Local Time 13:57 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Picaxe 28X1 to LCD display connection
Norbert Guérard
Posted: 11:23am 01 Jan 2008
Hello,
Based on the diagram "Gizmo's Windmill Charge Controller Ver.1.2 24/10/2005", I tried to make one but I have some problem with the LCD display.
Could you please tell me if the following interface connections between the picaxe 28X1 and the LCD display (LED008 from www.tech-supplies.co.uk) are ok or not?
Picaxe 28X1---connected through---to LCD(LED008)display-
pin n°-------------------------------pin n°-------------
----------------------0V-------------1 Vss--------------
----------------------+5V------------2 Vdd--------------
---------contrast adjust 10k pot-----3 V0---------------
23(out2)--------------330R-----------4 RS---------------
----------------------0V-------------5 R/W--------------
24(out3)--------------330R-----------6 SE---------------
-----------------------0V------------7 DB0--------------
-----------------------0V------------8 DB1--------------
-----------------------0V------------9 DB2--------------
-----------------------0V------------10 DB3-------------
25(out4)--------------330R-----------11 DB4-------------
26(out5)--------------330R-----------12 DB5-------------
27(out6)--------------330R-----------13 DB6-------------
28(out7)--------------330R-----------14 DB7-------------
Reason for my doubt: in the picaxe manual 3.pdf page 35 "Connecting the LCD option 3",
LCD pin 14 is indicated DB4
while on the LCD (LED008) display,
pin 14 is marked DB7
Which is correct?
b) second problem
When the file "picaxe_code.txt is opened with the "Picaxe Programing Editor Version 5.1.5" and the Picaxe Syntax checked, the following Compile Error appear: Error: Syntax error in this line
(line 11 : SYMBOL get = b11)
Should the SYMBOL "get" be changed to solve the problem?
Kind regards and happy new year.
Norbert
Norbert
Posted: 05:29am 02 Jan 2008
Hi Norbert
As far as I can the the wiring diagram on my site is correct. I dont have the latest 3.pdf manual from Picaxe, I'll download it tonight to have a look. But the circuit diagram has been used by a couple of visitors and has worked OK.
The "Get" may now be a reserved keyword with the latest PicAxe compiler. When I wrote the program Get was a valid variable name, but this may have changed since then. Renaming it should fix your problem, dont forget to change it where ever you see "Get".
Hope that helps
sPuDd
Posted: 01:58pm 02 Jan 2008
Norbert,
The PICAXE forum is the best place for this kind of info: PICAXE Forum UK
sPuDd..
It should work ...in theory
Norbert Guérard
Posted: 01:54pm 06 Jan 2008
Thank you for your help
The problem is solved simply by adjusting the contrast potentiometer of the LCD display to a lower voltage.
I had also to do a reset of the picaxe.
Best regards,
Norbert
Norbert
