Local Time 09:11 23 Jun 2026 Privacy Policy
Forum Index : Electronics : pswgt-300 component identification
lambcutlet
Posted: 01:58pm 22 Oct 2011
hi,
just signed up to share this.
since i followed and used some of the info from the topics regarding the powerjack 300w grid tie inverter
Scrubbed component U2 appears to be a PWM controller
part number depends on component manufacturer but heres a short list
U2, onsemi - SG3525A or Fairchild - KA3525A or TI - UC3525A
they are all the same
Also,
Q4, Q5, marking 718 is FMMT718 pnp transistor
D5, D6, marking ZS1 is ZHCS1000 schottky diode
reason i worked this out. I wanted to check if the MOSFETs were specced correctly for there application
my gti blew the MOSFETs Q6 & Q1 STP75nf75Edited by lambcutlet 2011-10-24
