Local Time 16:38 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Recursion in MMBasic
ceptimus
Posted: 11:27am 24 Oct 2019
I've been experimenting with recursion in MMBasic.  For simple examples, like the classic factorial, it works fine.
function factorial(n%)
 if n% = 0 then
   factorial = 1
 else
   factorial = n% * factorial(n% - 1)
 end if
end function
print factorial(100)
But I've found that it doesn't seem to co-exist happily with any loops (do loop, or for next) that use exit (exit do, exit for).  The error reports are rather strange - you get errors such as "LOOP without a matching DO" when returning from two or three levels deep of recursion, even though that same code executes fine at the deeper recursion levels.  I've tried it on various versions of MMBasic including the DOS one, and the same errors seem to occur on all the ones I've tried.
My code had no places where I just jumped out of a loop - every loop that required early exiting had a proper exit route. Also I was careful that when I wanted to pass a 'value' to a recursive sub or function, that sub or function created a local copy of the variable so as not to inadvertently modify the value (MMBasic has call by reference parameters).
I changed any loops that needed exits or called other subs/functions to work instead with labels and If ... Then GoTo label - and then it runs perfectly albeit rather slowly.
I don't know what mechanism MMBasic uses to 'find' a label - does it build a table of addresses for them, or does it search through the entire program from the start each time it needs to target one? If it's the latter, that would explain the slowness.
Posted: 03:06pm 24 Oct 2019
May be best to post a short example or two that ought to work but doesn't, so Geoff can reproduce it easily.
ceptimus
Posted: 05:28pm 24 Oct 2019
Thanks John.  Excellent idea.
Here's a short one.  It calculates OEIS A000522 using a short recursive function.  I've written two equivalent functions named "foo" and "bar" that should both return the same result.
You'll see that the labels plus gotos (foo) version works fine, but the equivalent For Next version (bar) crashes when attempting to calculate bar(2). The error reported is "Error: Cannot find a matching FOR"
The code:
Option explicit
Function foo(a) 'version with labels and gotos
   Local i
   foo = 1
   i = 1
   If i > a Then GoTo label_B 'skip loop body when a is zero
label_A: ' for i = 1 to a
       foo = foo + foo(a-1)
   i = i + 1 : If i <= a Then GoTo label_A ' next
label_B:
End Function
Function bar(a) 'version with For Next loop
   Local i
   bar = 1
   For i = 1 To a
       bar = bar + bar(a-1)
   Next
End Function
Dim n
Print "Demo MMBasic recursion bug. Calculate OEIS A000522"
Print "Using foo() method - labels and gotos"
For n = 0 To 8
   Print n, foo(n)
Next
Print : Print "Using bar() method - For Next"
For n = 0 To 8
   Print n, bar(n)
Next
The output:
0       1
1       2
2       5
3       16
4       65
5       326
6       1957
7       13700
8       109601
0       1
1       2
2
[19] Next
Obviously MMBasic doesn't support calling a recursive function that contains a loop from inside that loop.  I'm quite happy with that - I realize that I'm trying to do something a bit extraordinary. It's interesting that the label and goto method does work though.
By the way, I've verified that MMBasic must search through the code (from the beginning) whenever it targets a label (with goto for example). If you have a lot of comments near the start of the program (before the label) the program runs much slower than when you move those same comments to a position in the program after the label.
Edited 2019-10-25 04:49 by ceptimus
Pluto
Posted: 06:51pm 24 Oct 2019
Should there be a "NEXT i" just before the "Label_B" statement?
ceptimus
Posted: 07:11pm 24 Oct 2019
No Pluto - the whole point is that in the foo() function there aren't any For or Next statements (except in the comments).  Remember that anything after a ' is a comment.  I probably shouldn't have put those (' for ... ) and (' next ) comments in foo() - they are confusing rather than helpful, but it's too late for me to edit the code now.
When you eliminate the "For Next" statements and replace them with a bunch of equivalent "i=i+1  - If - Then - GoTo" statements then a program with recursion will work.
Of course, the "For Next" version is much easier to understand but unfortunately it crashes.
I should probably have put the bar() function first - study bar() first and once you understand it, verify that foo() does exactly the same, but in a less clear way.
To make it clearer, this is all you really need to see the bug - the rest of the program was just to demonstrate a way to work around the bug.
Option explicit
Function bar(a)
  Local i, r
  r = 1 ' the return value of this function
  For i = 1 To a
      r = r + bar(a-1)
  Next
  bar = r
End Function
print bar(3)
Edited 2019-10-25 05:25 by ceptimus
Posted: 07:50pm 24 Oct 2019
For what it's worth (not much!), I don't think you're trying to do anything extraordinary.  I think it should just work and I suspect MMBasic will be fixed :)
I just tried a version (had to add line numbers) with the old Linux (statically-linked) MMBasic (v 4.4.07e) and oddly get weird values but doesn't throw an error.
Oh... wait...
The version using r does the above.  (E.g. print bar(3) prints 11.)
The version using bar = bar + bar(a-1) throws an error.
Oh...
Posted: 08:20pm 24 Oct 2019
TRy putting the 'target' in the NEXT statement
  Quote     NEXT i
Works OK in MMBasic DOS and armite F4
Posted: 08:59pm 24 Oct 2019
Goodness!  Works on Linux with that.
Posted: 09:44pm 24 Oct 2019
Timings on H7 using Jim's correction 11.2Sec vs 8.5sec
  Quote  Demo MMBasic recursion bug. Calculate OEIS A000522
0       1
1       2
2       5
3       16
4       65
5       326
6       1957
7       13700
8       109601
11207.706
0       1
1       2
2       5
3       16
4       65
5       326
6       1957
7       13700
8       109601
8511.128
Edited 2019-10-25 07:45 by matherp
ceptimus
Posted: 10:26pm 24 Oct 2019
Awesome! Thanks to all who've posted.
I will start adding the loop variable to all my Next statements - it's a good way of self-documenting the code anyway.
Ironically, I was playing around with strangely nested For Next loops a while back to see what happened:
For I = 1 to 10
For J = 1 to 10
Print I, J
Next I
Next J
I concluded that there could never be any possible use for that sort of code, even if it worked, and that was why most BASICs are happy for the loop variable to be omitted from Next statements.
Posted: 10:39pm 24 Oct 2019
I encountered exactly the same problem last week on my CMM and found the solution of using the loop variable explicitly in the Next statement.
Unfortunately I couldn't work out a solution for Do While Loops which demonstrate the same issue if used in recursive functions.
ceptimus
Posted: 12:07pm 25 Oct 2019
thwill, here is bar() rewritten to use an equivalent Do While Loop, and as you say it crashes MMBasic:
Option explicit
Function bar(a)
   Local i,r=1
   i=1:Do While i<=a
       r=r+bar(a-1)
   i=i+1:Loop
   bar=r
End Function
Dim n:For n=0 To 8:Print n,bar(n):Next n
Until the bug in MMBasic is fixed, it's possible to use the weird construct described below that makes "For Next" behave like "Do While Loop".
We introduce a dummy loop variable - I've used z - and put whatever the While control logic was - in the example above it was "i<=a" - inside the parentheses after the Not
So "Do While i<=a" is replaced by "For z=0 To 0 Step 0:If Not(i<=a)Then Exit For"
... and "Loop" is replaced by "Next z"
here is the kludged version that runs without error:
Option explicit
Function bar(a)
   Local i,z,r=1
   i=1:For z=0 To 0 Step 0:If Not(i<=a)Then Exit For
       r=r+bar(a-1)
   i=i+1:Next z
   bar=r
End Function
Edited 2019-10-25 22:18 by ceptimus
ceptimus
Posted: 01:58pm 25 Oct 2019
Unless you have a special interest in MMBasic recursion, you can probably ignore the following - it's getting dangerously close to becoming an entry for an obfuscated BASIC contest.
I wanted to test Sub() which can "return" values using the fact that the arguments are passed by reference. Function() does the same and it's a source of subtle bugs if a Sub() or Function() in MMBasic accidentally modifies the argument variable(s).  I also wanted to verify that Exit Sub doesn't cause a problem with recursion.
Anyway, the following code does execute without error and generates the correct answers.
Option explicit
Sub bar(a) 'a is passed by reference. This Sub modifies a to "return" a result
   Local i,t,z,r=1
   If a=0 Then a=1:Exit Sub
   i=1:For z=0 To 0 Step 0:If i>a Then Exit For
       t=a-1:bar(t):r=r+t
   i=i+1:Next z
   a=r
Dim n,r:For n=0 To 8:r=n:bar(r):Print n,r:Next n
Posted: 08:00pm 25 Oct 2019
Thanks Ceptimus.
I originally used a "goto label" instead of a loop to workaround it. Is the Next kludge more efficient?
Also your example isn't MMBasic 4.5 is it? "Option explicit" and using "Dim" to declare variables aren't in my copy of the manual.
Edited 2019-10-26 06:22 by thwill
ceptimus
Posted: 08:28pm 25 Oct 2019
On all the platforms I've tried, GoTo label is much slower than the other loop constructs.
I think Geoff said that the (Colour) Maximite builds a table of addresses of labels, but the other implementations search through the program from the beginning to find a label whenever one is targeted - so a GoTo label executes very slowly for any labels that are towards the end of a large program.
The other loop constructs, even when they are misused a little to get around the bug, are also neater and arguably better programming practice than using GoTo.
I'm using MMBasic Ver 5.05.02 in DOS, and the latest versions on the Armmites and Pi-cromite for testing.  I've not been using my Colour Maximite nor any of the PIC based Micromites for these tests.
Option Explicit is a great safety net for catching bugs if your version of MMBasic supports it.
I'm not sure if there is a better way of declaring scalar variables in DOS MMBasic than with DIM - and if you use Option Explicit you have to declare global variables somehow.  Perhaps someone more knowledgeable than me will provide an answer to that.
Edited 2019-10-26 06:32 by ceptimus
Posted: 05:33am 26 Oct 2019
TEGAN: "Of course, if we had an index file, we could look it up in the index file under index file!  What am I saying.  I'm talking nonsense."
NYSSA: "Recursion isn't nonsense."
TEGAN: "Eh?"
NYSSA: "That's an example of recursion - when procedures fall back on themselves.  IF you had an index file, you could look it up in the index file."
TEGAN: "'IF'.  My dad used to say that 'If' was the most powerful word in the English language..."
NYSSA: "Recursion's a powerful mathematical concept.  But I don't see how it can help us now."
TEGAN: "If....  I.F.!!!  Stands for Index File!"
- Doctor Who, Castrovalva.
Posted: 11:09pm 27 Oct 2019
Grogster: Wrong platform; the TARDIS clearly ran BBC BASIC 2 - see The Five Doctors.
Ceptimus: thanks for the reply. As it happens my current project won't work on DOS MMBasic because it uses PEEK and POKE to access a byte array that acts as the Z-machine's memory; though thinking about it, DOS MMBasic presumably has a lot more memory to play with than a CMM and I could use an array of integers even if I never store > 255 in them.
I'll be taking an in depth look at which are the fastest constructs and how file ordering matters when I optimise the code. Does anyone have any insight?
Posted: 01:03am 28 Oct 2019
thwill,
Depending on the size of memory required, I would create an array of strings.
Each element uses one byte for the length then 255 bytes for the string.
A string array s$() would reserve 8 X 256 or 2K bytes which you could then peek and poke at will.
You can get the starting address for any variable.
An integer array uses 4 bytes per element but you could use code to divide each number into 4. That would save using peek and poke.
CMM V4.5 doesn't have integers available to play with.
The DOS version is restricted in memory
  Quote  > memory
   Program:   0K ( 0%) used 512K free (0 lines)
 Variables:   0K ( 0%) used  31K free (0 variables)
General RAM:   0K ( 0%) used 512K free
ceptimus
Posted: 09:06am 28 Oct 2019
For testing programs on the DOS version, I wrote these Peek and Poke equivalents in MMBasic.  You can only use an offset of 0,1,2, or 3 of course. Peek works on simple variables and arrays, but Poke only on simple variables, so if your program pokes to an array variable you have to alter it to copy that to a simple variable, poke to that and then copy back again. Only other change needed is to put a comma after all the VAR keywords - that can be done with a quick search and replace.  The DOS version just treats VAR as an extra variable passed to peek / poke - a variable that it doesn't need, so it names that variable 'dummy'.  You also need to DIM VAR if you're using Option Explicit, as DOS MMBasic will otherwise complain that VAR is not defined.
If your program is intended for just the DOS version, then you're better off just using arrays or strings as Jim suggested, but for testing programs on the DOS version that you eventually intend to run on some other 'mite, these peek and poke hacks are useful.
Dim VAR
Function Peek(dummy,v%,o%)
   Local div(3)=(&h1,&h100,&h10000,&h1000000)
   peek=(v%\div(o%))And &hFF
End Function
Sub Poke dummy,v%,o%,p%
   Local mul(3)=(&h1,&h100,&h10000,&h1000000)
   Local mask(3)=(&hFFFFFF00,&hFFFF00FF,&hFF00FFFF,&hFFFFFF)
   v%=(v% And mask(o%))Or(p%*mul(o%))
Edited 2019-10-28 19:07 by ceptimus
ceptimus
Posted: 11:07am 28 Oct 2019
On the DOS version of MMBasic, you're allowed 50 nested for loops, but some other platforms only allow 10.  So recursion using the for loop trick can result in a "too many nested for loops" error.
It's always possible to simulate recursion by using arrays and a variable "depth" to index into those arrays keeping track of the current 'recursion depth'
Here's a non-recursive bar() that does that.  Of course, bar() lends itself to this approach so this version runs in a blink.  It starts to run into numerical errors at bar(13) on 32-bit 'mites and even the 64-bit integer variables of DOS MMBasic top out at bar(20).
The same depth-indexed array approach can be used to eliminate explicit recursion from any program - but it may make your head hurt a little while you're figuring out how to do it.
Option explicit: Option default integer
Const MD=25 'max depth
Const FALSE=0
Const TRUE=1
Function bar(a)
   Local depth=0,_a(MD),r(MD),i,j,unwind=FALSE
   _a(0)=a
   Do While Not(unwind)
       r(depth)=1
       If _a(depth)=0 Then
           unwind=TRUE
       Else
           _a(depth+1)=_a(depth)-1
           depth=depth+1
       EndIf
   For i=depth-1 To 0 Step -1
       For j=i+1 To depth
           r(i)=r(i)+r(i+1)
       Next j
   Next i
   bar=r(0)
End Function
Dim i:For i=0 To 20:Print Str$(i,2);Str$(bar(i),21,0):Next
Edited 2019-10-28 21:10 by ceptimus
