Local Time 00:22 12 Nov 2026 Privacy Policy
Forum Index : For Sale : Wind Turbine- 500W+
KarlJ
Posted: 11:44am 10 Nov 2009
The bug has bitten so I'm going for a dual stator, hence this one has to go as I've only got one tower.
A randys workshop "weldment", modified to include a stop to avoid blades hitting the tail.
Addition of the Yeasu thrust bearing and tail.
Set of blades PVC, 1200mm (giving diameter of about 2.5M).
Foundry and fiberglass nose cone and aluminium prop hub with splines.
80 series stator rewired for your chosen voltage.
Would certainly out perform a 500W chinese mill at over $1000 from Jaycar and would run quieter and not require the "cheap chinese mill mods" as described on this forum.
Asking $600 which is less than what it owes me.
VK4AYQ
Posted: 11:39am 05 Dec 2009
Hi Karl
how much would it cost to send to 4311
All the best
Foolin Around
KarlJ
Posted: 12:37am 06 Dec 2009
freight is $140 including insurance.
As we're paying dimensional here- If you wanted a couple of extra motor sets, the freight on them would be free and I'd give you the two spare motors / shafts bearings for free.
Karl
