Local Time 00:02 12 Nov 2026 Privacy Policy
Forum Index : Wanted : Magnets
AMACK
Posted: 10:57am 29 May 2011
I am looking for 24 or 25 N50M disk magnets 50mm diameter X 12.5mm thick...magnatised through thickness or N48H same size.
If some one has any that are 15mm thick that would work too.
If some one has a few stacked away and has not intention of using let me know and I would like to takl to you..
AMACK
*Note to self
1. Make it thick
2.Make it heavy.
shawn
Posted: 06:39pm 29 May 2011
Gee these are really getting expensive have you given any thought to making a big ceramic mag gen ? we had a thread on it and it can be done with respectable power output. with current neo prices we are going to see plenty getting built i think Hugh has mentioned adding a ceramic mill to his new book.
brucedownunder2
Posted: 10:58pm 29 May 2011
Yes, I agree with the ceremic magnet idea..
I wandered around the whitegoods area at the tip some time ago .. Heaps of microwave ovens for the taking .tell the tippie u just want the magnets and promise to return the rest of the microwave.You might get away with it .. These have 2 X 50mm odd X 12mm thick circular magnets and are very easy to remove . keep a couple of the transformers while you are at it... 3 or 5 trips to the tip and you'll have plenty for your project..
Bruce
Bushboy
