Local Time 23:28 04 Nov 2026 Privacy Policy
Forum Index : Electronics : A question about unf radios
Nato1987
Posted: 05:22am 30 Jan 2016
Gday gents just wondering if I can connect a large CB radio antenna to a handheld 5w radio as I need a lot of range but can't afford (plus barely anyone uses) Hf
Any help greatly appreciated
NATO
davef
Posted: 08:43am 30 Jan 2016
What frequency does the handheld operate on?
Nato1987
Posted: 07:03pm 30 Jan 2016
Mate no idea I'm looking at a baofeng ATM
Nato1987
Posted: 07:06pm 30 Jan 2016
136-174 MHz and 400-479.995 MHz (TX/RX) That's what is says on the eBay page
http://www.ebay.com.au/itm/Baofeng-Dual-Band-UV-5R-VHF-UHF-Radio-3800mAh-Battery-Clip-PTT-Earpiece-AU-Stock-/14149505514 6?hash=item20f1c3332a:g:H-IAAOSwkNZUf~Zn
rustyrod
Posted: 09:56pm 30 Jan 2016
Australian old school CB radio was 27mhz so your set will no way work with an old one of these antennas
The uhf band is 476/477mhz so, no, an old school cb won't work here either
The vhf 136-174 mhz won't work with either a 27 mhz or a uhf antenna
you may get antenna tuner and a long length of wire to work, but the antenna tuner will cost as much as a second hand uhf unit.
You will get a long wire with a few turns around the portable's stubby antenna to work, to get more range/stations on receive.
Perhaps you could find a pair of handheld uhf with rechargeable batteries at (like)supercheap auto, then if the stubby aerial is removable, connect an uhf whip antenna
You possibly need two of your Baofeng units to talk together on vhf
The attraction of no one else on the vhf may be outweighed with limited distance.
I have no doubt some person could calculate the measurements and number of turns of wire to rewire an existing whip antenna or make a new one using a fishing rod blank
I still have my first walkie talkies that with a new 9 volt battery each, we could talk about three back yards apart. They were the size of half a brick and had a pull out antenna 1.2 meters long. We were so "cool". They cost around $30 for the pair in the mid 60's. My dad must have been rich. 9 volt batteries cost around 90 cents so we had to pool together our pocket money to get them. This did not happen often so was a real treat.
Always Thinking
Nato1987
Posted: 10:07pm 30 Jan 2016
  rustyrod said   Australian old school CB radio was 27mhz so your set will no way work with an old one of these antennas
Ok are there any antennas that would get me better range with minimal faffing about?
rustyrod
Posted: 01:26am 01 Feb 2016
Nothing is easy when doing modifications!
Do more research eg eBay, www - forums
eBay aerial for a few $s might work, then has your radio got bnc aerial connection?
If not more expense.
Have you contacted the supplier to inquire if any aerials are available?
This will wake up the neighbors, except you need a suitable antenna and lots of cabling and probably a licence.
I can't see where or what power supply. Ask seller for more detailed information.
Always Thinking
powerednut
Posted: 04:14pm 12 Feb 2016
Those transceivers are designed to operate on the amateur radio bands (2m and 73cm). You need a licence to operate those radios.
An amateur foundation licence isn't hard to get - your local club probably runs courses.
