Local Time 12:32 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DOW$ not working Picromite
lew247
Posted: 08:10am 17 Aug 2018
Can anyone tell me why this won't work?
I'm trying to print the day of the week but it always prints Saturday
I've narrowed it down to the month not being processed right
IF I comment out 'DOW$(0)="Sunday":DOW$(1)="Monday":DOW$(2)="Tuesday":DOW$(3)= "Wednesday":'DOW$(4)="Thursday":DOW$(5)="Friday":DOW$(6)="Saturday"
then print DOW$ it prints a blank space
I'm using a Picromite, what I don't get is I've used this code on the Explore 100 in the past and it worked
The only "possible issue" I can see is if I PRINT month$ it prints 8 and not 08 but I can't see that causing an issue
It's probably something stupid I've done but I cannot see what
[code]DIM DOW$
DOW$(0)="Sunday":DOW$(1)="Monday":DOW$(2)="Tuesday":DOW$(3)= "Wednesday":DOW$(4)="Thursday":DOW$(5)="Friday":DOW$(6)="Saturday"
Year=Val(Mid$(Date$,7,4)):Month=Val(Mid$(Date$,4,2)):Day=Val(Mid$(Date$,1,2))
print date$
print time$
print DOW$(DayOfWeek(Year, Month, Day))
Function DayOfWeek(year, month, day)
a = Int((14-month)/12)
m = month + 12*a - 2
y = year - a
DayOfWeek = (day + y + Int(y/4)-Int(y/100)+Int(y/400)+Int(31*m/12)) Mod 7
End Function
[/code]Edited by lew247 2018-08-18
Posted: 08:12am 17 Aug 2018
You haven't dimensioned DOW$
should be
DIM DOW$(6)
lew247
Posted: 08:26am 17 Aug 2018
It's still giving the same result
Posted: 08:39am 17 Aug 2018
lew247
Posted: 08:59am 17 Aug 2018
Peter, how come your's doesn't have spaces in the listing but mine does?
there are no spaces in my code
Posted: 09:11am 17 Aug 2018
Your code has CR and LF at the end of lines. Linux expects just CR.
You have commented out the lines setting up DOW$
This is better syntax anyway
DIM DOW$(6)=("Sunday","Monday","Tuesday","Wednesday","Thursday","Friday","Saturday")
lew247
Posted: 09:17am 17 Aug 2018
Sorry Peter, I put the comment in when I was trying to find the error and wanted it to print the day numberal
it's working now
lew247
Posted: 10:42am 17 Aug 2018
Trying it in the proper full code now
it comes up with Error: Function or array DAYOFWEEK not declared
you don't declare functions do you?
PicFan
Posted: 11:16am 17 Aug 2018
Did you declare a variable for the function's result?
ERROR !
x = DayOfWeek(Year, Month, Day)
OK !
X = The result, the number from Day of week.
WolfgangEdited by PicFan 2018-08-18
lew247
Posted: 11:49am 17 Aug 2018
I didn't realise I had to ...
It's working now, coming up with the wrong day but it's got to be something I did so I should be able to get it
lew247
Posted: 12:28pm 17 Aug 2018
Now it's doing the original problem which is why I tried the DOW function on its own with no program
Now I've integrated it into the program I'm getting this AND the Pi crashes and I have to reboot
The function is the same one I was using that worked
[code]
y = year - a
End Function[/code]
Posted: 01:44pm 17 Aug 2018
There is a known issue with the Pi-cromite that some, but not many, MMBasic errors cause a crash. I have been unable to track this down as is seems as though it is a compiler and/or linker error.
The problem in your code is almost certainly that the function is returning a negative number or a number > 6 which causes the MMBasic error in the first place
lew247
Posted: 08:15pm 17 Aug 2018
Peter
Is there a way to keep the Picromite running when you close the terminal window?
I've been using Putty to connect wirelessly but Ctrl Z won't work unless I stop the program with Ctrl C first
If I just close Putty then it crashes
Posted: 09:51pm 17 Aug 2018
  Quote  Is there a way to keep the Picromite running when you close the terminal window?
Yes, but I didn't find the mechanism. Somewhere in one of the Pi-cromite threads one of the other Unix experts explained how to do it. You will have to search on Pi-cromite and spend time browsing
disco4now
Posted: 11:56pm 17 Aug 2018
Hi Lewis,
During development I use the screen command as mentioned in a previous thread
'screen - provides terminal for current session so you can close putty.
'screen -D -r - lists screen sessions you can reconnect to
So when you first login and before you start MMbasic type
screen
... then do your command to start MMBasic as normal.
If you close the terminal or it times out when you come back do
screen -D -r
... this will reconnect to MMbasic
I have not finished development, so screen is good for now, but the final solution so it just boots up and runs will use one of the following.
Five other ways to do it
Gerry
F4 H7FotSF4xGT
lew247
Posted: 05:22pm 18 Aug 2018
Deleted - Google told me that I had to download screen Edited by lew247 2018-08-20
lew247
Posted: 06:28am 20 Aug 2018
Blit doesn't seem to be working properly?
The "compass" is a picture and the arrow should only be showing one position
Azure
Posted: 07:39am 20 Aug 2018
  Quote  Blit doesn't seem to be working properly?
Lew, you'll need to provide a bit more information if you are expecting any suggestions or help on your last post.
Posted: 08:25am 20 Aug 2018
The protocol to make this work is:
write the compass without a pointer
BLIT READ area overlapping the complete compass, i.e. the compass background
do
option autorefresh off ' optional reduces artifacts
BLIT WRITE compass background
write the pointer
option autorefresh on 'optional reduces artifacts
refresh 'optional reduces artifacts
loop
lew247
Posted: 06:59pm 01 Sep 2018
I've finally got the Day of the Week working on the Picromite
BUT
it will not print on the display in the position and font I want it
The 2 print statements work perfectly and if I print it in a different font and position it works
Anyone got any ideas why not?
[code]
cls RGB(GREEN)
dim DOW$,DOW_DAY$
DOW$(0)="Sunday":DOW$(1)="Monday":DOW$(2)="Tueday":DOW$(3)="Wednesday":DOW$(4)="Thursday":DOW$(5)="Friday":DOW$(6)="Sat"
DOW_DAY$=DOW$(DayOfWeek(YEAR,MONTH,DAY))
print DOW_DAY$
Text 290,60,DOW_DAY$,LM,6,1,RGB(red),RGB(blue)'dow
print DOW_DAY$
function DayOfWeek(year, month, day)c
local a,m,y
a = int((14-month)/12)
y = year - a
DayOfWeek = (day + y + int(y/4)-int(y/100)+int(y/400)+int(31*m/12)) mod 7
end function
[/code]
EDIT: It seems most fonts other than 6.1 work
BUT FONT 6,1 works printing "DATE$" or "TIME$"Edited by lew247 2018-09-03
