Local Time 01:25 05 Nov 2026 Privacy Policy
Forum Index : Electronics : Inverter negative input current
davef
Posted: 02:08pm 25 Sep 2017
I have a measurement shunt between the battery and the inverter. At standby levels, ie about 1Amp (26 Volt system) the rather distorted waveform shows that current apparently is flowing back into the battery over about 1/4 of the overall time.
As soon as I put on a small load, ie 2-3Amps the waveform shifts upwards to be completely positive.
As the measurement system only handles positive currents I get a source of error at low loads and of course that is where the system sits for the largest percentage of the time!
Does this sound normal?
Edited by davef 2017-09-27
Posted: 02:20pm 25 Sep 2017
Could be. Circuits designed to measure 100 or so amps can struggle to give a accurate reading at the bottom of the scale.
davef
Posted: 04:27pm 25 Sep 2017
15bits of effective ADC resolution and low level DC loads are measured accurately. The ADC can only measure positive currents, the new model will be able to measure currents in both directions.
Posted: 05:54pm 25 Sep 2017
There are Hall Effect Current Sensors that are bidirectional and are ideal for this application.
davef
Posted: 08:11pm 25 Sep 2017
Thanks for suggested enhancement. It is an existing product that has software so realistically no opportunity to modify.
If some current flowing back into the battery is normal I will give up trying to incorporate this measurement error into my datalogging.
