Local Time 19:29 04 Nov 2026 Privacy Policy
Forum Index : Electronics : F + P smartdrive theory
rossmcn
Posted: 12:31pm 28 Sep 2012
Hi. I am working on a turbine from which I am going to be able to get an F+P motor to spin at about 600rpm. I am going to have two of them on a shared axle. Because it is a VAWT so I can experiment with different setups at ground level, Would I be best to start with staggered stator setup? How much is it theoretically possible, in watts, to get from a standard smartdrive, if it is doing around 600rpm? Cheers from Melbourne on Grand Final morning, jeeez its cold.
Technology has the advantage that it is 'real'. Theories, even laws, are ultimately only our best current model. Consequently, inevitably they will eventually be replaced with a better model
sjh7132
Posted: 12:34pm 28 Sep 2012
  rossmcn said   Hi. I am working on a turbine from which I am going to be able to get an F+P motor to spin at about 600rpm. I am going to have two of them on a shared axle. Because it is a VAWT so I can experiment with different setups at ground level, Would I be best to start with staggered stator setup? How much is it theoretically possible, in watts, to get from a standard smartdrive, if it is doing around 600rpm? Cheers from Melbourne on Grand Final morning, jeeez its cold.
600 RPM from a vawt that can overcome the cogging of 2 Smart drives? That sounds very impressive, do you care to share how you are doing that?
Steve
