Local Time 17:57 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Variable power supply update
Doug
Posted: 11:34pm 07 Oct 2010
Hi all
Was looking through a web page on electronic projects, specifically power supplies and came across the variable power supply cct that glen has posted in the projects page with one change. The LM317 transistor is only good for about 1.5 amps maximum current flow. Apparently if you change it for a LM338T it will handle up to 5 amps. In my mind that makes it a much more usable type of power supply.
Doug
May The Power Be With You
Posted: 11:28am 24 Nov 2010
Good info Doug.
I've used a LM338K in the past, same chip but different case. One tip I have is to use a BIG heatsink if you plan to draw a few amps, since its a series regulator and they can get very warm. The LM338 has built in protection against overheating, a big heatsink will mean better regulation at high current loads.
VK4AYQ
Posted: 01:04pm 24 Nov 2010
Hi Glen
Have you seen the switchmode regulator its got four leads in the same package as a normal regulator 5 amps I think and very low loss I cant find the number at the moment.
All the best
Foolin Around
VK4AYQ
Posted: 09:34pm 24 Nov 2010
Hi Glen
I found the details on the regulator, is 3 amp not 5 as I thought but maybe able to be used as a controller for a high power fet, what do you think.
All the best
Manufacturer: National Semiconductor
Manufacturer P/N: LM2576T-ADJ
Output voltage adjustable from 1.23V to 37V
Guaranteed 3A output current
Input voltage up to 40V
High efficiency
Thermal shutdown and current limit protection
Package: TO-220
http://www.national.com/ds/LM/LM2576.pdf
http://www.national.com/ds/LM/LM2576.pdfEdited by VK4AYQ 2010-11-26
Foolin Around
Posted: 10:29pm 24 Nov 2010
Hi Bob
I've been tempted to build a switch mode variable power supply for some time. Something different to my trusty old series regulators, with a smaller heat sink
The LM2576 looks pretty good, easy to use. Jaycar sell them for $17.oo
I also like the TL494, its just the IC, and needs a MOSFET and other parts, but does include neat features like soft start and current limiting. The TL494 is used in many PC power supplies and I've used one in a motor controller.
http://www.datasheetcatalog.org/datasheet/motorola/TL494.pdf
http://focus.ti.com.cn/cn/lit/an/slva001d/slva001d.pdf
VK4AYQ
Posted: 11:01pm 24 Nov 2010
Hi Glen
I have found some on ebay
Seller information
green21century ( 4584)
99.8% Positive feedback
Ask a question
Save this seller
See other items
Visit store: green21century
10 units for $13 free post have ordered some to try them, do you think they could be used as a controller for a couple of fets, I have a nice 1.2 kw transformer 36 volt I would like to build a big power supply with but didn't want to create a workshop warmer with 3055 in parallel.
All the best
Foolin Around
VK4AYQ
Posted: 11:15pm 24 Nov 2010
Hi Glen
Had a look at the spec sheet, it is an interesting option.
Foolin Around
