Local Time 00:12 12 Nov 2026 Privacy Policy
Forum Index : Wanted : need Drive Shaft, Retaining Plates & Nut,
sizar
Posted: 07:54am 23 Jul 2007
hello
everyone i need a Drive Shaft, Retaining Plates & Nut, Bearings and that white bearing under the magnet hub to make a wind generator as i got a 100 series motor but i was only given the magnet hub and the stator
anyone that has a spare to give away please message me thanks sizar
p.s i'm looking for something afforable as my uni drained all my money away Edited by sizar 2007-07-24
if you really want to achieve something then you must face it with full potential and be prepared to fail because failing is part of learning
dwyer
Posted: 09:16am 23 Jul 2007
Hi Sizar
Where are you and what State??
Dwyer the Bushman
sizar
Posted: 10:59am 23 Jul 2007
hi dwyer in sydney australia nsw 2176 i only require the Drive Shaft, Retaining Plates & Nut, Bearings let me know if you can help
thanks sizar
