Local Time 00:12 12 Nov 2026 Privacy Policy
Forum Index : Wanted : How to remove thinset residue after old t
jamesthomas54
Posted: 03:06pm 27 Dec 2010
Hi, all,
I plan to remove the old tiles in my kitchen. The tiles were set on concrete
floor. I tested it by removing a few tiles off and it seems that removing
tiles is not that hard, but the thinset residue is hard to clean out.
Is there a good way to remove the left thinset/mortar? Does the grinder
available at Lowes (looks like a household vacuum) really work?
Thanks,
rubbish skip hire
brucedownunder2
Posted: 11:08pm 27 Dec 2010
I used a square nosed shovel with lots of success.. The glue is tacky ,but you can rent a sander/grinder from bunnings for the half day or full day .. A 200mm grinder makes a lot of dust , but gets the job done . If you are getting the tiling done ,,ask the tiler,, he probably will advise you (some don't remove the sticky left-overs ) ,the thickness of the adhesive covers that...
Bruce
Bushboy
Posted: 12:28am 28 Dec 2010
I found Petrol softens the glue and you can remove it with a scraper, although not the best smell and still not the easiest job, but its cheap compared to some other methods.
No smoking while working or you goose might be cooked in a blinding flash.
Pete.
