Forum Index : Electronics : New MPPT Board Design
| sjh7132 Newbie Joined: 27/12/2011 Location: United StatesPosts: 13 |
Is there a good way to post a youtube video? MPPT Video Steve |
Adding a link like you have done is probably the best way. Thats a very interesting video there Steve, well done. Keep us posted on how your MPPT development goes. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| govertical Guru Joined: 11/12/2008 Location: United StatesPosts: 383 |
Hi, if you use a battery for a test load do need a special interface or do you limit the board output ? just because your a GURU or forum administer does not mean your always correct :) |
Like I said in the video, right now the firmware is pretty crude, but eventually I want to have all the limits configurable so you could tell the board that to charge hard as long as the output voltage is below 14, and then start cutting back on the current so that it's zero if the battery is at 14.5 There is also a dump load circuit on the board so that if your battery can't take the power, it can put it into a dump load to keep the turbine under control. Steve |
