Local Time 18:55 04 Nov 2026 Privacy Policy
Forum Index : Electronics : SC mppt sol reg
mid north Matt
Posted: 05:00am 03 Feb 2011
just seen the new silly chip mag and they have a mppt solar regulator circuit aimed at campers/mobile home owners with engel fridges for 12/24 volt systems up to 120w @12v,so can this be tweaked for more amps by adding more mosfets and heatsinking?
Pt Wakefield Matt
Bryan1
Posted: 08:33am 03 Feb 2011
G'day Matt,
The sillychip article last year on the solar night light has the circuit and after I complained about no code they put the source code up on their website. Basically that circuit beefed up with a bigger fet and inductor and modifying the code will be good enough for any mppt diy build.
Cheers Bryan
mid north Matt
Posted: 01:38am 05 Feb 2011
hi Bryan
just checked the s/chip mag again at the shop and the regulator has one of those pic chips so unless someone brings out a kit that puts me out as i dont know how to program pics that they insist on using in alot of there projects
Pt Wakefield Matt
govertical
Posted: 08:58pm 01 Jan 2012
  Bryan1 said   G'day Matt,
Cheers Bryan
Hi, is there a link? I would to check the circuit.
