Local Time 00:12 12 Nov 2026 Privacy Policy
Forum Index : Wanted : Large Potentiometer
robbo
Posted: 12:48pm 05 Jan 2011
Hey everyone,
Just wanting to see if anyone has any ideas for a large potentiometer for another project of mine. I am interested in adjusting the input to a heating element(of about 3200 watts)from a 240 volt suorce, but cannot find anything acceptable. Does anyone have any ideas ? It will need to be capable of about 15 amps.
I have an old variac, but the amperage is insufficient for this job. Perhaps someone can think of any scrap items I can scrounge this off of ?
Have a good one...
Rob.
"the Earth was not given to us, by our fathers, rather, it is lent to us by our children".
VK4AYQ
Posted: 01:58pm 05 Jan 2011
Hi Robbo
I have used a speed controller out of an old vacuum cleaner for a similar application, it was rated at 1800 watts but if you put bigger scr in it you could get more current.
It came from an old electrolux but I see the Chinese things they sell now have a controller, and it probably lasts longer than the accessories so should be plenty in the rubbish.
All the best
Foolin Around
robbo
Posted: 02:03pm 05 Jan 2011
Thanks for your response,
"but if you put bigger scr in it you could get more current."
What does SCR mean ? Still, would you be able to get up to 15 amps. This looks like a big ask for it ?
Posted: 02:12pm 05 Jan 2011
Most heating elements are adjusted by duty cycle, meaning the period of time it is on to the period of time it is off.
A standard thermostat works this way.
Why do you need to regulate the current to the element?
Pete.
Ps:- it would have been better to post this in ...electronics or Other stuff, but not in the wanted section.
robbo
Posted: 02:25pm 05 Jan 2011
Pete,
I have a poorly made homebrew still, (purchased from another owner) which is heating a tad too high for my liking. It currently heat the fluid used at 82-84 degrees, when I need it as 78 degrees.
Is there some other way to increase the load on this circuit perhaps ? (or will that just draw more current?).
The original idea is to lower the input voltage to vary the temperature.
Yes, your right, "electronics" would have been better.
VK4AYQ
Posted: 12:19am 06 Jan 2011
Ghug a lug Chug a lug
Just get a temperature controlled from fleabay V Village has them for around $35
Foolin Around
GOFJ
Posted: 06:22am 24 Jan 2011
I brew ginger beer and use a 350 watt water bed heater (variable temperature controlled running at 28 deg C) under 3 plastic kegs, to controll the wattage (and stop it going up in flames) I use an electric drill speed controller (old Dick Smith kit). The heater is a plastic mat and is designed to have a very large heat sink (bladder full of water) to stop localised hot spots which I no longer have, hence the chopper controller to limit the power.
Jack
