Local Time 19:29 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Oakley Shunt Regulator
ozetrade
Posted: 07:18am 26 Oct 2005
Not being an electronics wiz, could I get an opinion on this Shunt Regulator from Oakley. There's more info in this PDF.
Could this be modified to handle say 12V 35-40A out. Can it manage the expected voltage going in from an F&P...if not what mods would be required? Is there a better kit on offer somewhere else?
The kit price looks REAL good to me....and I'd like to know if a few mods would achieve a usable product.
Greg
Greg
Just North of Brisbane in Redcliffe
OZeTrade.net
Posted: 11:13am 27 Oct 2005
Hi Greg.
I havn't built one, but I think its a pretty good design. Basically it just clamps down the battery voltage when it gets to high. I think it can handle a few hundred watts, so would work for the F&P. Plus you could buy a couple at that price and connect them across the same battery bank with no problems. Nice simple design, set and forget.
If I needed another regulator, I would buy one.
ozetrade
Posted: 09:35pm 27 Oct 2005
Thanks Glen,
I ordered one last night. Looking forward to "trying" to put it together.Confused
greg
Greg
OZeTrade.net
Chris
Posted: 09:52am 29 Oct 2005
It uses common IRFZ44N mosfets that oatley sell cheap. You could add some extra's to a external board with some flying wires for more efficient and more current handling.
ozetrade
Posted: 10:54am 29 Oct 2005
  Chris said  It uses common IRFZ44N mosfets that oatley sell cheap. You could add some extra's to a external board with some flying wires for more efficient and more current handling.
Thanks Chris. When I get this board assemble and done some testing, I might get you to show me how to do that.
Greg
Greg
OZeTrade.net
Bryan1
Posted: 04:03am 22 Feb 2006
Hiya Guy's,
               I made up one of those Oatley shunt regulators to suit my nife batteries which float around 16 volts. It's been about 6 months since I made it and I've been away working most the time so I put some heating wire as a dumpload and the shunt reg looks after itself. As Chris stated it would pay to mount the mosfets on a seperate board and use decent heatsinks and it will handle the amps your after.
Cheers Bryan
brucedownunder2
Posted: 09:20pm 22 Feb 2006
   Hello, about the Oatley shunt reg .   If ya gunna increase the handling capacity , better take a look at the  terminal connections and the pcb tracks. these will need to be modified(larger) ,by thick wire or whatever .
  Go for fairly big heatsinks also on the exteran mosfets-maybe even take the 3 off the board also.
Nice little simple unit,but Glenn's sophisticated one  has all the bells and whistles.
  Bruce
Bushboy
BenandAmber
Posted: 05:38pm 30 Jul 2019
Some of you guys have been here a long time
