Local Time 21:00 04 Nov 2026 Privacy Policy
Forum Index : Electronics : battery power
irishron40
Posted: 08:30am 21 Dec 2014
Hello, can you please confirmthe following
i have a new car baterry 12 volt 830 amp and 95ah
i run garden led lights. all light together draw 2.5 amp
so that would be 10 amp in 4 hour
should i devide the 95ah by 10 to see how many days i can have them on for or is it the 830 devided by 10 amp a day?
maybe an easy question for you all, but I am still learning lol
thank you
ron
davef
Posted: 09:19am 21 Dec 2014
830Amps sounds like the cranking current, so you don't want that.
So, 95Amps divided by 10A. Also, that 95Amp/hour rating is determined by the amount of current drawn, keywords discharge rate.
Also, search Battery University
irishron40
Posted: 09:23am 21 Dec 2014
thx davef
VK4AYQ
Posted: 12:36pm 21 Dec 2014
Hi Irishron
If you use the full 95 AH your battery will be fully discharged and that causes sever sulphation a few cycles at 100% discharge will reduce the capacity of your battery and a lot will destroy it.
As a rule of thumb with lead acid batteries to get a good life out of them it is wise to only discharge to 35 % of capacity so in your case only a bit over 30 AH and then fully recharge. That is on your figures 12 hours, so you would need t fully recharge daily to get a reasonably long life out of your battery.
All the best
Foolin Around
irishron40
Posted: 05:21pm 22 Dec 2014
thx bob. i might need to get a better dc motor that gives out more amp. we dont have continious winds here. it might give me 14 volts for 4 seconds and then wind drops again.
VK4AYQ
Posted: 05:27pm 22 Dec 2014
Hi Irishron
You may do better to invest in a solar cell as the sun is more reliable than the wind but the wind is a good backup.
All the best
Foolin Around
