Local Time 00:02 12 Nov 2026 Privacy Policy
Forum Index : Wanted : LG Rotor
brucedownunder2
Posted: 08:52pm 04 Nov 2009
I've a LG motor ,and I would like to get a second magnetic rotor .I'd like to fit it out with Neo's ..
If anyone out there would like to part with one of the "bigger" LG rotors,,(there are 2 types) ,,I'd be happy to buy..
Bruce
Bushboy
grub
Posted: 08:03pm 06 Nov 2009
I have the magnetic rotor off a LG, the centre spline is chewed out and so it was replaced (can't buy the centre spline separately). What is the diameter of the rotor that you require and I will check the one that I have. If it is the same then you can have it as I will be only sending it off for scrap.
brucedownunder2
Posted: 08:19pm 06 Nov 2009
Fhank You ,Mr. nice Grub ,lol.
The one I need is 300mm outside diameter by 70mm thick..
I could use the plastic "hub" bit from mine in yours once I fit it with Neo's.
(07) 55453513 and we will work out the mailing stuff..
Bruce.
Bushboy
grub
Posted: 07:40am 09 Nov 2009
I reckon the one I have is the one you want. I left a message on your phone but if you can't understand me (I reckon I sound brain dead when I hear my recorded voice) then email me with your address and I will COD it to you via Aust. Post or the company of your account choice. Email is grubatausidotcom
Its all yours whenever you want it.
brucedownunder2
Posted: 01:28am 10 Nov 2009
Thank You "Grub" ..
I'm "out of town " at present,,grandkids birthdays...
I'll e-mial the details to you asap...
Thank You for your kind reply,,,I hope it will benefit all that are interested at a later date..
Bruce
Bushboy
brett
Posted: 12:13am 30 Nov 2009
Hi Bruce
Did you get the LG parts you need. I have a LG rotor and Motor (windings burnt) about the size you need.
Free if you want to pay postage and keep me informed on your progress with them.
Regards Brett
brucedownunder2
Posted: 05:07am 30 Nov 2009
Thanks Brett,, Cameron(grub) has kindly sent me one and I hope my kind postie will keep it in the postoffice depot for when I arrive back later this week..
I do intend to retrofit with Neo's and could use yours also ..it has to be the larger motor-you know there are 2 ..one stator is around 30mm wide ,the smaller.. and the big one I am using is around 40mm ,a bit larger than the F&P all over..
So ,yes, I will take yours if it's the larger one .
Cameron put his in a padded bag and securely cross taped it with strong packing tape ,,did the trick ok.
Bruce Pickers
48 Macrozamia Dr.
Clagiraba
QLD 4211
Thank You for your interest..
Bruce
Bushboy
grub
Posted: 08:50pm 30 Nov 2009
Cameron? Who the hell is Cameron? Unfortunately, or fortunately, I am another Trevor :)
brucedownunder2
Posted: 02:32am 01 Dec 2009
Ha,Ha ,,lol Mr. Grub ..
Just me ,an ol fa#t crackin up again.. Thought "Cameron" would be more polite than calling you "grub"...
Never mind ,
Bruce
Bushboy
grub
Posted: 08:47pm 01 Dec 2009
"Thought "Cameron" would be more polite than calling you "grub""
You haven't seen my backyard or workshop.
Was the rotor the correct one?
You should also get brett's burntout motor, can always rewire it.
brucedownunder2
Posted: 08:16pm 05 Dec 2009
Thanks Grub ,, got your parcel yesterday ,,the rotor is corret one and was not damaged..
Brett, I'm home now ,,so call me on 07 55453513 if you want to chat about your motor..
Nice to have friends ,,
Thanks a lot guys
Bruce
Bushboy
VK4AYQ
Posted: 01:20pm 20 Feb 2010
Hi Bruce
Hows the LG motor conversion going, I purchased one and would like to have a go at a twin unit if it would give a good output it is a lot more robust than a FP and I could double it up easier I think.
ALL the best
Foolin Around
KarlJ
Posted: 03:35pm 03 Apr 2010
Bob, chat with Phillm on that one mate
he spent a shedload of time on it but to very little avail.
send him a pm
VK4AYQ
Posted: 01:02am 04 Apr 2010
Thanks Karl
Will do mate I got one on ebay and its muck like the f&p 80. but a bit bigger. I thought it would be a good project for when I get the fp up and going.
I thought Bruce had a bit of a play with them.
Will give Phillim a call to see what he found.
All the best
Foolin Around
leeyn
Posted: 06:41am 22 Mar 2011
What is the diameter of the rotor that you require and I will check the one that I have...
Buy RS GoldRunescape GoldRS Gold
VK4AYQ
Posted: 02:20pm 22 Mar 2011
Hi leeyn
I will do a measure in the morning and get back to you, I think they are the same diameter though but one ahs a wider rotor and stator.
All the best
Foolin Around
