Local Time 00:12 12 Nov 2026 Privacy Policy
Forum Index : Wanted : pulley blocks
brucedownunder2
Posted: 01:42am 13 May 2010
Hi, anyone out there had 1,2 or 3 sheave pulley blocks in the 3 inch (75m) sheave range .. They seem to befairly scarce these days ,I don't mind if they are rusty or very dirty,,I'll clean them up and cold gal them.
I'll pay for your efforts if you have anything for sale.
Bruce
Bushboy
VK4AYQ
Posted: 03:45am 13 May 2010
Hi Bruce
I have a set I would lend you if you want to use for a while, don't want to sell as they are hard to get as you mentioned.
All the best
Foolin Around
dwyer
Posted: 08:35am 13 May 2010
hi Bruce
I have one pully block with hook but old and working order need clean up just let me know as l don't use it many more but is somewhere hiding in my shed ?
Dwyer
brucedownunder2
Posted: 08:54am 13 May 2010
Thanks vk4 and Dyer,
Just waved Ilda farewell in ambulance, she's a bit crook , the hospital wll look after her ,I'm sure.
Thanks for the response, I'll take you up on yours Dyer ,,a bit messy borroeing stuff vk4 ,if you know what i mean ,but meny thanks anyhow,,,
Ilda's down in the pindara private hosp. so will hopefully bring her home tomorrow, the osteroposis(can't spell) medication really rocked her.
Bruce
Bushboy
dwyer
Posted: 02:01pm 13 May 2010
Hi Bruce
Sorry to hear that your wife Ilda fell sick as l am sure that Pindara Hospital and medical staff will look after her well and I hope that Ilda will make speedy recover as my Mum has been there before after she had a fall. Don't let youself down Bruce as Ilda will be fine Regard from Ian and my little boy Leon
Dwyer
Posted: 02:13pm 13 May 2010
Hi Bruce,
sorry to hear Ilda is having some trouble with the medication. Say Hi and get well from Me.
On the matter of pulleys. I use the 50mm nylon pulley type, SSteel frame, roller bearing types, as used on sailing boats, on the main sheet. These are good for probably 1000kg. I use 10mm spectra, with a double, and tripple block to raise my tower. These are not that expensive, and run free. If you use wire rope, then these are not much good, but I find that spectra is much easier to handle and will work with the smaller pulleys.
Gordon.
dwyer
Posted: 11:33am 17 May 2010
Hi Bruce Did you recieved my e-mail this morning?
I just found out tonight that l was unable to Image Upload on private message this morning. Maybe get Gimzo look into it .
Kind regard Ian
brucedownunder2
Posted: 09:53pm 17 May 2010
Yes Thanks Ian , received your message .
It's a bit large for what I want,thanks.
I'll buy a couple from the rigging shop that services the trawler fleet down this way ,,around $45 each for small 60mm sheave types.
Thanks Mate.
Bruce.
Bushboy
