Forum Index : Electronics : Fisher Paykel Motor.
| blucattledog Newbie Joined: 22/07/2011 Location: AustraliaPosts: 2 |
Hi there, I was wondering if someone could help me with a design for the Fisher Paykel smart drive motor. I need to run one of these motors at high speed(as fast as it runs now in the washing machine) but obviously not for a washing purposes. I will run this on a bench setup. What configuration could I use as far as the wiring goes(preferably stock without alteration of rotor/stator wiring)and how would I drive the motor in relation to a switch to turn it on and off.... power supply etc,,,, Basically this will be like a bench grinder setup, but used for polishing instead... Im not much of an electrical guru, which is why I came here and asked this question... Ive done a heap of searching on the net, but couldn't find anything like what I require,,, so I was hoping someone here could offer some help.. Cheers.. |
Hi Blu The F&P needs a special controller. Have a look at this post http://www.thebackshed.com/forum/forum_posts.asp?TID=3789&PN =1, should get you pointed in the right direction. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| Tinker Guru Joined: 07/11/2007 Location: AustraliaPosts: 1904 |
The F&P motor is, IMO, a little awkward to use for anything as a motor - other than the washing machine its designed for. But, there are heaps of washing machines around that use standard induction motors, these usually run a about 1450RPM on the shaft. Some have even 2 speed provisions. You'll get a better protected motor (and much easier to mount) than the F&P and a shaft that usually has a V-belt pulley on it - giving you a wide range of speed settings. Just look at your local recycle center or fossick at kerbside bulk rubbish collection days for cheap or free ones. I use a washing machine motor to power my home built bandsaw and another one to power a belt/ disk sander. These have been in use for about 20 years now and perform adequately. Can't see why not also useful for a polisher. You would be fiddling with a part that runs on lethal mains voltage and you need to connect the motor with this in mind. Best get an electrician to wire it up, its too dangerous fore somebody who is not "much of an electrical guru". This would apply to the F&P motor as well BTW. Its only when they are converted to become an alternator to run at low voltages for windmill uses the instructions on this forum are suitable for the average wannabe electrical guru . Klaus |
Thanks Guys, your time in responding is appreciated,, |
