Local Time 23:28 04 Nov 2026 Privacy Policy
Forum Index : Electronics : XM-L LED
irishron40
Posted: 03:16pm 07 Feb 2016
hi i am a little confused, I have a XM-L LED out of a torch that uses 3 1.5v batteries.
when i connect this XM-L LED thru a lm317 with output adjusted to 4,5 volt its not half as bright. this led draws 0.47A
how can i solve this?
thxEdited by irishron40 2016-02-09
isochronic
Posted: 06:10pm 07 Feb 2016
What voltages/current does the the 317 circuit have ie input and led ?
I am guessing your 3x1.5 cells are powering the led up ok but the 317
is dropping out, it would need say 5.5 - 6v input for 4.5v output I think
Edited by chronic 2016-02-09
Pete Locke
Posted: 11:13pm 07 Feb 2016
Here is the data sheet for the LED. Did the torch have a P.C board with clever bits on it with the torch? If so you would need to include it when powering it from any sort of supply, including batteries. There should at least be some sort of current limiting involved, as an LED is just like a zener diode when it conducts.
irishron40
Posted: 03:08am 08 Feb 2016
thanks for that info .
ron
irishron40
Posted: 03:49am 09 Feb 2016
just found out the problem.
The problem was that I had a bad earth.
I had build a rotating lighthouse out of what ever parts I had.
I had a shaft inside the rotating part and earth was taken with a brush from washing machine as it needed to be able to rotate. the shaft had a laquer on it which mad the contacts only maybe working at 50%.
Mad a copper shaft and now its full beam.
Just learned something elese due to this,
thanks for the help
ron
