Local Time 12:08 04 Nov 2026 Privacy Policy
Forum Index : Electronics : LED solar panel meter
dwyer
Posted: 01:20pm 30 Dec 2006
hi l just found something intersting tonight on e-bay from e3b6a5y GlobalDigital
DC 50v/200A DIGITAL COMBO AMP & VOLTMETER
with built-in voltage regulator (BLUE Led display)
�@ Display Type   7-Segment, 3-1/2 BLUE LED Display
�@ Operating Voltage   5V~18V DC
�@ DC Voltage Range   0~50.0V DC
DC Current Range   0~200.0A DC
�@ Accuracy   0.2%
�@ Resolution   0.1V / 0.1A
�@ Input Impedance   >10Mƒ¶
�@ Sampling Rate   2~3 Readings per Second
�@ Dimensions   79mm�~43mm�~32mm
dwyer the bushman
Gill
Posted: 04:42am 31 Dec 2006
Thanks dwyer, had no end of trouble finding it though, so here's a link for the guys
.Aus_e3b6a5y-GlobalDigital-Store
or global,
they have a range of voltage and amp combos as you'll see. Good stuffEdited by Gill 2007-01-01
Cheers Gill _Cairns, FNQ
