Local Time 21:56 04 Nov 2026 Privacy Policy
Forum Index : Electronics : lm7808
irishron40
Posted: 07:36am 04 Jun 2015
Hi I build a dutch style windmill.
have a 180 volt 4 amp treadmill motor fitted inside that drives the blades.
Iam able to operate this motor on 6 volts as I dont want it to spin to fast.
now my problem is this.
it will work on my bench power supply at 6 volts
it also works on a 6.3 volt 600 miliamp phone charger.
but it refuses to work on a lm7808 run from car battery.
battery is fully charged.
I checked amps draw , and at 8 volt it draws 0.49 amps
just confused why it wont work on the lm7808.
the only thing i can think of is that by startup it might draw a bit more and that lm7808 isnt able for that.
maybe capacitors shoul;d sort it?
just wonder what size caps on the output
thx
ron
Edited by irishron40 2015-06-05
irishron40
Posted: 11:12am 04 Jun 2015
ok , I got it working on a 7805 transistor
on the output of the transistor I have 3 16v 2200uf caps and a 1n4007 diode as the treadmill motor is also a generator.
