Local Time 21:00 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Would this drive a F& P?
KiwiJohn
Posted: 10:23am 10 Dec 2014
HI folks, it is quite a while since I check in here but I know this is the right place to ask this question!
Would this controller drive a F&P?
http://www.trademe.co.nz/Browse/Listing.aspx?id=819793102
http://www.leadshine.com/UploadFile/Down/3DM683m.pdf
CheersEdited by KiwiJohn 2014-12-11
Posted: 02:30pm 10 Dec 2014
Maybe, but not very well.
The F&P is 3 phase, while most stepper motors are 2 phase.
Instead of a stepper driver, you might be better off using a servo driver. Many servo motors are 3 phase AC, and use a decoder to get the drive position.
I have some memory of Silicon Chip magazine doing an article on a F&P driver a couple years back. Some one else might be able to help.
KiwiJohn
Posted: 04:30pm 10 Dec 2014
Thanks Glenn, this one claims to be 3 phase and there is a pair of them being offered.
This is an extract from the manual (which is the second link in my opening post)
[quote]5. Connecting the Motor
The 3DM683 can drive any 3 lead or 6 lead three phase hybrid stepping motors. The connection
between the driver and 3-phase stepping motors includes two different kinds of connections, namely
delta-connection and star-connection. Using delta-connection, the performances of the motor under
high speed condition are better, but the driver current is higher too (about 1.73 times the motor coil
current); while using star-connection, the driver current equals to the motor coil current. [/quote]
I suppose another way to ask my question is does the F&P behave the same as a 'regular' 3 phase stepper?Edited by KiwiJohn 2014-12-12
Posted: 04:58pm 10 Dec 2014
Interesting, it might work. The F&P has a fair bit of back emf, but most modern stepper controllers can adjust for this.
I guess the F&P should be able to step, using its natural cogging, and hold, just like a regular stepper motor.
Dunno, would be a interesting experiment.
The SC web site shows the article about the F&P motor driver was published Feb 1012, but you need to pay to get any more info
I have a copy somewhere, but maybe someone else can put their finger on it quicker, the make/model of the controller would be handy.
KiwiJohn
Posted: 05:00pm 10 Dec 2014
Thanks Glenn, I might give it a miss as there does seem to be a lot of unfinished projects on my bench!
Posted: 05:04pm 10 Dec 2014
Found it!
The controller was $149, and you need to email contact@energy1000.com.au to buy one.
Now it looks like its just a motor driver, and not a stepper, so did you want to step the F&P or just run it as a motor?
yahoo2
Posted: 05:38pm 10 Dec 2014
From memory his was designed for a mobility scooter or a golf cart 50 amp by 36volt and was quite sluggish with standard 240v series wired motor.
The bit I remember is that the wiring for the hall effect sensors was made easy because the unit could self calibrate the phases as it was rotated, I thought that was pretty neat!
KiwiJohn
Posted: 05:49pm 07 Jan 2015
The 3DM683 driver arrived and yes, it does drive a F@P motor, sort of!
I have a 36V power supply and set the driver to 5.7A (peak).
Using EMC2 I can get the motor to run with bags of torque but acceleration is very slow and top speed is, estimated, 150rpm.
I am hoping to use this for the X axis on a CNC router table.
Posted: 06:51pm 07 Jan 2015
Hi John
Back EMF might be the problem with speed and acceleration. Same thing applies to any stepper motor. Do you have a F&P stator modified for a windmill? The parallel windings will drop the inductance and therefore you should be able to get more speed out of it.
KiwiJohn
Posted: 07:40pm 07 Jan 2015
Hi Glenn
I am a bit uneasy about damaging the driver from back EMF so thanks for reminding me of paralleling the windings.
Posted: 09:08pm 07 Jan 2015
No problem John, let us know how it goes.
I did a similar mod on some stepper motors for my own CNC. The steppers were 8 wire types, so you had 2 windings for the A phase and 2 for the B phase. The 2 A's could be connected in series or parallel. Same with the B phase. In series, it had more torque but less top speed. In parallel the torque was reduced, but speed improved.
I would see if you could reduce the 5.7 amps, at 36 volts its a lot of watts your pumping into the stator. Some stepper controllers have a running current and a holding current, so you may get away with a much lower holding current, and just reserve the high currents for motion. If you using micro-stepping, you may need to keep the holding current high to fight the F&P's natural cogging.
Lots to play with, you'll soon see why they call it stepper motor tuning.
KiwiJohn
Posted: 10:14pm 07 Jan 2015
Hi Glenn, I quickly changed the stator to star winding to see what difference I could see but nothing really to report there.
The current does sound high but neither the stator nor the driver heatsink is getting wam, maybe this power supply is not living up to its label!
First thing tomorrow I will cut the winding and make each phase 7+7 in parallel.
KiwiJohn
Posted: 10:15pm 07 Jan 2015
Dang! I meant to say I have changed to Delta wiring!
Holding current is set for 50% and after one second drops to 30%.Edited by KiwiJohn 2015-01-09
Posted: 12:17am 08 Jan 2015
Yeah good point about the power supply, might pay to throw a analogue multimeter or cro across the output to see how it holds up under load.
KiwiJohn
Posted: 09:21am 08 Jan 2015
While I have your here.. What do you think of the idea I see online of linking PC power supplies in series (after isolating the black wire from ground)?
Posted: 11:54am 08 Jan 2015
Yeap easy way to go if you have a few PC power supplies handy. I did the very same on my CNC rounter, see this page http://www.thebackshed.com/cnc/RouterA2.asp, though its a bit out of date, been a few changes to the cnc router since then.
As you say, got to isolate the -ve output from the power supply case.
KiwiJohn
Posted: 01:46pm 08 Jan 2015
Thanks, I know where there is a stack of power supplies waiting for the day they might be needed for something!
This tuning of the F@P motor is proving quite a challenge!
KiwiJohn
Posted: 08:50pm 11 Jan 2015
============NEWS FLASH!============
If you want to use a F&P as a stepper motor the number of steps per revolution is 112.
I cant understand why it is that number except that it is 8 times the number of windings.
Posted: 10:51pm 11 Jan 2015
Did you try the rewired stator?
KiwiJohn
Posted: 01:18pm 12 Jan 2015
Hi Gizmo, it is the same number of steps with rewired stator. I have one stator wired each phase 7+7 and one with has 3 phases of 6 coils each with the rest of the coils cut away with a jig saw!
They all operate on 112 steps per 360 degrees.
