Local Time 00:12 12 Nov 2026 Privacy Policy
Forum Index : For Sale : Generators
flyfisher
Posted: 04:29pm 03 Aug 2012
WIND TURBINE GENERATOR - DORNHOFF & CO. K.G - HORREM BEZ. KOLN GERMANY - 32VOLT 6KVA DC. GENERATOR - TYPE: G5/325 INSUL. CLASS BTPL 1200RPM. - One motor is complete with coupling, the other has not and could be used as a spare. These items are Located in Warragul, Vic and are for pick up only. There will be no help to remove these items, so you had better bring your own muscle as needed. $780.00 for both.
