Local Time 18:31 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Old F&P rotor types -differences?
domwild
Posted: 07:14am 26 Apr 2011
Just cleaning out the garage and looking at my collection of old rotors. Am finding two types: The ones with larger magnets and fewer of them (obvious!) and the other type with smaller magnets.
Questions:
Is one type better than the other one? Smoother waveform with more magnets?
Thanks.
Winston Churchill
Posted: 07:24am 26 Apr 2011
I have a suspicion the old rotors with the individual magnets are slightly stronger than the newer rotors with the four magnets combined into one block. I do remember hearing something about F&P going for the combined magnet because it made less of the whine noise on the spin cycle, but I could be totally wrong.
I do have some of the old and newer hubs in boxes in storage, I should use my gauss meter ( shameless plug intended ) and measure the magnet strength of the different types.
domwild
Posted: 10:36pm 26 Apr 2011
Thanks, Glenn.
Winston Churchill
Bryan1
Posted: 08:48am 27 Apr 2011
G'day Glenn,
Good idea to use the ugn3503 as a gauss meter, I made a simple circuit using one of them years ago for testing N-S poles. All I used was a nimh battery I got from oatleys a green led and resistor and the hall effect sensor.
With putting the poles in on my 4kw motor conversion I didn't need that circuit as the strength of the magnets told me if I got the poles right. Once I got all 21 magnets in one pole I couldn't get the opposing pole within 2" of it. I did find out the hard way when one get the pole wrong a split magnet and luckily none in my finger.
Cheers Bryan
