Local Time 22:27 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Charge 12V battery from another w/o reg?
karmacoma
Posted: 11:50am 26 Aug 2015
Can I charge one 12V battery from another 12V battery without a regulator?
I want to charge a 12V 7.2Ah SLA battery from the solar power storage battery on my tiny remote PV system. The main battery is just a 140Ah car battery.
Can I do this without a regulator?
Ian
govertical
Posted: 12:03pm 26 Aug 2015
Greetings, from my experience with SLA batteries it may expand and burst if charged over the 12 volt limit. Hopefully other members will offer better info. Good question, thanks for posting. Edited by govertical 2015-08-27
karmacoma
Posted: 01:00pm 26 Aug 2015
Govertical, that would be a concern! But if the maximum voltage in the main battery is 14.4V or so (when it is itself charging through a PV panel and a high quality PV regulator), would that be too much for the SLA to cope with?
govertical
Posted: 01:19pm 26 Aug 2015
Hi, the manufacturer of your SLA may provide max charging information. Different battery types have different charging limitations.
rustyrod
Posted: 05:29pm 26 Aug 2015
In my experience, the rule of thumb with most batteries the amp hour divided by 10 is the charge rate
7.2 ah is .72 amp
then a 12v x 6 watt bulb draws .5 amp
or 12v x 10 watt bulb draws around .8 amp
install a bulb of choice in your charge circuit.
It will glow brightly for a start if your charging battery is flat and decrease as it charges
when the two voltages are the same it will go out.
you may charge a 6 volt battery in this manner although you will have to monitor when it is charged
using very small bulb you may charge a 1.25v elcheepo rechargeable cell in a few hours
been doing this like for ever
Always Thinking
karmacoma
Posted: 11:29am 27 Aug 2015
rustyrod, is the idea of the lightbulb to limit the charging current so that the car battery doesn't push energy into the discharged SLA battery at a very high current?
rustyrod
Posted: 03:47pm 27 Aug 2015
Yes, this is correct
Different wattage bulbs will give different charging currents.
Always Thinking
karmacoma
Posted: 12:27am 28 Aug 2015
I like how low-tech this is. Since we will be doing this in a Pacific Islands village, this kind of 'bush mechanic' approach is good. It's pretty elegant actually, because the light acts as a charging indicator - i.e. it goes out when charging is complete. The only thing is that traditional incandescent bulbs are getting harder to find - but hopefully there are still some bulbs in those wattages in the auto-parts shops.
Ian
Georgen
Posted: 11:25pm 31 Aug 2015
Couldn't use LED globes instead of incandescent one?
Edited by Georgen 2015-09-02
George
solarwind
Posted: 11:27am 17 Sep 2015
No, unfortunately not. Leds can only pass about 30mA or so max. (depending on the type of LED).
Incandescent lamps make fine current limiters!
You don't have success until you've tried it!
