Local Time 19:29 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Pete’s 10A variable power supply
MariusDeJong
Posted: 02:46pm 16 May 2012
On the site there is a schematic for a 10A variable power supply. I am currently building it and would like to some help with it. Can someone clarify the connection nodes. Where the line connect or just overlap. Attached is the schematic. I am still learning and would appreciate all the help i can get.
Marius de JongEdited by Gizmo 2012-05-18
Posted: 10:15pm 16 May 2012
I'm guessing you mean the wire from pin 2 of the IC? Yes there should be a dot there, it joins to all the resistors.
I've updated the drawings
http://www.thebackshed.com/Windmill/articles/VariablePowerSu pply.asp
MariusDeJong
Posted: 06:32am 18 May 2012
Dear Glenn
Thank you for your speedy reply and update. That is how I had it, looks like i will have to do some fault finding. The voltages seem to stay constant at 2.5V and doesn't want to adjust.
Marius de Jong
phase
Posted: 12:50am 02 Oct 2012
the lm723 cct is very simple and additional current transistors ae very simple to add..if you are still having trouble with the .."723 ..cct.." pl,s pm me ...
phase
Posted: 05:45am 02 Oct 2012
ok cool the lm"723 " can be used in numinous different equations ..Edited by phase 2012-10-03
larny
Posted: 11:44am 02 Oct 2012
This threasd had 2 pages before I logged in, but now I can only find one.
I had intended to quote one of phase's posts.
Phase, from memory, in essence you said "the LM 3914 can be configured to a single dot & the LED current can be set in the range 20-40 Ma"
You mean mA not Ma.
m = milli, M = Meg.
And the convention for units that are named after a person employ a capital letter.
In this case it was Ampere.
The same applies to Watt, Volt, Gauss, etc. but not units such as metre.
Hence mm = millimetre, km = kilometre, Mm = megametre.
Len
Posted: 05:41am 03 Oct 2012
[quote]This threasd had 2 pages before I logged in, but now I can only find one.
[/quote]
Perhaps its because you are in the wrong woods, and you should have commented in this thread.
http://www.thebackshed.com/forum/forum_posts.asp?TID=5207&PN =1&get=last#51893
Then all bears get lost in the woods at some time, just watch out for Goldie locks,
she will make a mess of your porridge.
larny
Posted: 12:06pm 03 Oct 2012
Yes, you're right.
Thanks.
Fornunately, I've had my porridge already.
