
Posted: 03:51am 12 Sep 2020
G'day Mike,
Another one from down-under here.
Re the date, how about you try with the battery in up the other way?
Cheers,
Andrew
Womble
Posted: 11:18am 17 Sep 2020
  MikeAlves said  Do any of you know how to switch the vegimite port to peanut butter?
This might work
MikeAlves
Posted: 11:47am 17 Sep 2020
Looks good. Does it ship to the US?
Nimue
Posted: 12:27pm 17 Sep 2020
Hi
Another "switch" related question.
Preassembled CMM2
To make life easier for my target audience of teachers, is there anything "wrong" with replacing the jumper that we move to flash the ROM with a SPDT switch?
In theory, what I want to achieve is an outside the box switch that one way is "run" - ie normal operation and the other way is "flash" so that the device can be upgraded.
I have wired this up and it works fine for running / flashing.
If the device was accidentally moved to "flash" setting - but was otherwise set up to use (ie keyboard and power) -- are there any negative consequences?  Reluctant to try in case I fry as they say....
Nim
Posted: 12:33pm 17 Sep 2020
  Nimue said  To make life easier for my target audience of teachers, is there anything "wrong" with replacing the jumper that we move to flash the ROM with a SPDT switch?
Unless I'm misunderstanding what you are talking about ...
Hmm, I'm sure it is a switch on mine.
Anyway you don't need it, search the manual for "UPDATE FIRMWARE", this performs the "switch" in software until the next reset/reboot.
Nimue
Posted: 12:39pm 17 Sep 2020
- defo a jumper inside mine.
Ok -- software switch is good.
I should learn RTFM....
Nim
Nimue
Nim
Posted: 12:57pm 17 Sep 2020
  Nimue said  - defo a jumper inside mine.
Nim
I think yours must be an all in one board whereas mine has the Waveshare module and the switch is on the module.
If you aren't obsessively reading and re-reading the manual then you aren't capturing the full 1980s microcomputer experience
Nimue
Posted: 01:01pm 17 Sep 2020
  thwill said
I read mine in bed -- spiral bound and all.
Nim
CircuitGizmos
Posted: 02:49pm 17 Sep 2020
Little switch
This is a switch that can be used.
